Author Topic: Variable Picture  (Read 7762 times)
MichaelJ
Variable Picture
« on: September 01, 2010, 12:20:21 PM »
Hello,
I have created a new Dialog with a picture. The Name of the Picture ist 100. I have make a Link with the Picturelist.
My Lisp-Routines make with every saving a new Picture with the same name.
I want to have a Update from the picture in my Dialog. But I don’t happened…
The Dialogs shows always the first picture.
My code in my LSP is :
(defun c:AuftragsdatenX_Dialog1_OnInitialize (/)
(dcl_Control_SetPicture AuftragsdatenX_Dialog1_ 100)
Is this Functionality possible ? Have anybody a idea?
Michael
Andrea
Re: Variable Picture
« Reply #1 on: September 02, 2010, 12:09:48 PM »
Hello,
Michael
Hi Michael,
didn't tested with OpenDCL...
but this work with ObjectDCL.
(Odcl_Control_SetPicture project_Dialog_Control 100)
but I think the problem is that you have written the wrong variable name.
Keep smile...
MichaelJ
« Reply #2 on: September 02, 2010, 01:12:24 PM »
Hey,
The command "Odcl_Control_SetPicture " doesnt exist in openDCL. The name of the variables is correct - i have checked it... :-(
It must be exist  a solution for this problem
Michael
« Reply #3 on: September 02, 2010, 07:11:14 PM »
Michael, your syntax appears to be correct.
Can you clarify what you are trying to do.
Is it
Change the Picture in the Control
or
Replace the Picture in the List ?
Can you post an example Dialog and Lisp Control code ?
« Reply #4 on: September 02, 2010, 07:14:02 PM »
Have you posted as AutoKAD on the OpenDCL Forums ?
MichaelJ
« Reply #5 on: September 03, 2010, 07:51:22 AM »
I have created a new Dialog with a picture and the name in OpenDCL is “TEST01_Dialog1_”
Then I have make a setting to the picture. I have select Number 100 of the Picturelist in OpenDCL. The Name of the Picture is “Picture.jpg”.
This File is changing every time. My Mainprogram make with every saving a new “Picture.jpg”.
The problem is, that the Dialog shows only the “first” “Picture.jpg”. It must be a update from the picture and must be show the newest “picture.jpg”.
If you want to simulate you must change the picture manuel, with the same name.
I hope you can understand me…
I don’t posting with the name “AutoKAD”.
Michael
« Reply #6 on: September 03, 2010, 08:10:29 AM »
It is doing what you told it to do ... loading < PictureID 100 > ... and works fine for me,
The stored images do not have neames , they have ID numbers. I've wanted this to be changed for years, but that's another story ... and we work with what we have :)
So, if you want to display a file you need to tell the dialog to do that.
I'll have a play shortly if you like.
« Reply #7 on: September 03, 2010, 08:32:03 AM »
Have a play with this ..
(command "OPENDCL")
(defun c:Test01 (/) (dcl_project_load "Test01" t) (dcl_form_show Test01_Dialog1))
(defun c:TEST01_Dialog1_OnInitialize (/)
  ;; Display the built in Picture
  (dcl_Control_SetPicture TEST01_Dialog1_piccy 100 )
(defun c:TEST01_Dialog1_Button1_OnClicked (/)
  (dcl_PictureBox_LoadPictureFile TEST01_Dialog1_piccy "Picture1.jpg" nil)
(defun c:TEST01_Dialog1_Button2_OnClicked (/)
   (dcl_PictureBox_LoadPictureFile TEST01_Dialog1_piccy "Surprise.jpg" nil)
« Reply #8 on: September 03, 2010, 08:39:17 AM »
This is what it looks like my end.
The video is a little messy..
[BTW] Have you been here ?? http://www.opendcl.com/forum/index.php
« Last Edit: September 03, 2010, 08:48:58 AM by Kerry »
« Reply #9 on: September 06, 2010, 05:59:10 AM »
hello !! ... anyone there ??
jbuzbee
« Reply #10 on: September 07, 2010, 09:11:59 AM »
I think he wants to dynamically update the picture loaded in the odcl file at runtime - which I understand can't be done.  The only solution is to set up a folder and save jpegs there to load into the picture control.
OP: am I close?
James Buzbee
Windows 8
