« on: August 31, 2010, 11:19:24 PM »
This is one of the reasons why Supporting the Swamp is worthwhile
Stand Alone Support
For $65 per incident, you can ask technical questions about installation, configuration, printing and plotting, troubleshooting, and customization using VBA or LISP/Visual LISP™ for the current release and two previous major releases of the following products:
AutoCAD
AutoCAD Architecture / Autodesk Architectural Desktop
AutoCAD Civil 3D / Autodesk Civil 3D
AutoCAD Electrical
AutoCAD Land Desktop / Autodesk Land Desktop
AutoCAD LT
AutoCAD Map 3D / Autodesk Map 3D
AutoCAD Mechanical
AutoCAD MEP / Autodesk Building Systems
AutoCAD Raster Design / Autodesk Raster Design
Autodesk Civil 3D – Land Desktop Companion
Autodesk Impression
Autodesk Inventor Professional
Autodesk Inventor Suite / Autodesk Inventor Series
Autodesk VIZ
Revit Architecture / Autodesk Revit Building
Revit MEP / Autodesk Revit Systems
Revit Structure / Autodesk Revit Structure
Autodesk Safety Net Support does not provide support for third-party software, operating systems support, customization using Visual Basic or Visual C++, or support for device drivers not supplied with Autodesk products.
Donating a couple of dollars a month to theSwamp is WAY more economical than
some of the alternatives.
... and this place is usually lots more fun
« Last Edit: September 10, 2010, 10:41:02 PM by Kerry »
Logged
