Author Topic: Searching files in subfolders?  (Read 8801 times)
whdjr
« on: December 22, 2004, 10:52:45 AM »
I was trying to write a tool that would search all subdirectories (below the folder I selected) and return a list of dwgs with the path intact.  This is becoming a lengthy process and I didn't know if I was missing something or if someone might know of an easier way.  Part of my tool relies on an expresstool command (which I don't particularly like) and searching for files in subfolders seems to be difficult if you are unsure how many subfolders there are.
Any thoughts or suggestions would be helpful.
Thanks,
Ron Heigh
« Reply #1 on: December 22, 2004, 11:05:07 AM »
you can do this very easily with the code for the superfind program.
it uses VBA.
do you have the acadx module by Tony Tanzillo?
whdjr
« Reply #2 on: December 22, 2004, 11:13:48 AM »
No.  I don't have it.  I am really close to getting it.  I have written recursively, but I'm not sure how I can get it to save the folder names though.  It just gives me a bunch of nil lists.
Here is my code so far:
(defun c:test ()
  (find_dwgs (acet-ui-pickdir))
(defun find_dwgs (path / folders files)
  (setq folders (get_folders path))
(defun get_folders (folder / f)
  (if (setq f (cddr (vl-directory-files folder nil -1)))
    (mapcar '(lambda (x)(get_folders (strcat folder "\\" x))) f)
The code looks a little bare, but I stripped out a bunch of other options and stuff to go with it just to make it a bit more readable and understandable.
« Reply #3 on: December 22, 2004, 11:24:50 AM »
Perhaps this will give you some ideas.
;;;  fn2file.lsp by Charles Alan Butler
;;;  by Precision Drafting & Design All Rights Reserved.
;;;  Contact at ab2draft@TampaBay.rr.com
;;;   Version 1.0   Nov 26,2004
;;; DESCRIPTION
;;; Create a text file with file names of a given type in a
;;; specific directory. Text file name is the directory name
;;; First line is the path then all files names
;;; The file is saved in that directory
;;;  Limitations
;;;  Limited error checking
;;; Command Line Usage
;;; Command: fn2file
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
(defun c:fn2file (/ flist myfile path ftype fname)
  (and
       ;;(setq path (ale_browseforfolder "Select directory to get files:"))
       ;;(setq path (strcat path "\\"))
       (setq path (getfiled "Select a File Type in Folder you want the list from" "" "" 4))
       (setq ftype (strcat "*" (caddr (fnsplitl path))))
       (setq path  (car (fnsplitl path)))
       (setq flist (megetfolders path ftype nil)); change nil to T to get sub folders
       (setq fname (strcat path (last (splitdirs path)) "-" (substr ftype 3) "-files-list.txt"))
       (mk-file fname (car flist))
(prompt "\nTo create a text file of file names enter fn2file.")
;  Jürg Menzi (info@menziengineering.ch)
;This code returns folders recursive or not recursive with or without
;file names:
; == Function MeGetFolders
; Scans from current folder (recursive) for folders (and files).
; Arguments [Type]:
;   Fol = Root folder [STR]
;   Pat = File name pattern
;         - Not False: eg. *.*, *.dwg [STR]
;         - False:     Folders only [BOOLEAN]
;   Rec = Recursive flag [BOOLEAN]
;         - True:  scan folders recursive
;         - False: scan first folder level
; Return [Type]:
;   > If pattern argument False:
;     '("Pth1" "Pth2"...) [LIST]
;   > If pattern argument not False:
;     '(("Pth1" '("Fil1" "Fil2"...)) ("Pth2" '(...))...) [LIST]
; Notes:
;   - If no files found in a folder, the file list returns a '("").
;   - Deep folder structure slow down the function.
(defun MeGetFolders (Fol Pat Rec / FolLst TmpFol)
 (setq TmpFol (if (wcmatch Fol "*\\") (substr Fol 1 (1- (strlen Fol))) Fol)
       FolLst (cons TmpFol (apply 'append (MeGetFoldersRec TmpFol Rec)))
 (if Pat
  (mapcar
  '(lambda (l)
    (cons l (cond ((vl-directory-files l Pat 1)) ('(""))))
   ) FolLst
  FolLst
; == Function MeGetFoldersRec
; Recursive function for MeGetFolders.
; Arguments [Type]:
;   Fol = Folder [STR]
; Return [Type]:
;   > Folder list '((Pth1) (Pth2)) [LIST]
; Notes:
;   Return value contain nil atoms.
(defun MeGetFoldersRec (Fol Rec / TmpFol)
 (mapcar
 '(lambda (l)
   (if (not (wcmatch l "`.*"))
    (cons
     (setq TmpFol (strcat Fol "\\" l))
     (if Rec (apply 'append (MeGetFoldersRec TmpFol Rec)))
  ) (vl-directory-files Fol nil -1)
;;  Write data to text file
(defun mk-file (fname datalst)
  ;; open a file for writing
  (setq fo (open fname "w"))
  (foreach itm datalst (write-line  itm fo))
  (close fo) ; close the open file handle
; Example: (ALE_BrowseForFolder "Select drawings folder")
; Original BrowseForFolder by Tony Tanzillo
(defun ALE_BrowseForFolder (PrmStr / ShlObj Folder FldObj OutVal)
   (setq
     ShlObj (vla-getInterfaceObject
              (vlax-get-acad-object)
                "Shell.Application")
     Folder (vlax-invoke-method ShlObj 'BrowseForFolder 0 PrmStr 0)
   (vlax-release-object ShlObj)
   (if Folder
         (setq FldObj (vlax-get-property Folder 'Self)
               OutVal (vlax-get-property FldObj 'Path)
         (vlax-release-object Folder)
         (vlax-release-object FldObj)
         OutVal
;;  by MP
; (splitdirs "c:\\123\\456\\789") returns ("c:" "123" "456" "789")
(defun splitdirs (path / r w i c)
  (setq w "" i (1+ (strlen path)))
  (repeat (strlen path)
    (if (member (setq c (substr path (setq i (1- i)) 1)) '( "\\" "/"))
      (if (/= w "") (setq r (cons w r) w ""))
      (setq w (strcat c w))
  (if (/= w "") (cons w r) r)
  ;;  remove file name added by CAB
  (if (wcmatch path "*`.*") ; has file name ?
    (reverse (cdr (reverse r))) ; remove it
    r
Anonymous
Recursive solution for finding files in subdirectories
« Reply #4 on: December 22, 2004, 12:27:52 PM »
Hey Swampers,
Find a file in subdirectories using recursion.
the syntax is
(findfilex "c:/acad/" "312vg.dwg")
It will return a list of the files
Peter Jamtgaard
(defun FINDFILEX (PATH FNAME / DIRLST2)
 (if (findfile (strcat PATH FNAME))
  (setq DIRLST2 (list (findfile (strcat PATH FNAME))))
 (search PATH FNAME)
(defun SEARCH (PATH FNAME / DIRLST PATH2)
 (setq DIRLST (vl-directory-files PATH nil -1))
 (if DIRLST
  (foreach N DIRLST
   (if (and (/= N ".")(/= N "..")(/= N nil))
     (setq PATH2 (strcat PATH N "/"))
     (if (findfile (strcat PATH2 FNAME))
      (setq DIRLST2 (cons (findfile (strcat PATH2 FNAME)) DIRLST2))
     (search PATH2 FNAME)
 (reverse DIRLST2)
whdjr
« Reply #5 on: December 22, 2004, 01:17:49 PM »
Thanks CAB.
The recursive section by Jürg Menzi had the missing link I needed.
SMadsen
« Reply #6 on: December 22, 2004, 01:25:04 PM »
Yet another, written long ago (wrapped in a primitive interface command)
(defun C:SEARCHFOR (/ foundfiles folder fn)
  (defun filesearch (fld filename / fld fn found flst lst)
    (cond ((setq flst (vl-remove ".." (vl-remove "." (vl-directory-files fld))))
           (setq lst (mapcar (function (lambda (n)
                                         (if (= (substr fld (strlen fld) 1) "\\")
                                           (strcat fld n)(strcat fld "\\" n))))
                             flst)
           (foreach fd lst
             (cond ((vl-file-directory-p fd)
                    (filesearch fd filename))
                   (T
                    (cond ((wcmatch fd filename)
                           (setq found      fd
                                 foundfiles (cons found foundfiles)
                           (princ found)
                           (terpri)))))
  (setq folder (getstring "\nStart in folder: ")
        fn     (getstring "\nFile to search for: ")
  (if (= folder "")(setq folder (getenv "systemDrive")))
  (cond ((and folder (/= fn ""))
         (filesearch folder fn))
  (princ (strcat "\n" (itoa (length foundfiles)) " files found"))
« Reply #7 on: December 22, 2004, 02:05:09 PM »
Quote from: SMadsen
there it is!! I was waiting for you to dig that out.  :D
I remember seeing that code but couldn't remember where or when.
thanks guys, that is some very nice code.
SMadsen
« Reply #8 on: December 22, 2004, 06:28:47 PM »
Quote from: Mark Thomas
You could just have asked  :D
whdjr
« Reply #9 on: December 23, 2004, 08:14:34 AM »
"Ask and you shall receive"
