Author Topic: Text and Mtext middle rectangle  (Read 13103 times)
roy_043
  • BricsCAD 18
Re: Text and Mtext middle rectangle
« Reply #15 on: September 21, 2010, 05:01:10 PM »
@ Lee Mac:
Three changes for your code:
(defun c:BxTx ( / e ll ur c ) [color=red]; variable n removed[/color]
  ;; © Lee Mac 2010
        (while
            (setq e (car (entsel "\nSelect Text or MText: ")))
            (not (wcmatch (cdr (assoc 0 (setq l (entget e)))) "*TEXT"))
          (princ "\n** Object must be Text or MText **")
        e
      (setq ll (getpoint "\nPick Lower-Left Corner: "))
      (setq ur (getpoint "\nPick Upper-Right Corner: " ll))
      (setq c  [color=red](mapcar '(lambda (a b) (/ (+ a b) 2.0)) ll ur)[/color])
    (entupd
      (cdr
        (assoc -1
          (entmod
            (if (eq "MTEXT" (cdr (assoc 0 l)))
              (SubstDXF 10 (trans c 1 0) (SubstDXF 71 5 l))
              (SubstDXF 11 (trans c 1 [color=red]e[/color]) (SubstDXF 72 1 (SubstDXF 73 2 l)))
(defun SubstDXF ( code value elist ) ;; © Lee Mac 2010
  (entmod
    (if (assoc code elist)
      (subst (cons code value) (assoc code elist) elist)
      (append elist (list (cons code value)))
« Reply #16 on: September 21, 2010, 05:02:51 PM »
Nice changes, thanks Roy  :-)
Sam
« Reply #17 on: September 22, 2010, 12:40:59 AM »
@ Lee Mac:
  ;; © Lee Mac 2010
        (while
        e
    (entupd
      (cdr
        (assoc -1
          (entmod
  (entmod
Dear Sir
error on lisp
i'm using autocad 2006
Command: ap APPLOAD BxTx.lsp successfully loaded.
Command: ; [color=red]error: malformed list on input[/color]
Command:  BXTX
Pick Upper-Right Corner: ; [color=red]error: no function definition[/color]: SUBSTDXF
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
roy_043
  • BricsCAD 18
« Reply #18 on: September 22, 2010, 02:50:01 AM »
@ Sam:
Please check if you have copied and pasted all of the code, making sure to scroll completely down in the code window.
cmwade77
« Reply #19 on: September 22, 2010, 11:18:12 AM »
Here is my version, which does what is being asked for and a bit more.
Please note that this is a routine that we have had in place for a while, but I rewrote a good portion of it yesterday to speed it up and remove some bugs, it has not been 100% tested yet, so there may still be some more bugs in it. Also, any suggestions for improvements are more than welcome. I believe I have commented all borrowed code, if you recognize code that came from another routine, please let me know so that I can give the proper credit. Also, I use Notepad++ for my editing, so the formatting is designed to look the best in it.
Edit: I changed the code to being attached, as there were problems with how it pasted.
<edit: CAB added formatted code back>
;|                           AT.LSP                              **
                          VERSION 6.0                              **
                          BY: Chris Wade                            **
                            09-21-10                              **
      - Mostly rewritten                                              **
      - Contains the following commands:                                      **
        ATM: Align To Middle                                          **
          - Aligns text to the middle of two points that the user selects, in the manner            **
            that the user specifies by selecting points.                            **
            Options:                                            **
            - After selecting an object, press N for Notes. The note will be inserted next to the line    **
              that you selected and will be based on the layer that the text is on.              **
            - Click two points that are on the X axis from each other (i.e. Horizontal):          **
            - X align   - Aligns text horizontally between the two points.                **
            - Adjusts text justification to Middle Center                  **
            - Click two points that are on the Y axis from each other (i.e. Vertical):            **
            - Y align   - Aligns text vertically between the two points                  **
            - Adjusts text justification to Middle Left                    **
            - Click two points that are not on the X or Y axis from each other (i.e. Diagonal):        **
            - XY align  - Centers the text horizontally and vertically                  **
                      between two points.                              **
            - Click on a piece of text:                                    **
            - Text    - Aligns to selected text.                            **
            - Adjusts text justification to match the text that is aligned to.        **
            - Click on a blank spot:                                    **
            - Center  - Centers text to cells in a table, will error out if no table lines are found.  **
(defun c:AT (/ flt CCC A B C D E F G H TAG vl i ent obj tmp pt prop eLst pLst poly ov)
  (setq flt '((-4 . "<OR")
          (0 . "TEXT")
          (0 . "MTEXT")
          (-4 . "<AND")
          (0 . "INSERT")
          (66 . 1)
          (-4 . "AND>")
          (-4 . "OR>")
  (setq CCC T)
  (while CCC
    (setq CCC (ssget flt))
      ((= CCC nil)
        (princ "\nYou must select text to use!")
      (T
        (initget "N _Notes")
        (setq C (getpoint "\nPick first point/<N>ote bubble: "))
          ((= C "Notes")
            ;Insert General or Reference Notes
            (setq PickPt (last (last (last (ssnamex CCC)))))
            (setq CopyText (entget (ssname CCC 0)))          ;get entity information for mtext
            (setq LS (cdr (assoc 73 CopyText))
                LS2 (assoc 73 CopyText)
                Lay (assoc 8 CopyText))
            (if (= LS 1)
                (setq CopyText (subst '(73 . 2) (assoc 73 CopyText) CopyText))
                (entmod CopyText)
            (setq InsPt (list (cadr(assoc 10 CopyText)) (caddr(assoc 10 CopyText))))  ;get mtext insertion point
            (setq Theight (cdr (assoc 40 CopyText)))          ;get mtext height
            (setq Tspacing (cdr (assoc 44 CopyText)))          ;get line spacing
            (setq NoteNum "1")
            (setq LineNumber 0)
              ((or (= (getvar "tilemode") 1) (/= (getvar "cvport") 1))
                  (SETQ ScaleFactor (GETVAR "DIMSCALE"))
                  (SETQ DistanceLeft (/ ScaleFactor 4.8))
              ((and (= (getvar "tilemode") 0) (= (getvar "cvport") 1))
                  (setq ScaleFactor 1)
              ((= (cdr Lay) "$GN")
                (setvar "clayer" "$GN")
                (NumberNow_AT "GN")
              (T
                (setvar "clayer" "$RN")
                (NumberNow_AT "RN")
          (T
            (setq D (osnap C "_ins"))
              ((or (= D nil) (= D null))
                (setq D (osnap C "_nea"))
              (T
                (SETQ A (entget (car (NENTSELP "" D))))
                (SETQ B (CDR (ASSOC 0 A)))
                  ((= B "ATTRIB")
                    (setq TAG "TL")
                  ((= B "MTEXT")
                    (setq E (cdr (assoc 71 A)))
                    (setq G (cdr (assoc 10 A)))
                      ((= E 1)
                        (setq TAG "TL")
                      ((= E 2)
                        (setq TAG "TC")
                      ((= E 3)
                        (setq TAG "TR")
                      ((= E 4)
                        (setq TAG "ML")
                      ((= E 5)
                        (setq TAG "MC")
                      ((= E 6)
                        (setq TAG "MR")
                      ((= E 7)
                        (setq TAG "BL")
                      ((= E 8)
                        (setq TAG "BC"))
                      ((= E 9)
                        (setq TAG "BR")
                  ((= B "TEXT")
                    (setq E (cdr (assoc 72 A)))
                    (setq F (cdr (assoc 73 A)))
                    (setq G (cdr (assoc 11 A)))
                      ((= F 1)
                        (setq TAG "B")
                      ((= F 2)
                        (setq TAG "M")
                      ((= F 3)
                        (setq TAG "T")
                      ((= E 0)
                        (setq TAG (strcat TAG "L"))
                      ((= E 1)
                        (setq TAG (strcat TAG "C"))
                      ((= E 2)
                        (setq TAG (strcat TAG "R"))
                ;Insert code to align text.
                (center "X" CCC G G TAG)
              ;Code to center text inside boxes adapted from Lee Mac's code at http://www.theswamp.org/index.php?topic=31289.0
                (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl))
                (mapcar 'setvar vl '(0 0))
                (setq i -1)
                (while (setq ent (ssname CCC (setq i (1+ i))))
                  (setq obj (vlax-ename->vla-object ent))
                  (if (eq "AcDbText" (vla-get-ObjectName obj))
                    (if (eq AcAlignmentLeft (vla-get-Alignment obj))
                        (setq tmp (vla-get-InsertionPoint obj))
                        (vla-put-Alignment obj acAlignmentMiddleCenter)
                        (vla-put-TextAlignmentPoint obj tmp)
                    (vla-put-AttachmentPoint obj acAttachmentPointMiddleCenter)
                  (setq pt (vlax-get obj
                    (setq prop
                      (if (eq "TEXT" (cdr (assoc 0 (entget ent))))
                        'TextAlignmentPoint 'InsertionPoint)
                  (setq eLst (entlast))
                  (vl-cmdf "_.-boundary" "_a" "_o" "_r" "_i" "_n" "" "" pt "")
                  (if (not (eq eLst (setq poly (entlast))))
                      (vla-getBoundingBox (vlax-ename->vla-object poly) 'MiP 'MaP)
                      (setq pLst (mapcar 'vlax-safearray->list (list mIP maP)))
                      (vlax-put-property obj prop
                        (vlax-3D-point
                          (polar (car pLst) (apply 'angle pLst) (/ (apply 'distance pLst) 2.))
                      (entdel poly)
                  (princ "\n ** Boundary not Found ** ")
                (mapcar 'setvar vl ov)
              (T
                ;Center text between two points
                (setq H (getpoint "\nPlease select the second of the two points to determine the middle of:  "))
                (setq x1 (rtos (car C) 2 5)
                      x2 (rtos (car H) 2 5)
                      y1 (rtos (cadr C) 2 5)
                      y2 (rtos (cadr H) 2 5))
                  ((= y1 y2)
                    (center "X" CCC C H "MC")
                  ((= x1 x2)
                    (center "Y" CCC C H "ML")
                  (T
                    (center "NO" CCC C H "MC")
(defun NumberNow_AT (xx)
    (if (= LineNumber 0)
        (setq PickDist(distance InsPt (list (car InsPt) (cadr PickPt))))    ;get distance from insertion point down to picked point
        (setq LineNumber(fix (+ 1 (/ PickDist (* Tspacing (/ Theight 0.6))))))    ;number of lines down to selected line
      ((or (= xx "GN") (= xx "RN"))
        (setq NoteNum (getstring "\nEnter Note Number: "))
    (setq DistanceDown (* Tspacing (* (- LineNumber 1) (/ Theight 0.6))))    ;set distance down from mtext insertion point to insert note
    (setq NewInsPt (list (- (car InsPt) DistanceLeft) (- (- (cadr InsPt) (/ Theight 2)) DistanceDown)))  ;combine the two into one point
    (princ "\nWorks to here!")
      ((or (= xx "GN") (= xx "ATG"))
        (vl-cmdf "-insert" "GN" "X" ScaleFactor "Y" ScaleFactor NewInsPt "0" NoteNum))  ;insert note symbol (attributes have been set to not verify) - For general notes bubble
      ((or (= xx "RN") (= xx "ATR"))
            (vl-cmdf "-insert" "RN" "X" ScaleFactor "Y" ScaleFactor NewInsPt "0" NoteNum))  ;insert note symbol (attributes have been set to not verify) - For general notes bubble
      ((= xx "AN")
        (setq Bubble (ssget "_C" C C)
            Bubble (ssname Bubble 0))
        (setq CopyBubble (entget Bubble)); Entity information for bubble
        (setq att (entget (car (nentselp "" (cdr (assoc 10 CopyBubble))))))
        (setq CopyBubble (subst (cons 10 NewInsPt) (assoc 10 CopyBubble) CopyBubble))
        (setq att (subst (cons 11 NewInsPt) (assoc 11 att) att))
        (entmod att)
        (entmod CopyBubble)
      ((/= xx "AN")
        (setq NoteNumSave (+ (atof NoteNum) 1))            ;increment counter
        (setq NoteNum (rtos NoteNumSave 5 0))          ;set format of number
; Justifies text - Adapted from Express Tools
(defun center (xx CCC H G TAG / GG TxtList)
    (tjust12)
    (setq TxtList (tmw:ss->Objlist CCC))
    (foreach item TxtList
      (setq GG (tmw:Var->Safe (vla-get-InsertionPoint item)))
        ((= xx "X")
          (vla-put-InsertionPoint item (vlax-3d-point (list (car (mid-pt H G)) (cadr GG) (caddr GG))))
        ((= xx "Y")
          (vla-put-InsertionPoint item (vlax-3d-point (list (car GG) (cadr (mid-pt H G)) (caddr GG))))
        ((= xx "NO")
          (vla-put-InsertionPoint item (vlax-3d-point (list (car (MID-PT H G)) (cadr (mid-pt H G)) (caddr (MID-PT H G)))))
    ) ;_ foreach
(defun tjust12 ()
      (setq flag TAG)
      (acet-tjust CCC flag)
);defun c:tjust
;; Returns the middle of two points
(defun mid-pt (p1 p2)
  (polar p1 (angle p1 p2) (/ (distance p1 p2) 2.) )
(defun tmw:ss->Objlist (ss / RtnList temp1)
    (while (setq temp1 (ssname ss 0))
    (setq RtnList (cons (vlax-ename->vla-object temp1) RtnList))
    (ssdel temp1 ss)
    ) ;_ while
    RtnList
) ;_ defun
(defun tmw:Var->Safe (VariantValue /)
    (if (= (type VariantValue) 'variant)
    (safearray-value (variant-value VariantValue))
    ) ;_ if
) ;_ defun
(DEFUN DTR (X)
  (/ (* X PI) 180.0)
« Last Edit: September 24, 2010, 02:25:22 PM by CAB »
Sam
« Reply #20 on: September 24, 2010, 01:11:31 AM »
@ Sam:
dear sir
copy all code
thx solve the problem
« Reply #21 on: September 24, 2010, 10:40:02 AM »
Chris,
Do you have a wide screen large display? My 19" only display's the left 3/4 of the page.
Just curious.
cmwade77
« Reply #22 on: September 24, 2010, 12:05:26 PM »
Chris,
Just curious.
I do have a 24" widescreen as one of my displays; however, I normally edit LISP on my 19" screen......there appears to have some formatting issues when pasted into the post above, I have changed it to an attachment in my previous post.
« Reply #23 on: September 24, 2010, 02:26:27 PM »
Must be a tab setting. I removed all the tabs & posted it. 8-)
cmwade77
« Reply #24 on: September 24, 2010, 02:29:12 PM »
Strange, oh well, as long as it works, right  :lol:
« Reply #25 on: September 24, 2010, 03:31:15 PM »
Chris,
If you are formatting code in the VLIDE, make sure this option is unchecked:
Tools > Environment Options > Visual LISP Format Options
Insert Tabs
cmwade77
« Reply #26 on: September 24, 2010, 06:21:28 PM »
Chris,
Insert Tabs
No, as specified, I use Notedpad++ and this is the first time that I have found it to be a major problem with formatting, not quite sure why.
roy_043
  • BricsCAD 18
« Reply #27 on: September 25, 2010, 09:27:11 AM »
Lee Mac is probably right: this is caused by the use of tabs, instead of spaces, for indentation.
To change this in Notepad++:
Settings > Preferences > Language Menu/Tab Settings > Check the "Replace by space" option
roy_043
  • BricsCAD 18
« Reply #28 on: September 26, 2010, 01:29:26 PM »
Here's one that will move the text to the same OCS as the rectangle and rotate it to line up with one of its sides.
Just for practice...
(defun c:InRec2 ( / n:StopWithMessage polyEnt polyEntLst polySel ptLst ptMid ptSel txtEnt txtEntLst)
  (defun n:StopWithMessage (message)
    (princ message)
    nil
      (setq txtEnt (car (entsel "\nSelect text: ")))
      (or
        (wcmatch (cdr (assoc 0 (setq txtEntLst (entget txtEnt)))) "*TEXT")
        (n:StopWithMessage "\nError: this is not a text ")
      (setq polySel (entsel "\nSelect left part of top or bottom of rectangle (lwpolyline): "))
      (or
        (= (cdr (assoc 0 (setq polyEntLst (entget (setq polyEnt (car polySel)))))) "LWPOLYLINE")
        (n:StopWithMessage "\nError: this is not a lwpolyline ")
      (or
        (= (length (setq ptLst (apply 'append (mapcar '(lambda (a) (if (= (car a) 10) (list (cdr a)))) polyEntLst)))) 4)
        (n:StopWithMessage "\nError: the number of vertices does not equal 4 ")
      (setq
        ptSel
          (trans
            (vlax-curve-getclosestpointto
              (vlax-ename->vla-object polyEnt)
              (trans (osnap (cadr polySel) "_nea") 1 0)
            0
            polyEnt
          ) ; ptSel in OCS poly
        ptMid (append (kg:MidPoint (car ptLst) (caddr ptLst)) (list (cdr (assoc 38 polyEntLst)))) ; ptMid in OCS poly
        ptLst (cons (last ptLst) ptLst)
      ;; find the vertices ptSel is between and sort these points so that the point furthest from ptSel is the first in the list:
      (while
          (cadr ptLst)
          (not (equal (angle (car ptLst) ptSel) (angle ptSel (cadr ptLst)) 1e-8))
        (setq ptLst (cdr ptLst))
      (setq ptLst (vl-sort (list (car ptLst) (cadr ptLst)) '(lambda (a b) (> (distance a ptSel) (distance b ptSel)))))
      ;; modify the text:
      (if (= (cdr (assoc 0 txtEntLst)) "TEXT")
        (entmod
          (kg:ListSubstOrAppendAssocCar
            (list
              (cons 10 ptMid) ; this is just for the z-coord (in OCS)
              (cons 11 ptMid) ; this will determine the insertion point (in OCS)
              (cons 50 (angle ptSel (car ptLst)))
              '(72 . 1)
              '(73 . 2)
              (assoc 210 polyEntLst)
            txtEntLst
        (entmod
            (list
              (cons 10 (trans ptMid polyEnt 0))
              '(71 . 5)
            txtEntLst
(defun kg:MidPoint (pt1 pt2)
  (mapcar '(lambda (a b) (/ (+ a b) 2.0)) pt1 pt2)
(defun kg:ListSubstOrAppendAssocCar (itemsLst lst / tmp)
  (foreach item itemsLst
    (if (setq tmp (assoc (car item) lst))
      (setq lst (subst item tmp lst))
      (setq lst (append lst (list item)))
(princ "\nUsage: InRec2 ")
« Last Edit: September 27, 2010, 03:43:54 AM by roy_043 »
Hugo
« Reply #29 on: September 27, 2010, 12:38:08 AM »
@roy_043
Get this message
Select text:
Select left part of top or bottom of rectangle (lwpolyline): ; Fehler: no
function definition: KG:MIDPOINT
Bekomme diese Meldung
