Author Topic: explain me how is work (cond, While & its)  (Read 7730 times)
Sam
« on: September 16, 2010, 01:03:34 AM »
Dear all
(cond, While & its)
« Last Edit: September 16, 2010, 01:17:37 AM by Sam »
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
BlackBox
Re: explain me how is work (cond, While & its)
« Reply #1 on: September 17, 2010, 01:56:16 PM »
(cond, While & its)
Please read the Developer Documentation for information on the cond and while functions.
To view this documentation, open the VLIDE (by typing VLIDE at the command line + Enter), and hit F1.
Hope this helps!
« Reply #2 on: September 17, 2010, 02:30:12 PM »
Subtitle: Hard to help a man who won't help himself?
« Reply #3 on: September 17, 2010, 02:40:34 PM »
The Its has me intrigued.
The rest I found here on my system ... ( yours may differ)
C:\Program Files\Autodesk\ACADM 2011\Help\acad_dev181.chm
« Reply #4 on: September 17, 2010, 03:01:48 PM »
I'm guessing a case of IF typed with fat fingers  :evil:
BlackBox
« Reply #5 on: September 17, 2010, 04:38:33 PM »
I hope I wasn't 'mean'...? :-o  If so, that was not my intention.
I simply felt it prudent that the OP read for themselves, before broaching a conversation on the matter(s).
[edit]
To offer a couple of carrots...
The cond function is a conditional function (hence the name), which permits the testing for one of several list cases. When the test expression of a list is true, a subsequent expression is evaluated for that condition only. Out of many possible list cases, only one condition is evaluated.
If that jibberish didn't make any sense, maybe this will:
  (([color=red]If_Test_1_is_True[/color]) ([color=blue]Do_This_1[/color]))
  ((If_Test_2_is_True) (Do_This_2))
  ((If_Test_3_is_True) (Do_This_3))
  ((If_Test_4_is_True) (Do_This_4)))
The while function provides a potential loop, given a test expression. 'While' the test expression is true, a subsequent expression is evaluated.
For example:
(while ([color=red]This_Test_is_True[/color])
 ([color=blue]Do_This[/color]))
I hope that helps!
[/edit]
« Last Edit: September 17, 2010, 04:55:39 PM by RenderMan »
« Reply #6 on: September 17, 2010, 04:46:53 PM »
<snip>
MP felt the same way as you RenderMan.
BlackBox
« Reply #7 on: September 17, 2010, 05:01:28 PM »
Thanks for the clarification, Se7en... I'm new to TheSwamp, and I'm not trying to 'make waves' (pun intended).
You know, a man wiser than I once shared with me the secrets for 'How To Ask Questions The Smart Way'... I felt that my initial reply was a fitting response, given the question.
« Reply #8 on: September 17, 2010, 08:04:16 PM »
Had a spare minute, so here is a quick outline:
IF
IF evaluates a test expression (shown in blue), and, if it returns anything non-nil, will proceed to evaluate a 'then' expression (shown in red). Should the test expression return nil, IF will evaluate the 'else' expression (shown in green) should this be supplied.
IF/THEN
(if [color=blue](this_is_true)[/color]
  [color=red](do_this)[/color]
IF/THEN/ELSE
  [color=green](else_do_this)[/color]
The IF function can only take three arguments: the test expression, an expression to evaluate if the test expression returns non-nil, and an optional expression to evaluate if the test expression returns nil.
Hence, if we wish to evaluate mutiple expressions within the IF function, we can wrap these functions within a function such as progn which can be then supplied to IF as a single expression:
IF/THEN
[color=red]  (progn
    (do_this)
    (and_this)
    (and_this)
  )[/color]
IF/THEN/ELSE
[color=red]  (progn
    (do_this)
    (and_this)
    (and_this)
  )[/color]
[color=green]  (else_do_this)[/color]
IF/THEN/ELSE
[color=red]  (progn
    (do_this)
    (and_this)
    (and_this)
  )[/color]
[color=green]  (progn
    (else_do_this)
    (and_this)
    (and_this)
  )[/color]
COND
COND will evaluate a test expression (first item in a list of expressions) for each condition (list of expressions) supplied and evaluate the expressions following the test expression should it return non-nil. COND will stop evaluating test expressions when a condition is met.
    [color=blue](if_this_is_true)[/color]
[color=red]    (do_this)
    (and_this)
    (and_this)[/color]
    [color=blue](else_if_this_is_true)[/color]
    (and_this)
    (and_this)[/color]
    (and_this)
    (and_this)[/color]
This functionality could also be achieved using a tree of nested IF statements, however this is much less elegant and harder to follow:
[color=red]  (progn[/color]
    (and_this)
    (and_this)[/color]
  (if [color=blue](else_if_this_is_true)[/color]
      (and_this)
      (and_this)[/color]
        (and_this)
        (and_this)[/color]
WHILE
WHILE will evaluate a test expression, and, if it returns a non-nil value, will evaluate a set of expressions; this is repeated until the test expression returns nil.
(while [color=blue](this_is_true)[/color]
  (and_this)
  (and_this)[/color]
That's all for now!
Lee
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: September 17, 2010, 11:47:56 PM »
cond is similar to the switch statement in C++ except for its spelling and implementation
« Reply #10 on: September 17, 2010, 11:51:12 PM »
So,
it's the same but different  :-P
« Reply #11 on: September 17, 2010, 11:57:05 PM »
nice explanation Lee  :-)
Sam
« Reply #12 on: September 18, 2010, 01:41:44 AM »
dear all
renderman,se7en, kerry & special thx for lee mac
thx for help & u r valuable time
« Reply #13 on: September 18, 2010, 07:32:27 AM »
Thanks Ron  :-)
« Reply #14 on: September 18, 2010, 01:41:58 PM »
Is it right that the switch statement can only handle integers as the test expressions though? I found that really annoying when learning C++ ...  :|
