Author Topic: set or get variables in register  (Read 3303 times)
dussla
« on: September 11, 2010, 12:55:05 AM »
hi
firends
i excute   2 cad app  in common.
i would like to save first cad app variable .
and i would like to use  that variable in second cad app.
so i use register
how can i do that ?
good day , good luck   all friends
danallen
Re: set or get variables in register
« Reply #1 on: September 11, 2010, 01:11:01 AM »
try this, it does save in registry:
Command: (setenv "yourvar" "test")
"test"
Command: (getenv "yourvar")
"test"
roy_043
  • BricsCAD 18
« Reply #2 on: September 11, 2010, 05:12:57 AM »
Setenv works fine but can only handle strings. Using vl-registry-read and vl-registry-write you can also write numbers and you have more control over the registry structure.
Of course if your apps only have to communicate within the same drawing you can just set a global variable. If you want them to communicate between drawings but in the same Acad session you can use vl-bb-ref and vl-bb-set.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: September 11, 2010, 07:42:55 AM »
I use this http://www.theswamp.org/index.php?topic=28286.0 I hate the registry  :-)
TimSpangler
  • CAD Naked!!
« Reply #4 on: September 11, 2010, 07:56:21 PM »
There are functions to handle the conversion.  Don't think of this as a deterrent   ;-)
ACA 2015 - Windows 7 Pro
dussla
« Reply #5 on: September 12, 2010, 02:30:02 AM »
thank you good answer~
