Author Topic: Write an Excel's cell with ADO  (Read 5358 times)
Patrick_35
« on: August 17, 2010, 09:16:46 AM »
Hi
I try to write an Excel cell with ADO, but it does not work
I am inspired by this topic (thank's ElpanovEvgeniy)
(setq fil (getfiled "Sélectionner le fichier Excel"  ""  "xls;xlsx" 0)) ;choose Exel's file
(setq adoconnect (vlax-get-or-create-object "ADODB.Connection")
      adorecord  (vlax-get-or-create-object "ADODB.Recordset")
      adocommand (vlax-get-or-create-object "ADODB.Command")
; Ouvrir le fichier Excel
; Open Excel's file
(vlax-invoke-method adoconnect 'Open
(strcat "Provider=Microsoft.Jet.OLEDB.4.0;Data Source="
fil
";Extended Properties=;Excel 8.0;HDR=No"
nil
; Liste des feuilles Excel
; Dump sheets
(mapcar '(lambda(x) (vl-string-right-trim "$" x))
(vl-remove-if-not '(lambda(x) (wcmatch x "*$"))
  (caddr (mapcar '(lambda(x) (mapcar 'vlax-variant-value x))
(vlax-safearray->list
   (vlax-variant-value
     (vlax-invoke-method
       (vlax-invoke-method adoconnect 'OpenSchema 20)
       "GetRows"
       65535
; Ouvrir la Feuille Excel
; Open sheet TD01
(vlax-invoke-method adorecord 'Open
      (strcat "SELECT * FROM [" "TD01" "]")
      adoconnect
      1
      3
      nil
; Lire la cellule A1 (fonctionne comme A1:B5 par exemple)
; Read cell A1 in sheet TD01
(vlax-invoke-method adorecord 'Open "SELECT * FROM [TD01$A1:A1]" adoconnect 1 3 nil)
(setq res (vlax-invoke adoconnect 'Execute "SELECT * FROM [TD01$A1:A1]"))
(setq tot 0)
(while (< tot (vlax-get (vlax-get res 'fields) 'Count))
  (princ (strcat "\n" (vlax-get (vlax-get-property (vlax-get res 'fields) 'item tot) 'value)))
  (setq tot (1+ tot))
; Ecrire la cellule A1 (fonctionne comme A1:B5 par exemple)
; Write cell A1 in sheet TD01
(setq cel (vlax-get-property (vlax-get res 'fields) 'item 0))
(vlax-put-property cel 'Value "Test") ; Not Work
Regards
Re: Write an Excel's cell with ADO
« Reply #1 on: August 17, 2010, 09:55:32 AM »
Also check these threads. There is a problem using Windows 7, I think.
ADO Links
Patrick_35
« Reply #2 on: August 17, 2010, 10:08:14 AM »
Thank's Cab
I'm try the search and i don't find.
I work with windows XP
Patrick_35
« Reply #3 on: August 18, 2010, 09:49:34 AM »
Yes, I find
; Connect to Excel's file with ADO
(defun Connexion_Xls(fichier / adoconnect)
  (setq adoconnect (vlax-get-or-create-object "ADODB.Connection"))
fil
nil
  adoconnect
; Dump sheets
(defun Liste_Onglets(Connexion)
     (vlax-variant-value
       (vlax-invoke-method
(vlax-invoke-method Connexion 'OpenSchema 20)
"GetRows"
65535
; Read cell
(defun Lire_cellule(Connexion Feuille Cellule / adocommand adorecord txt)
  (setq adorecord  (vlax-get-or-create-object "ADODB.Recordset")
  (vlax-put adocommand 'ActiveConnection Connexion)
  (vlax-put adocommand 'CommandText (strcat "SELECT * FROM [" Feuille "$" Cellule ":" Cellule "]"))
  (vlax-invoke-method adorecord 'Open adocommand nil 1 3 nil)
  (setq txt (vlax-get (vlax-get-property (vlax-get adorecord 'fields) 'item 0) 'Value))
  (vlax-invoke adorecord 'Close)
  (vlax-release-object adorecord)
  (vlax-release-object adocommand)
  txt
; Write cell
(defun Ecrire_Cellule(Connexion Feuille Cellule Valeur / adocommand adorecord)
  (vlax-put-property (vlax-get-property (vlax-get adorecord 'fields) 'item 0) 'Value Valeur)
  (vlax-invoke adorecord 'Update)
; Close file and ADO
(defun Fermer_Xls(Connexion)
  (vlax-invoke Connexion 'Close)
  (vlax-release-object Connexion)
; Example
(setq fil (getfiled "Sélectionner le fichier Excel"  ""  "xls;xlsx" 0)) ; search file
(setq mon_xls (connexion_xls fil)) ; connect to file
(setq lst (liste_onglets mon_xls)) ; Dump sheets
(lire_cellule mon_xls (car lst) "A1") ; read cell
(ecrire_cellule mon_xls (car lst) "A1" "GREAT ^^") ; write cell
(fermer_xls mon_xls); close file and ADO
« Reply #4 on: August 18, 2010, 01:34:06 PM »
Patrick, quick question: is the ADO method quicker than writing using the Excel.Application?
Patrick_35
« Reply #5 on: August 19, 2010, 02:28:00 AM »
Hi
Yes, using CDO method is faster than using Excel.Application fast and more and it also helps overcome Excel
It remains to find for Excel 2007 as methods change.
gile
  • Marseille, France
« Reply #6 on: August 19, 2010, 03:11:03 AM »
Have to consider that using this method, the Excel sheet is read as a database table. So, the first line may or may not be considered as a 'header' (argument HDR=Yes or HDR=No) and the the data in each column have to be the same type (interger, real, string, date, ...).
For Excel 2007, you have to use the "Microsoft.ACE.OLEDB.12.0" driver instead of "Micosoft.Jet.OLEDB.4.0" (not tested) and the .xlsx file extension.
(strcat "Provider=Microsoft.ACE.OLEDB.12.0;Data Source="
fil
nil
Patrick_35
« Reply #7 on: August 19, 2010, 04:00:20 AM »
fil
nil
Thanks gile
I find it
; Connexion sur le fichier Excel
; Retourne la connexion si tout s'est bien passé, sinon nil
; 1er argument --> Nom du fichier
; Pour ceux qui ont la version antérieur à Office 2007
; il faut que AccessDatabaseEngine.exe (25.3Mo) soit installé pour lire les fichiers xlsx
; http://www.microsoft.com/downloads/fr-fr/confirmation.aspx?familyId=7554f536-8c28-4598-9b72-ef94e038c891&displayLang=fr
(defun Connexion_Xls(fichier / adoconnect data)
  (setq adoconnect (vlax-create-object "ADODB.Connection"))
  (if (eq (strcase (vl-filename-extension fichier)) ".XLSX")
    (setq data (strcat "Provider=Microsoft.ACE.OLEDB.12.0;Data Source="
fichier
";Extended Properties='Excel 12.0;HDR=No'"
    (setq data (strcat "Provider=Microsoft.Jet.OLEDB.4.0;Data Source="
fichier
  (if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke-method (list adoconnect
  'Open
  data
  nil
    nil
    adoconnect
Now, i've an problem.
With an xlsx's file, i write only in cell "A1"
and what you recommended ?
Salut gile
J'ai trouvé la solution pour lire les fichiers xlxs, mais maintenant mon problème et que j'écris que dans la cellule A1.
Par contre, je ne comprends pas ton histoire qu'une colonne doit être d'un même type (réel, entier, etc...)
Si je lis la cellule A1 par exemple et que c'est un string, j'ai un string.
Si je lis la cellule A3 par exemple est que c'est un chiffre, j'ai un réel;
J'évite pour l'instant de lire des plages type A3:C8, car cela ne fonctionne pas correctement, il ne lit que la 1er ligne
ps : Tu as une routine pour trouver toutes les feuilles.
gile
  • Marseille, France
« Reply #8 on: August 19, 2010, 07:20:23 AM »
I was meaning that if you select more than one entry (row) each value in a column is considered as a key which have to be the same type in a database table.
If they're not, ADO wil choose one type (I don't know about which crtiteria) and return null for all datas which type is different.
Je voulais dire que si tu sélectionne plus d'une entrée (ligne) chaque valeur dans une colonne est considérée  comme une clé qui doit être du même type dans une table de base de données.
Si elles ne le sont pas, ADO choisit un type (je ne sais pas suivant quel critère) et retourne null pour toutes les valeurs quin ne sont pas de ce type. Voir ici
Patrick_35
« Reply #9 on: August 19, 2010, 08:01:58 AM »
Thank you gile
Now I have another problem.
With a xlsx file, I can not write otherwise than in cell A1
« Reply #10 on: August 19, 2010, 02:50:03 PM »
Hi
Thanks Patrick, I shall have to look into possibly using this method in the future  ;-)
