hello freind
good day , good luck
still i am lisp beginner , sorry my lazy
can i help you pls ?
1. i have many blocks in dwg
ex)
block name per
apple 350 objects
bird 200 objects
if i select all block ,
1. make block name layer
2. send same name block to same name layer
can you understand ?
2. i would like to select objects that object elevation is above 1 mm
thank you for great help always
