Author Topic: lisp request for cnc scrap utilization  (Read 6714 times)
Re: lisp request for cnc scrap utilization
« Reply #15 on: August 11, 2010, 10:19:16 PM »
Quote from: Frankenfurter
one being cadcode,
Any idea of cost Daniel ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: August 11, 2010, 10:52:54 PM »
I don't know how accurate these are, but they ought to be close.
http://www.true32.com/CategoryProductList.jsp?cat=CADCode+Software
LE3
« Reply #17 on: August 11, 2010, 11:04:40 PM »
for the software place i was working they have stuff to do that like kitchen works, peddi-nest... or whatever but won't recommend them, since they let me go - so .... n.  :lol:  :-P
adalea03
« Reply #18 on: August 15, 2010, 01:55:31 PM »
How about a database of the parts that you do make, including all pertinent info.
Test a piece of scrap for its pertinent info.
List possible candidates from the database where required info matches the scrap piece.
Some tolerance factors may be necessary for the step above.
Bring all candidates and the scrap together, then, using Lee's suggestion you will prolly soon find ways to automate it.
Tony
