Author Topic: Get Parent Folder Name  (Read 2770 times)
Jeff H
« on: September 07, 2010, 05:18:23 PM »
I have done this before but cannot remember how I did it
I thought I did with a method from the Path class but I can find it. I looked in the DirectoryInfo but it will do it for active file. I am passing in a string.
Ex:
C:\BlahBlah\YadaYadaYada\Swamp\ThisIsTheOneWant\File.dwg
How can I extract just "ThisIsTheOneWant" by passing in an string
I thought there was method for that or do I need to do Split with "\" as the delimiter or some other way?
Is asking for Parent Folder the correct terminology?
The parent folder being the folder the file is contained in.
LE3
Re: Get Parent Folder Name
« Reply #1 on: September 07, 2010, 05:54:27 PM »
have not needed, but looks like Directory class has a GetParent method
maybe?
« Reply #2 on: September 07, 2010, 06:06:14 PM »
Look like you can do something like
new FileInfo( <YourPath> ).Directory.Name
Jeff H
« Reply #3 on: September 07, 2010, 06:25:25 PM »
Thanks le & T.Willey this is the only one I could get to work so far
                string groupName;
                FileInfo groupN = new FileInfo(lvi.ImageKey.ToUpper());
                groupName = groupN.Directory.Name.ToString();
It seems what le posted should work but for some reason it gives me the full path. It might be in the context I am using it why it does not.
« Reply #4 on: September 07, 2010, 06:28:14 PM »
No need to convert it to a string, as the Name property returns a string.  You shouldn't need to change the path to upper case either.  Have you had it error before?
Glad you got it working.  You're welcome.
« Reply #5 on: September 07, 2010, 06:38:00 PM »
This worked for me.
MessageBox.Show( new FileInfo( path ).Directory.Name );
LE3
« Reply #6 on: September 07, 2010, 06:41:47 PM »
Just tried and works:
string fileName = @"C:\LicenseServer\install\web.config";
string sdir = Directory.GetParent(fileName).Name;
returns: "install"
MickD
« Reply #7 on: September 07, 2010, 06:43:58 PM »
here's a rough one I used to get me out of trouble in the past ... just for reference
//get the current drgs' containing folder:
string folderpath = doc.Name;
int lastslash = folderpath.LastIndexOf("\\") + 1;
folderpath = folderpath.Remove(lastslash,folderpath.Length - lastslash);
- John Carmack
- J.R.R. Tolkien
Jeff H
« Reply #8 on: September 07, 2010, 07:09:18 PM »
Let me requote that to
For some reason if I do it wrong and leave off the .Name it gives me the full path. If I do it right like le posted it works perfectly
Sorry about that and thanks again le
Jeff H
« Reply #9 on: September 07, 2010, 07:20:07 PM »
No because I am saving the file name as the image key for a ListVew control so when I double click it I can use the image key to open the database and with the code posted I am using it for setting the group name.
And T.Willey thanks for calling out the redundant ToString
It is the beginning of Standard Detail Library Manager
« Last Edit: September 07, 2010, 07:24:25 PM by fro2001 »
