Can I manage files loading (arx/.net/lisp/vba) via events, with possibility of cancellation for load every from it?
In my code I can only get message about files loading (arx/.net/lisp):
//Microsoft
using System;
using System.Linq;
using System.Text;
using Microsoft.Win32;
using System.IO;
//Autodesk
using acad = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
namespace MyNetLib
public class Class1 : IExtensionApplication
DocumentCollection dm = acad.DocumentManager;
Document dwg;
Database db;
Editor ed;
const string ns = "gpsm";//namespace of commands
/// <summary>
/// Default constructor
/// </summary>
public Class1()
Drawing = acad.DocumentManager.MdiActiveDocument;
/// <summary>
/// Drawing
/// </summary>
Document Drawing
get { return dwg; }
set
dwg = value;
if (dwg != null)
db = dwg.Database; ed = dwg.Editor;
else
db = null; ed = null;
public void Initialize()
ed.WriteMessage("\nInitialize 'MyNetLib'...\n");
AppDomain.CurrentDomain.AssemblyLoad += new AssemblyLoadEventHandler(CurrentDomain_AssemblyLoad);
((AcadApplication)acad.AcadApplication).ARXLoaded += new _DAcadApplicationEvents_ARXLoadedEventHandler(Class1_ARXLoaded);
dwg.LispWillStart += new LispWillStartEventHandler(dwg_LispWillStart);
ed.WriteMessage("\nInitialize 'MyNetLib' finished.\n");
void CurrentDomain_AssemblyLoad(object sender, AssemblyLoadEventArgs args)
ed.WriteMessage(string.Format("\nLoading .Net-library '{0}'\n", args.LoadedAssembly.Location));
void Class1_ARXLoaded(string AppName)
ed.WriteMessage(string.Format("\nLoaded ARX-library: '{0}'\n", AppName));
void dwg_LispWillStart(object sender, LispWillStartEventArgs e)
try
string x = "(load ";
if (!e.FirstLine.StartsWith(x)) return;
string fileName = e.FirstLine.Substring(x.TrimEnd(null).Length, e.FirstLine.Length - x.Length - 1).Replace("\"","");
List<string> paths2;
string cProfileName = acad.GetSystemVariable("cprofile") as string;
//Current AutoCAD registry key
string productKey = Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.ProductKey;
string keyName = string.Format(@"{0}\Profiles\{1}\General", productKey, cProfileName);
RegistryKey regKey = Registry.CurrentUser.OpenSubKey(keyName, true);
string regValue = regKey.GetValue("Acad", string.Empty) as string;
regValue = regValue.Substring(0, regValue.Length - 1);
List<string> paths = new List<string>(regValue.Split(';'));
paths2 = new List<string>();
paths2.Add(Environment.CurrentDirectory);
paths2.Add(new FileInfo(acad.DocumentManager.MdiActiveDocument.Name).Directory.FullName);
paths2.Add(((IAcadApplication)acad.AcadApplication).Path);
paths = paths2.Concat(paths).Distinct().ToList();
foreach (string item in paths)
if (File.Exists(Path.Combine(item, fileName)))
ed.WriteMessage(string.Format("\nLoading Lisp-file {0}\n", Path.Combine(item, fileName)));
return;
ed.WriteMessage(string.Format("\nLoading Lisp-file {0}\n", fileName));
catch (System.Exception ex)
ed.WriteMessage(string.Format("\nError: '{0}'", ex.Message));
public void Terminate()
//throw new NotImplementedException();
But I not known how do it for VBA-files (even for loading).
Registration in registry (reg-file):
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.2\ACAD-7001:409\Applications\Net]
"LOADER"="D:\\AcadPlagins\\MyNetLib.dll"
"LOADCTRLS"=dword:00000002
"MANAGED"=dword:00000001
Result:
