Author Topic: Manipulating AdobeReader using Visual LISP Possible?  (Read 23440 times)
Re: Manipulating AdobeReader using Visual LISP Possible?
« Reply #60 on: August 26, 2010, 09:33:10 AM »
Vali, good point.
« Reply #61 on: August 26, 2010, 02:01:33 PM »
oh come on Lee, I was talking about the AutoLisp portion being simple...don't put words into my mouth.
Yeah sorry, that was a cheap dig.
Anyway, I tried the 'copy' method today but, unfortunately was unsuccessful. The code runs without error, but nothing seems to happen.
Here is the code I have been trying, assume that 'pdfLst' is a list of full filenames of PDF files.
(startapp "net use lpt3 /delete")
(startapp "net use lpt3 \\\\<printserver>\\<printer>")
(foreach file pdfLst
  (startapp (strcat "copy /b \"" file "\" lpt3"))
  (startapp (strcat "copy /b \"" file "\" \\\\<printserver>\\<printer>"))
  (startapp (strcat "copy /b \"" file "\" //<printserver>/<printer>"))
Each with the same result as described above.
So far the closest I have got to printing is using:
(setq adobe "C:\\Program Files\\Adobe\\Reader\\AcroRd32.exe")
  (startapp (strcat adobe " /t /h \"" file "\""))
Which actually registers the necessary files on the print queue, but only the first is sent. The first file is open for longer than the subsequent files, so perhaps these files are not open long enough for the data to be sent to the printer... but, in any case, the printer registers a timeout error and fails to print all but the first file.
Lee
« Reply #62 on: August 26, 2010, 03:53:43 PM »
The only thing i got at this point is: are you sure you have the server name and the printer share name properly spelled and used? I'm thinking that you are sending the file into never-never land.
SH stands for SHELL...Type "sh enter enter" on the acad command line to open a prompt and send a file that way once.
LE3
« Reply #63 on: August 26, 2010, 04:41:48 PM »
Here it is something I just found out, but could not make it to work:
(setq prog-id "AcroPDF.PDF.1")
(setq pdf (vlax-create-object prog-id))
(vlax-invoke-method pdf 'LoadFile "C:\\test.pdf") ;; returns :vlax-false no idea why or how to set this...
; IAcroAXDocShim: IAcroAXDocShim Interface
; Property values:
;   messageHandler = nil
;   src = ""
; Methods supported:
;   execCommand (1)
;   GetVersions ()
;   goBackwardStack ()
;   goForwardStack ()
;   gotoFirstPage ()
;   gotoLastPage ()
;   gotoNextPage ()
;   gotoPreviousPage ()
;   LoadFile (1)
;   postMessage (1)
;   Print ()
;   printAll ()
;   printAllFit (1)
;   printPages (2)
;   printPagesFit (3)
;   printWithDialog ()
;   setCurrentHighlight (4)
;   setCurrentHightlight (4)
;   setCurrentPage (1)
;   setLayoutMode (1)
;   setNamedDest (1)
;   setPageMode (1)
;   setShowScrollbars (1)
;   setShowToolbar (1)
;   setView (1)
;   setViewRect (4)
;   setViewScroll (2)
;   setZoom (1)
;   setZoomScroll (3)
T
_$
(vlax-release-object pdf)
« Reply #64 on: August 26, 2010, 04:45:23 PM »
I'll definitely check that - thanks mate.
« Reply #65 on: August 26, 2010, 04:45:59 PM »
That's interesting Luis - I'll investigate that too when I get a spare minute - thanks.  :-)
« Reply #66 on: August 26, 2010, 04:57:29 PM »
I get the same results as you Luis - unable to load a file.  :-(
LE3
« Reply #67 on: August 26, 2010, 04:59:27 PM »
well.... :-( - how about the exe, did it worked?
« Reply #68 on: August 26, 2010, 05:14:24 PM »
The .exe method was the closest I got to actually printing...
See here:
http://www.theswamp.org/index.php?topic=34551.msg398482#msg398482
LE3
« Reply #69 on: August 26, 2010, 05:17:40 PM »
nope... the one sent to you via email
« Reply #70 on: August 26, 2010, 05:45:08 PM »
Ahh - apologies, my email has since changed so I rarely check my old one, I shall have a look now and also send you my new email address.
Daniel Eiszele
« Reply #71 on: August 26, 2010, 06:35:51 PM »
Unless I'm mistaken, the following doesn't work because pdf is still nil.
because...
<snip>
Adobe Reader does not support OLE.
Same link as what i posted before.
http://livedocs.adobe.com/acrobat_sdk/9/Acrobat9_HTMLHelp/Overview_GettingStarted.3.10.html
Daniel Eiszele
« Reply #72 on: August 26, 2010, 06:52:38 PM »
@Lee: Just wondering; is there a reason you are trying to do this from code?  If you select the files you want to print in explorer then select "print" from the right click menu then everything prints without a problem (at least on my system).
LE3
« Reply #73 on: August 26, 2010, 08:36:04 PM »
Thanks!
I know and even if that is not possible, I still gave it a try... and that's why I am in the programming field -  :-)
Went the C# route and that looks better (promising) - btw - once there is a working sample will try to post it at the .net side.
because...
<snip>
Daniel Eiszele
« Reply #74 on: August 26, 2010, 09:06:05 PM »
Thanks!
Tell me about it :) I didn't want to believe it either! But, after importing the type library and banging my head against the wall for a couple of hours I just had to assume that even though it looked like all the necessary methods had been exposed, there was still something behind the scenes stopping me from creating the connection.
A bit of further reading suggests that you can use DDE to communicate with Reader.
