Setenv works fine but can only handle strings. Using vl-registry-read and vl-registry-write you can also write numbers and you have more control over the registry structure.Of course if your apps only have to communicate within the same drawing you can just set a global variable. If you want them to communicate between drawings but in the same Acad session you can use vl-bb-ref and vl-bb-set.
