Author Topic: .bak files, plot.logs, .err logs  (Read 4375 times)
« on: September 06, 2010, 04:54:56 PM »
A few quick questions if I may   :-)
( 1 )
Goal:
Turn off creation of .bak files programmatically.
Research:
ISAVEBAK System Variable - stored in registry also (but where?)
Is this the best way to do this?
( 2 )
Goal:
Turn off creation of plot.log files programmatically.
Research:
(command "_.-plotstamp" "_Log" "_OFF" "" "")
Is there no System/Environmental Variable for this? Is there a better way to approach this?
( 3 )
Goal:
Turn off creation of .err files (error logs) programmatically.
Research:
Found REPORTERROR - but does this stop the .err files also?
Searched Swamp LISP section - not too much that is relevant, Google didn't give me too much either.
Many thanks for your interest,
Lee
roy_043
  • BricsCAD 18
Re: .bak files, plot.logs, .err logs
« Reply #1 on: September 06, 2010, 05:27:10 PM »
( 2 )
Goal:
Research:
http://www.theswamp.org/index.php?topic=27798.msg333739#msg333739
« Reply #2 on: September 06, 2010, 05:42:46 PM »
( 2 )
Goal:
Research:
Superb Roy, appreciated indeed.  :-)
« Reply #3 on: September 06, 2010, 06:10:14 PM »
( 2 )
Goal:
Research:
Re: AutomaticPlotLog property
Quote from: AutoCAD Help
This property is equivalent to the AutoCAD Options dialog box setting "Automatically Save Plot and Publish Log."
Is this the same as the individual plot.log text files that are created in the working directory? Or is this referring to the Plot and Publish CSV file?
BTW: this is for ACAD2004-7
VovKa
  • Ukraine
« Reply #4 on: September 07, 2010, 03:50:52 AM »
(vl-registry-read (strcat "HKEY_CURRENT_USER\\"
  (vlax-product-key)
  "\\Profiles\\"
  (getvar "CPROFILE")
  "\\General Configuration\\"
  "IsaveBackupDwg"
« Reply #5 on: September 07, 2010, 04:12:10 AM »
Ahhh... General Configuration - I spent all my time trawling through General...  :oops:
So, for concision, perhaps something like this?
(getenv "IsaveBackupDwg")
roy_043
  • BricsCAD 18
« Reply #6 on: September 07, 2010, 04:18:53 AM »
Bricscad doesn't create plot log files, so I can't help you with that one. I was just repeating a link that I remembered seeing on a different forum. It seemed to fit the bill...
« Reply #7 on: September 07, 2010, 04:21:00 AM »
Ok, thanks anyway Roy, I'd never use vla-get-output before and I love learning a new one  :-)
