Author Topic: Want to IMPRESS your CoIrkers??  (Read 5574 times)
« on: November 26, 2003, 02:54:57 PM »
Try this bit of API Code I put together.
Simply place it in a new module in the VBA editor and select the corresponding macro "SetWindowText" from the macros list from the toolbar.
Option Explicit
Declare Sub WindowText Lib "user32" Alias "SetWindowTextA" (ByVal hWnd As Long, ByVal N As String)
Public Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Public Function FindAutoCAD() As Long
  FindAutoCAD = FindWindow(vbNullString, Application.Caption)
End Function
Sub SetWindowText()
 WindowText FindAutoCAD, Interaction.InputBox("What do you want to name your AutoCAD session: ", "Rename AutoCAD", "AutoCAD")
End Sub
Right now I am using AutoCAD 2000 W/SwampCAD Add-ons....
Cool huh....
 :twisted:  :twisted:  :twisted:
daron
« Reply #1 on: November 26, 2003, 04:19:11 PM »
that is cool. I see you have yet to make a few dll files. You have a smiley on a toolbar in the upper right.
« Reply #2 on: November 26, 2003, 04:30:25 PM »
Actually, that was done intentionally. I hacked the acadres.dll and substituted the "evil smiley" :twisted:  from the forum in place of the regular smiley. That way the smiley more accurately reflects the attitude of the user.
daron
« Reply #3 on: November 26, 2003, 04:45:56 PM »
Ah, I wanted to do that since the last time we had that discussion from cadalog. I couldn't figure it out. I just looked through the acadres.dll in 2004 and couldn't find the ? on a cloud. That's what they've replaced it with in this release.
« Reply #4 on: November 26, 2003, 04:52:26 PM »
I should have said that it was in acadbtn.dll
If you have reshacker you can change it, if not use something like Visual Studios.
Generally the "error" icon is the last of the bitmaps.
When I get my other system up and running I will check out the 2004 version.
K
daron
« Reply #5 on: November 26, 2003, 05:09:05 PM »
Ah, couldn't find it there either.
