Author Topic: Document collection items.  (Read 6099 times)
BillZndl
« on: September 07, 2010, 10:44:00 AM »
If I want the active document and it's database:
DocumentCollection docCol = AcadApp.DocumentManager;
Document doc = docCol.MdiActiveDocument;
Database db = doc.Database;
Q: How I can get the database from a different document in the docCol that is not the active document?
I've searched quite a bit without success.
Re: Document collection items.
« Reply #1 on: September 07, 2010, 11:20:38 AM »
The same way.  The only thing that matters is how you find out which document you want the database from.  You could step through the collection with a foreach, and then when you find the one you want, you just grab the database.  You might be able to grab it from the item number, but I'm not sure if that way works.
foreach ( Document doc in docCol ) {
    if ( doc.Name == searchName )
BillZndl
« Reply #2 on: September 07, 2010, 11:23:18 AM »
I thought about doing it that way in the mean time.
Didn't know if it was the only or best way but I'll give it a shot!
Thanks Tim.
« Reply #3 on: September 07, 2010, 11:34:16 AM »
You're welcome Bill.
You might be able to do something like
docCol[1].Database
But I'm not sure, as I've only done it the way I've shown already.
BillZndl
« Reply #4 on: September 07, 2010, 02:31:23 PM »
Iterating works fine as I have know what filename I'm using.
Did you ever figure out how to update the destination drawing so the wblockcloned entities show up immediately?
« Reply #5 on: September 07, 2010, 02:52:43 PM »
If you're talking about this one
http://www.theswamp.org/index.php?topic=33321.0;all  - Copy block definitions - Beta testing
Then no.  I haven't worked on that one in awhile.  If not that one, then I don't think I remember the code, and that means most likely not.   :-)
BillZndl
« Reply #6 on: September 07, 2010, 03:18:38 PM »
Might've been, about the same date.
I saw it here:
 http://forums.autodesk.com/t5/NET/Updating-blocks-in-open-non-current-drawing/m-p/2678788#M19093
I still have a long way to go on this project.
I'm trying to copy a group from one drawing to another.
Like copyclip as block, except a group instead.
Am I re inventing the wheel?
« Reply #7 on: September 07, 2010, 03:43:18 PM »
I think those two are about the same code, so I would say no I haven't found a solution.  Sorry Bill.  Wish I could help more with that.
I would say yes.  I guess I would ask, is what's given not able to do what you want?  If not, then proceed.  I would think that you could do what you want.
BillZndl
« Reply #8 on: September 07, 2010, 03:54:25 PM »
Alrighty then, full speed ahead.  :-)
Oh, can you tell me what's the best way to identify the new entities after I wblockclone them over to the non active drawing.
I don't think that the IDMap variable works in that drawing.
try
  Database DestData = GetDestinationDB(path, docCol);
  Document DestDoc = GetDestinationDoc(path, docCol);
  if (DestDoc != null && DestDoc.Name.Equals(path))
                   using (DestDoc.LockDocument())
                         using (Transaction twb = DestData.TransactionManager.StartTransaction())
                                IdMapping IDMap = new IdMapping();
                                IDMap = database.WblockCloneObjects(new ObjectIdCollection(EntIds), DestData.CurrentSpaceId, DuplicateRecordCloning.Replace, false);
                                twb.Commit();
                                editor.WriteMessage("\nTransaction complete.");
                                        else
                                            MessageBox.Show("Filename chosen is not open in drawing editor.");
« Last Edit: September 07, 2010, 03:58:52 PM by BillZndl »
« Reply #9 on: September 07, 2010, 04:02:50 PM »
The function itself returns null or void, so the mapping you would use is the one you supply.
From the Managed Arx Docs
public unsafe void WblockCloneObjects(
    ObjectIdCollection identifiers,
    ObjectId id,
    IdMapping mapping,
    Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning cloning,
    [MarshalAs(UnmanagedType.U1)] bool deferTranslation
mapping is filled with IdPair objects that contain the objectId entities of the original and cloned object pairs. This array can be used for post-processing the objects involved in the deepClone operation.
In your call you are not supplying the idmap correctly.  Your call should look like
database.WblockCloneObjects(new ObjectIdCollection(EntIds), DestData.CurrentSpaceId, IDMap, DuplicateRecordCloning.Replace, false);
BillZndl
« Reply #10 on: September 07, 2010, 04:12:49 PM »
Not in net 2.0
Kinda weird but that's what I'm stuck with because of the windows versions here.
I'll have to play with this some more and see what will go.
Thanks again!
« Reply #11 on: September 07, 2010, 04:18:13 PM »
I don't think the Windows .Net version matters that much since it is a Acad call.  I didn't look through my code though to see how I did it, but that is from the '09 help, so maybe in another version of Acad it is a different call.  Weird.
Edit:  I see in '06 it does return an IdMapping.  So then, I think, it is like an associate list in lisp, where the first item is the old ObjectId and the second item is the new Id.  But then again I have never used an IdMapping object.
« Last Edit: September 07, 2010, 04:25:50 PM by T.Willey »
BillZndl
« Reply #12 on: September 07, 2010, 04:46:41 PM »
Ya, all I know is that when I went to net3.5 in WinXP it worked for me but when I tried to load net3.5 on the win2000 machines, it was a no go.
BillZndl
« Reply #13 on: September 09, 2010, 08:50:51 AM »
FWIW:
I used this to make the WblockClone entities to "appear".
I set the drawing to MDIActive before I processed the oids.
foreach (ObjectId id in Module.GrpInfoLst)  //Module is arraylist containing object ids from the IMap pairs.
   Entity en = trans.GetObject(id, OpenMode.ForWrite) as Entity;
      if (en != null)
          en.RecordGraphicsModified(true);
    trans.TransactionManager.QueueForGraphicsFlush();
    trans.Commit();
« Reply #14 on: September 09, 2010, 11:30:34 AM »
I think I tried that, now that you mention it, but I didn't like it switching back and forth, so I didn't go that route.  I think Tony said that it was an oversight, as to make item appear like that in Arx you can change the current document, without switching it to the active document, but it isn't exposed to .Net, so if you want to P/Invoke I think you can get it without switching the active document.
Thanks for posting your solution Bill.
