Author Topic: Custom Snippets  (Read 5000 times)
Jeff H
Custom Snippets
« on: August 24, 2010, 02:13:17 AM »
This is a quick example and is very easy and fast to set up. I just started setting up some templates  if anyone wants me to post them
This one does not have the reference and Namespace tags for inserting the using statements
When you insert it you type the command method name and it changes the method name and the ent type is a object so you get intellisense  I am sure you all
have used snippets
So if I in visual studo all have to do is right click insert Snippet Type Psr and press Tab twice and get
[CommandMethod("cv")]
        public static void cv()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect Viewport");
            peo.SetRejectMessage("\nNot a Viewport");
            peo.AddAllowedClass(typeof(Viewport), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
This is the snippet XML snippet
<?xml version="1.0" encoding="utf-8"?>
<CodeSnippets xmlns="http://schemas.microsoft.com/VisualStudio/2008/CodeSnippet">
  <CodeSnippet Format="1.0.0">
    <Header>
      <Title>Get Current BlockTable</Title>
      <Description>Add Code To get bt</Description>
      <Shortcut>Per</Shortcut>
    </Header>
    <Snippet>
      <Declarations>
        <Literal>
          <ID>CN</ID>
          <ToolTip>Replace with CommandName</ToolTip>
          <Default>CommandName</Default>
        </Literal>
        <Object>
          <ID>ENT</ID>
          <Type>Autodesk.AutoCAD.DatabaseServices.Entity</Type>
          <ToolTip>Replace with a connection object in your application.</ToolTip>
          <Default>dcConnection</Default>
        </Object>
      </Declarations>
        <Code Language="CSharp">
                <![CDATA[
         [CommandMethod("$CN$")]
        public static void $CN$()
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect $ENT$");
            peo.AddAllowedClass(typeof($ENT$), true);
                return;
      </Code>
    </Snippet>
  </CodeSnippet>
</CodeSnippets>
But I thought maybe some of you would want them to set them how you like
Re: Custom Snippets
« Reply #1 on: August 24, 2010, 03:59:23 AM »
Re: Custom Snippets
« Reply #2 on: August 24, 2010, 04:21:25 AM »
Declare AutoCAD Document,Editor,DataBase
Shortcut : kacDed   .. and Tab twice
Re: Custom Snippets
« Reply #3 on: August 24, 2010, 04:24:30 AM »
Write a message to CommandLine
Shortcut : kacMsg .. and Tab twice
Re: Custom Snippets
« Reply #4 on: August 24, 2010, 04:31:41 AM »
Prompts for entity selection and test
kacGetEntity_Test : tab twice
Re: Custom Snippets
« Reply #5 on: August 24, 2010, 04:38:03 AM »
I keep my snippets here :
C:\Users\ .... \Documents\Visual Studio 2010\Code Snippets\AutoCAD\kacDeclare Doc_Ed_Db.snippet
so Visual Studio can find them.
The reason I prefix snippets is to allow automatic listing by intellisence ..
eg type kac and all snippets prefixed with kac are listed
and the resulting code snip inserted
piccys :
« Last Edit: August 24, 2010, 04:46:57 AM by Kerry »
Jeff H
Re: Custom Snippets
« Reply #6 on: August 24, 2010, 04:48:21 AM »
I believe your setup is way better
Re: Custom Snippets
« Reply #7 on: August 24, 2010, 04:53:38 AM »
not better perhaps :) ...
uses the same snippets.
this is the XML for the WriteMessage
<CodeSnippets xmlns="http://schemas.microsoft.com/VisualStudio/2005/CodeSnippet">
    <Header>
      <SnippetTypes>
        <SnippetType>Expansion</SnippetType>
      </SnippetTypes>
      <Title>Write a message to CommandLine</Title>
      <Shortcut>kacMsg</Shortcut>
      <Description>Write a message to CommandLine</Description>
      <Author>KerryBrown</Author>
    </Header>
    <Snippet>
      <Declarations>
        <Literal Editable="true">
          <ID>editor</ID>
          <ToolTip>AcadApp.DocumentManager.MdiActiveDocument.Editor</ToolTip>
          <Default>ed</Default>
          <Function></Function>
        </Literal>
          <ID>message</ID>
          <ToolTip>Message string written to Command Line</ToolTip>
          <Default>message_stuff</Default>
        </Literal>
      </Declarations>
      <Code Language="csharp"><![CDATA[$editor$.WriteMessage("\n$message$");$end$]]></Code>
    </Snippet>
  </CodeSnippet>
</CodeSnippets>
Thankfully the snippet XML does not need to be hand coded :-D
Re: Custom Snippets
« Reply #8 on: August 24, 2010, 06:03:45 AM »
Creating and Using IntelliSense Code Snippets
http://msdn.microsoft.com/en-us/library/ms165392(v=VS.100).aspx
Snippet Designer Docs
http://snippetdesigner.codeplex.com/documentation
How Do I: Use Code Snippets in the Visual Studio IDE?  (video)
http://msdn.microsoft.com/en-us/vstudio/ee625748.aspx
Bryco
Re: Custom Snippets
« Reply #9 on: August 24, 2010, 10:14:38 AM »
Since I use Line line=tr.getObject(  and Crcle circle=, I was trying to figure out how to do this in a  getobject snippet, but failed.
<![CDATA[$Type$ $ObjVarName$ = tr.GetObject($ObjectIdToOpen$, OpenMode$OpenMode$) as $Type$;$end$]]>
where $ObjVarName$ would =lowercase  $Type$
Re: Custom Snippets
« Reply #10 on: August 24, 2010, 08:42:34 PM »
Bryce,
I don't recall seeing anything that would allow that sort of dynamic default.
I'll have a look tonight.
Re: Custom Snippets
« Reply #11 on: August 24, 2010, 08:53:03 PM »
For anyone following along, this is the type of snippet Bryco was referring to ... without the dynamic VarName option.
attached:
Jeff H
Re: Custom Snippets
« Reply #12 on: August 24, 2010, 08:54:38 PM »
Is that available in VS2008
Re: Custom Snippets
« Reply #13 on: August 24, 2010, 08:57:36 PM »
Yes, appears so.
http://snippetdesigner.codeplex.com/releases/view/43862
.. not sure if the 2008 version has been updated though.
Re: Custom Snippets
« Reply #14 on: August 24, 2010, 10:49:12 PM »
< snip >
Had a look over lunchtime Bryce.
I can't see any way to do that sort of dynamic assignment.
The Function Element is very restricted.
though, the current snippet only requires changes to 2 variables, so it's not too bad as is.
