Ok, I created a corridor, but some of the slopes couldn't daylight because a lack of survey data. I need to add a boundary to the corridor using a polyline. I tried to explode the corridor and just use the outer daylight boundary, but it exploded into lines. If I could turn those lines into polylines and then join them, that would be great, but the puter won't let me. Is there a way to do this I am not thinking of.
Oh yeah, by the way, I also have some manually created 3d poly's i need to be able to join to the above.
In those areas where there is not enough survey data it is suggest that you do the following...
Import the google earth surface for your site into that file...set some points on it...include those points into the surface model (careful to place them in a GoogleEarth Points group so you know where they came from).
Rebuild the corridor- Have a Nice Day (and at some point go get the survey data)
OR
Create a feature line, right near the edge of the EG surface, and let it get elevations from EG, move it off of the surface, add it into the surface.
OR
Edit the corridor region whereing in slopes OFF the surface, asign input value overirides to make the slopes steeper and catch the surface you do have.
