Author Topic: Draw In PaperSpace Send to Xref  (Read 6407 times)
« on: August 22, 2010, 01:23:14 AM »
I am able to get the objects to show up in the xref drawing but they do not persist to the actual file. So if I detach the xref and attach it or open the actual file the objects are not there. To add the objects to the xref I was adding the transformed objects to the BlockTableRecord of the xref.
The code was getting pretty ugly from testing different ways so I cleaned it back up to sending the objects just to modelspace.
Here is the code and any ideas on how to get objects to persist to the xref would be greatly appreciated
Here is a command you select a viewport  then the objects and its sends them to modelspace and erasing them from paperspace
 I thought about checking  the TILEMODE variable if modelspace was not active then if only one viewport was in the current space automatically selecting it, but there is always a viewport 2 if I add one
<CommandMethod("SendToModelSpace")> _
    Public Shared Sub SendToModelSpace()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim objIdsErase As New List(Of ObjectId)
        Dim peo As New PromptEntityOptions(vbLf & "Select viewport")
        peo.SetRejectMessage(vbLf & "Not a viewport ")
        peo.AddAllowedClass(GetType(Viewport), True)
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Exit Sub
        End If
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim vp As Viewport = tr.GetObject(per.ObjectId, OpenMode.ForRead)
            Dim PsToMsTransForm As Matrix3d = PaperToModel(vp)
            Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
            Dim btrMs As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            Dim pso As PromptSelectionOptions = New PromptSelectionOptions
            Dim psr As PromptSelectionResult = ed.GetSelection
                Return
            Else
                btrMs.UpgradeOpen()
            End If
            For Each id As ObjectId In psr.Value.GetObjectIds
                Dim psEnt As Entity = tr.GetObject(id, OpenMode.ForRead)
                objIdsErase.Add(psEnt.ObjectId)
                Dim msEnt As Entity = psEnt.Clone()
                msEnt.TransformBy(PsToMsTransForm)
                btrMs.AppendEntity(msEnt)
                tr.AddNewlyCreatedDBObject(msEnt, True)
            Next
            tr.Commit()
        End Using
            Dim btrPs As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
            For Each objId As ObjectId In btrPs
                If objIdsErase.Contains(objId) Then
                    Dim ent As Entity = objId.GetObject(OpenMode.ForWrite)
                    ent.Erase()
                End If
            Next
            tr.Commit()
        End Using
        objIdsErase.Clear()
Here’s the functions PaperToModel  and  ModelToPaper
PaperToModel  is just the inverse of ModelToPaper so you could use it either way
  Private Shared Function PaperToModel(ByVal vp As Viewport) As Matrix3d
        Dim mx As Matrix3d = ModelToPaper(vp)
        Return mx.Inverse()
    End Function
    Private Shared Function ModelToPaper(ByVal vp As Viewport) As Matrix3d
        Dim vd As Vector3d = vp.ViewDirection
        Dim vc As New Point3d(vp.ViewCenter.X, vp.ViewCenter.Y, 0)
        Dim vt As Point3d = vp.ViewTarget
        Dim cp As Point3d = vp.CenterPoint
        Dim ta As Double = -vp.TwistAngle
        Dim vh As Double = vp.ViewHeight
        Dim hgt As Double = vp.Height
        Dim wdh As Double = vp.Width
        Dim scl As Double = vh / hgt
        Dim lenLgh As Double = vp.LensLength
        Dim zAx As Vector3d = vd.GetNormal()
        Dim xAx As Vector3d = Vector3d.ZAxis.CrossProduct(vd)
        Dim yAx As Vector3d
        If Not xAx.IsZeroLength() Then
            xAx = xAx.GetNormal()
            yAx = zAx.CrossProduct(xAx)
        ElseIf zAx.Z < 0 Then
            xAx = Vector3d.XAxis * -1
            yAx = Vector3d.YAxis
            zAx = Vector3d.ZAxis * -1
        Else
        End If
        Dim pscToDcs As Matrix3d = Matrix3d.Displacement(Point3d.Origin - cp)
        pscToDcs = pscToDcs * Matrix3d.Scaling(scl, cp)
        Dim dcsToWcs As Matrix3d = Matrix3d.Displacement(vc - Point3d.Origin)
        Dim matCoords As Matrix3d = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, Point3d.Origin, xAx, _
         yAx, zAx)
        dcsToWcs = matCoords * dcsToWcs
        dcsToWcs = Matrix3d.Displacement(vt - Point3d.Origin) * dcsToWcs
        dcsToWcs = Matrix3d.Rotation(ta, zAx, vt) * dcsToWcs
        Dim perspMx As Matrix3d = Matrix3d.Identity
        If vp.PerspectiveOn Then
            Dim vs As Double = vh
            Dim aspectRatio As Double = wdh / hgt
            Dim adjustFactor As Double = 1.0 / 42.0
            Dim adjustedLensLength As Double = vs * lenLgh * Math.Sqrt(1.0 + aspectRatio * aspectRatio) * adjustFactor
            Dim eyeDistance As Double = vd.Length
            Dim lensDistance As Double = eyeDistance - adjustedLensLength
            Dim ed As Double = eyeDistance
            Dim aLenLgth As Double = adjustedLensLength
            Dim ld As Double = lensDistance
            Dim data As Double() = New Double() {1, 0, 0, 0, 0, 1, _
             0, 0, 0, 0, (aLenLgth - ld) / aLenLgth, ld * (ed - aLenLgth) / aLenLgth, _
             0, 0, -1.0 / aLenLgth, ed / aLenLgth}
            perspMx = New Matrix3d(data)
        End If
        Dim resultMx As Matrix3d = pscToDcs.Inverse() * perspMx * dcsToWcs.Inverse()
        Return resultMx
    End Function
Re: Draw In PaperSpace Send to Xref
« Reply #1 on: August 22, 2010, 07:05:10 AM »
I am working on my C# so here it is.
Please give me any suggetions. The reason I am starting C# is I feel for some reasons C# seems eaiser to see how the classes relate and to look at it and be able to visualize the way the code works. I did this Line by Line from the Vb so the layout might be different to what your use to.
using System;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD;
using Autodesk.AutoCAD.Windows;
using System.IO;
namespace HpadCadExamplesCS
    public class HpadExamplesCS
        [CommandMethod("SendToModelSpace")]
        public static void SendToModelSpace()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            List<ObjectId> objectsIdsErase= new List<ObjectId>();
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect Viewport");
            peo.SetRejectMessage("\nNot a Viewport");
            peo.AddAllowedClass(typeof (Viewport),true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
                Viewport vp = (Viewport)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                Matrix3d PsToMsTransForm = PaperToModel(vp);
                BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
                BlockTableRecord btrMs = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                PromptSelectionOptions pso = new PromptSelectionOptions();
                PromptSelectionResult psr = ed.GetSelection();
                if (psr.Status != PromptStatus.OK)
                    return;
                else
                    btrMs.UpgradeOpen();
                foreach (ObjectId id in psr.Value.GetObjectIds())
                    Entity psEnt = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    objectsIdsErase.Add(psEnt.ObjectId);
                    Entity msEnt = (Entity)psEnt.Clone();
                    msEnt.TransformBy(PsToMsTransForm);
                    btrMs.AppendEntity(msEnt);
                    tr.AddNewlyCreatedDBObject(msEnt, true);
                tr.Commit();
                BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                BlockTableRecord btrPaper = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.PaperSpace],(OpenMode.ForWrite));
                foreach (ObjectId id in btrPaper)
                    if (objectsIdsErase.Contains(id))
                        Entity ent = (Entity)id.GetObject(OpenMode.ForWrite);
                        ent.Erase();
                tr.Commit();
        private static Matrix3d PaperToModel(Viewport vp)
            Matrix3d mx = ModelToPaper(vp);
            return mx.Inverse();
        private static Matrix3d ModelToPaper(Viewport vp)
            Vector3d vd = vp.ViewDirection;
            Point3d vc = new Point3d(vp.ViewCenter.X, vp.ViewCenter.Y, 0);
            Point3d vt = vp.ViewTarget;
            Point3d cp = vp.CenterPoint;
            double ta = -vp.TwistAngle;
            double vh = vp.ViewHeight;
            double height = vp.Height;
            double width = vp.Width;
            double scale = vh / height;
            double lensLength = vp.LensLength;
            Vector3d zaxis = vd.GetNormal();
            Vector3d xaxis = Vector3d.ZAxis.CrossProduct(vd);
            Vector3d yaxis;
            if (!xaxis.IsZeroLength())
                xaxis = xaxis.GetNormal();
                yaxis = zaxis.CrossProduct(xaxis);
            else if (zaxis.Z < 0)
                xaxis = Vector3d.XAxis * -1;
                yaxis = Vector3d.YAxis;
                zaxis = Vector3d.ZAxis * -1;
            else
                xaxis = Vector3d.XAxis;
                zaxis = Vector3d.ZAxis;
            Matrix3d pcsToDCS = Matrix3d.Displacement(Point3d.Origin - cp);
            pcsToDCS = pcsToDCS * Matrix3d.Scaling(scale, cp);
            Matrix3d dcsToWcs = Matrix3d.Displacement(vc - Point3d.Origin);
            Matrix3d mxCoords = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, Point3d.Origin,
                xaxis, yaxis, zaxis);
            dcsToWcs = mxCoords * dcsToWcs;
            dcsToWcs = Matrix3d.Displacement(vt - Point3d.Origin) * dcsToWcs;
            dcsToWcs = Matrix3d.Rotation(ta, zaxis, vt) * dcsToWcs;
            Matrix3d perspectiveMx = Matrix3d.Identity;
            if (vp.PerspectiveOn)
                double vSize = vh;
                double aspectRatio = width / height;
                double adjustFactor = 1.0 / 42.0;
                double adjstLenLgth = vSize * lensLength * Math.Sqrt(1.0 + aspectRatio * aspectRatio) * adjustFactor;
                double iDist = vd.Length;
                double lensDist = iDist - adjstLenLgth;
                double[] dataAry = new double[] {1,0,0,0,0,1,0,0,0,0,
                    (adjstLenLgth-lensDist)/adjstLenLgth,lensDist*(iDist-adjstLenLgth)/adjstLenLgth,
                    0,0,-1.0/adjstLenLgth,iDist/adjstLenLgth};
                perspectiveMx = new Matrix3d(dataAry);
            Matrix3d finalMx = pcsToDCS.Inverse() * perspectiveMx * dcsToWcs.Inverse();
            return finalMx;
Bryco
« Reply #2 on: August 22, 2010, 01:15:53 PM »
Fro, it seems that either opening a new database or WblockCloneObjects is very sensitive as to many transactions are being used. The code below works fine but if you recomment the using you will find it doesnt.
Viewports-the first one is paperspace itself just to confuse everyone.
I presume you want to scale the entities by the vp scale, I didn't do that, but at 1to1 the below puts the objects in the right place
        [CommandMethod("TESTING")]
        public static void testany()
            if (psr.Status != PromptStatus.OK) return;
            ObjectIdCollection ids = new ObjectIdCollection(psr.Value.GetObjectIds());
            //using (Transaction tr = db.TransactionManager.StartTransaction())
            //{ if you use this transaction nothing works
                AddPaperspaceToXref(ids, "1");
        public static void AddPaperspaceToXref(ObjectIdCollection ids,string sXref)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord Xref = tr.GetObject(bt[sXref], OpenMode.ForRead) as BlockTableRecord;
                string path = Xref.PathName;
                Database dbase = new Database(false, false);
                try
                    dbase.ReadDwgFile(path, System.IO.FileShare.Read, true, "");
                catch (System.Exception ex)
                    if (ex.Message == "eFileSharingViolation")
                        MessageBox.Show("The X-ref file is open,please close it and try again.");
                        return;
                //using (Transaction trX = dbase.TransactionManager.StartTransaction())
                //{ if you use this replacing the tr below w/ trX the xref doesn't reload
                    BlockTable btx = tr.GetObject(dbase.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord xModelSpace = tr.GetObject
                        (btx[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    dbase.WblockCloneObjects(ids, xModelSpace.ObjectId,
                        new IdMapping(), DuplicateRecordCloning.Replace, false);
                    dbase.CloseInput(true);
                    dbase.SaveAs(path, DwgVersion.Current);
                    db.ReloadXrefs(new ObjectIdCollection(new ObjectId[] { Xref.ObjectId }));
                foreach (ObjectId id in ids)
                    Entity ent = tr.GetObject(id, OpenMode.ForWrite) as Entity;
                    ent.ColorIndex = 1;
                    ent.Erase();
                tr.Commit();
« Reply #3 on: August 23, 2010, 08:34:56 PM »
Hey Bryco Just wanted to let you know that you nailed it and I appreciate that.
Researching the docs I was going about it totally different and was getting nowhere with it
again Thanks
I will rearrange the code with transfromation and post later
« Reply #4 on: August 23, 2010, 10:41:23 PM »
Thanks to Bryco heres the code Let me know if you need a vb version
[CommandMethod("SendToXref")]
        public static void SendToXref()
            List<ObjectId> objectsIdsErase = new List<ObjectId>();
            peo.AddAllowedClass(typeof(Viewport), true);
                return;
                BlockTableRecord xrefBtr = (BlockTableRecord)bt["XrefTest"].GetObject(OpenMode.ForRead);
                string xPath = xrefBtr.PathName;
                    return;
                ObjectIdCollection xrefOID = new ObjectIdCollection();
                    Entity psEnt = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                    psEnt.TransformBy(PsToMsTransForm);
                    xrefOID.Add(psEnt.ObjectId);
                Database xrefDB = new Database(false, false);
                xrefDB.ReadDwgFile(xPath, System.IO.FileShare.Read, true, "");
                BlockTable btx = tr.GetObject(xrefDB.BlockTableId, OpenMode.ForRead) as BlockTable;
                xrefDB.WblockCloneObjects(xrefOID, xModelSpace.ObjectId,
                xrefDB.CloseInput(true);
                xrefDB.SaveAs(xPath, DwgVersion.Current);
                db.ReloadXrefs(new ObjectIdCollection(new ObjectId[] { xrefBtr.ObjectId }));
                tr.Commit();
                BlockTableRecord btrPaper = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.PaperSpace], (OpenMode.ForWrite));
                        ent.Erase();
                tr.Commit();
            Vector3d yaxis;
            else
                double vSize = vh;
            return finalMx;
Bryco
« Reply #5 on: August 25, 2010, 09:17:52 AM »
Thanks fro, I was hoping someone could explain the transaction problems I show as they don't make a lot of sense.
Glenn R
« Reply #6 on: August 25, 2010, 09:52:43 AM »
Bryce,
There was no trX.Commit() call in your code.
Bryco
« Reply #7 on: August 25, 2010, 11:23:21 AM »
OOPS. Thanx
Glenn R
« Reply #8 on: August 25, 2010, 11:49:25 AM »
Does that fix your transaction issues?
« Reply #9 on: August 25, 2010, 12:04:10 PM »
The first or outermost transaction musted be commited for all of the actions in nested transaction to be applied.
There are nested transaction in the   AddPaperspaceToXref method so for them to be applied
                tr.Commit();
Now they will be applied
Glenn R
« Reply #10 on: August 25, 2010, 02:24:19 PM »
Correct. I was waiting to see if someone spotted that :)
