I'm working on a proof-of-concept for a quickie in-application model viewer, using a NavisWorke "Lite" control and a 3D DWF of the current model. The back end seems to work, but I'm having nothing but problems with the front end.
How do you generate a 3D DWF from C#? All my search results are for plotting, which makes 2D DWFs- no good. I'm not seeing an equivalent method in the VS object explorer to either the "Export" or "3DDWF" commands. Anything DWF-related seems to be for manipulating DWFs, not actually *creating* one. The COM Export method doesn't have a DWF option.
(and thats the 10th time IT has called me in the last two hours about license setup. TRYING TO GET RESEARCH DONE HERE! :realmad: )
Suggestions?
EDIT: and what the flip is this doing in VBA??? I posted this in the .NET area! :doa:
