Author Topic: Ex: Show Thumbnail in PictureBox VB.NET  (Read 22492 times)
Jeff H
Re: Ex: Show Thumbnail in PictureBox VB.NET
« Reply #15 on: September 19, 2010, 04:53:59 PM »
jgr
« Reply #16 on: September 19, 2010, 05:36:47 PM »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: September 20, 2010, 02:33:00 AM »
I think the blockIcon command  generates  32x32x8bpp bitmaps,  I was able to create them via AcGsDevice/ AcGsView && MFC.
http://www.theswamp.org/index.php?topic=33116.msg401299#msg401299
For .net have a look at Autodesk.AutoCAD.GraphicsSystem.GetSnapshot(Rectangle rectangle); You should be able to render the block and take a snapshot,  I think you can do this via OffScreenDevice so you're not capturing off a control like I did
Jeff H
« Reply #18 on: September 20, 2010, 03:02:24 AM »
I use PreviewIcon with no problem
but this was a reply for CapturePreviewImage which broke in 2011 and the drawing does not have to be active
The behavior has been already reported. The current status for the Change Request is fixed and it should be available in the upcoming AutoCAD update.
As a workaround, The property “Layout.Thumbnail” should give you the layout/paper space thumbnail bitmap.”
Or if you need a thumbnail of the model space you can use the code I provided in my initial reply.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: September 20, 2010, 03:05:43 AM »
DoH! sorry, my mistake, just ignore me   :whistle:
Jeff H
« Reply #20 on: September 20, 2010, 03:07:05 AM »
This one brings up a dialog box though
 <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Unicode)> _
Private Shared Function acedCommand(ByVal type1 As Integer, ByVal command As String, ByVal type2 As Integer, ByVal blockName As String, ByVal [end] As Integer) As Integer
        If btr.PreviewIcon Is Nothing Then
            acedCommand(5005, "BLOCKICON", 5005, blkName, 5000)
Jeff H
« Reply #21 on: September 20, 2010, 03:08:36 AM »
Did you figure out in .NET another way for blocks with out having to call BlockIcon
It's Alive!
  • Retired
  • AKA Daniel
« Reply #22 on: September 20, 2010, 03:28:57 AM »
Not with .NET, but I assume you can use the classes within Autodesk.AutoCAD.GraphicsSystem to render, view, or get a snapshot of any entity(s) just as you can with the underlying AcGs classes.
Jeff H
« Reply #23 on: September 20, 2010, 04:02:09 AM »
That NameSpace does not like me every thing I played around with in it has crashed or just leaves a bunch of stuff all over the screen including code from ADN but I am pretty sure it has to do with I have no idea what I doing?
Jeff H
« Reply #24 on: September 20, 2010, 05:30:15 AM »
The Database.ThumbnailBitmap reads like 200 out of 200 iterating through a folder
This one read 0 out of a 200
        [System.Security.SuppressUnmanagedCodeSecurity(), DllImport("acdb18.dll", CallingConvention = CallingConvention.Cdecl,
         EntryPoint = "?acdbGetPreviewBitmap@@YAPEAUtagBITMAPINFO@@PEB_W@Z")]
        private static extern IntPtr acdbGetPreviewBitmap([MarshalAs(UnmanagedType.LPWStr)] string sFilename);
        System.Drawing.Bitmap GetBitmapFromDwg(string filename)
            IntPtr bmpInfo = acdbGetPreviewBitmap(filename);
            return Autodesk.AutoCAD.Runtime.Marshaler.BitmapInfoToBitmap(bmpInfo);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #25 on: September 20, 2010, 06:14:45 AM »
I'm a little confused are you trying to get the PreviewBitmap for the drawing or the PreviewIcon(still bitmaps) from the BlockTableRecord?
Jeff H
« Reply #26 on: September 20, 2010, 12:49:04 PM »
Sorry
There all thrown together
Basically I have no problems getting either a BlockTableRecord's or "drawings or layout's" bitmap's closed or open, but I have not found a stable method for generating one if it does not exist.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #27 on: September 21, 2010, 03:57:39 AM »
Simple, use the  AcGsVew classes as I mentioned earlier
here is a snippit of a form, just use your block or any other entity
namespace ExecMethod
  public partial class ViewFrm : Form
    AcGs.Manager manager = null;
    AcGs.Device device = null;
    AcGs.Model model = null;
    AcGs.View view = null;
    public ViewFrm()
      InitializeComponent();
      manager = AcAp.Application.DocumentManager.MdiActiveDocument.GraphicsManager;
      device = manager.CreateAutoCADDevice(this.Handle);
      device.OnSize(new System.Drawing.Size(300, 300));
      model = manager.CreateAutoCADModel();
      // you can use your block ref for this
      view = manager.CreateAutoCADView(new Line(new Point3d(0, 0, 0), new Point3d(300, 300, 0)));
      device.Add(view);
      view.ZoomExtents(new Point3d(0, 0, 0), new Point3d(300, 300, 0));
      //Bitmap bmp = view.GetSnapshot(new System.Drawing.Size(300, 300)) <<<<<------------------------
    private void ViewFrm_Paint(object sender, PaintEventArgs e)
      view.Invalidate();
      view.Update();
Jeff H
« Reply #28 on: September 21, 2010, 04:22:29 AM »
Finally I used that class without crashing
Once again Thank you
AHH!
It just crashed in the background
*EDIT*
 After I close the form about 5 to 10 seconds later it crashes
*EDIT*
http://forums.autodesk.com/t5/AutoCAD-2007/Unhandled-Access-Violaton-Writing-0x0014-Exception-at-7788fc47h/td-p/2674073
Is the same error
It might be something with my system
Thanks again for the code
« Last Edit: September 21, 2010, 04:42:39 AM by fro2001 »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #29 on: September 21, 2010, 05:52:58 AM »
Sorry, it was only indented to give you an idea, you probably need to do a bit of disposing
