Author Topic: Custom Snippets  (Read 4965 times)
Bryco
Re: Custom Snippets
« Reply #15 on: August 25, 2010, 09:15:17 AM »
Thanks Kerry.
Using your system I could probably add them all anyway.
It's  a good system.
I don't use a template for a new class/namespace but a snippet should be fine for that, is there a standard naming convention for the namespace and then the class? Let's say I wanted to start something called ThreeD.
Re: Custom Snippets
« Reply #16 on: August 25, 2010, 04:30:56 PM »
.. is there a standard naming convention for the namespace and then the class?
Both names can be determined whimsically.
Bryco
Re: Custom Snippets
« Reply #17 on: August 25, 2010, 08:54:10 PM »
Lol, for me that's carry on as usual.
Re: Custom Snippets
« Reply #18 on: August 25, 2010, 09:59:26 PM »
I've just started moving all of my code into seperate projects that can be added to any application .. this is something I was not doing yet .. I'll have to start!
