yes, just capture the user selection and parse the string returned. For example, here is how you would capture the user selection.
(defun C:BigBoard ( / userclick dlgname dcl_id big-board-list _make-dialog)
;; bigboard
(defun _make-dialog ( / fn f dcl )
(setq fn (strcat (vl-filename-directory (findfile "acad.exe"))"\\$vld$.dcl")
f (open fn "w")
dcl
"board : dialog {"
": list_box {"
"key = \"selections\";"
"multiple_select = true;"
"height = 19;"
"allow_accept = true;"
"ok_cancel;"
(mapcar
(function
(lambda ( x )
(princ x f)
(princ "\n" f)
dcl
(close f)
fn
(defun setItems (val lst / ret)
(foreach n (mapcar (function (lambda (n) (- n 48)))
(vl-remove 32 (vl-string->list val))
(setq ret (cons (nth n lst) ret))
(reverse ret)
(setq big-board-list '("Command Description"
"Co Copy"
"M Move"
"Ano Automatic Numbering"
"Dr Door"
"Ww Window"
"Acal Area Calulation")
(setq dcl_id
(load_dialog
(setq dlgname (_make-dialog))))
(if (not (new_dialog "board" dcl_id))(exit))
(start_list "selections")
(mapcar 'add_list big-board-list)
(end_list)
(action_tile "selections" "(setq strLst (setItems $value big-board-list))")
(setq userclick (start_dialog))
(unload_dialog dcl_id)
(vl-file-delete dlgname)
(and (= 1 userclick)
(and strLst (print strLst)))
