Author Topic: wcmatch mental block  (Read 6227 times)
Re: wcmatch mental block
« Reply #15 on: August 05, 2010, 03:30:32 PM »
Perhaps using Regular Expressions:
  (lambda ( string pattern / rx result )
    (setq rx (vlax-create-object "VBScript.RegExp"))
    (setq result (LM:RegExExecute rx pattern string))
    (vlax-release-object rx)
    (and result)
  "TEST4a4"  "^TEST[0-9]*$"
==> nil
(defun LM:RegExExecute ( reg pat str / l )
  ;; © Lee Mac 2010
  (mapcar
    '(lambda ( prop value ) (vlax-put-property reg prop value))
    '(pattern global ignorecase) (list pat actrue acfalse)
  (vlax-for x (vlax-invoke reg 'execute str)
    (setq l (cons (list (vlax-get x 'value) (vlax-get x 'firstindex)) l))
  l
Not sure if the pattern is verbose however, as I haven't played around with RegEx enough...
« Reply #16 on: August 05, 2010, 03:54:52 PM »
Easy to remedy: Just add another filter to the list: "~*#[~0-9]#*".
« Reply #17 on: August 05, 2010, 04:26:01 PM »
How about this?
(defun wcsuffix (str pre / )
    (wcmatch str "TEST*#")
    (distof (substr str (1+(strlen pre)))2)
Command: (wcsuffix "TEST123" "TEST")
T
Command: (wcsuffix "TEST123a" "TEST")
nil
Command: (wcsuffix "TEST123a4" "TEST")
nil
« Last Edit: August 05, 2010, 04:29:04 PM by CAB »
« Reply #18 on: August 05, 2010, 04:33:44 PM »
Oops that one will not catch decimals but this should work.
(defun wcsuffix (str pre / tmp)
    (setq tmp (substr str (1+(strlen pre))))
    (= tmp (itoa(atoi tmp)))
nil
T
Command: (wcsuffix "TEST12.3" "TEST")
nil
« Reply #19 on: August 05, 2010, 04:35:55 PM »
Nice solution CAB  8-)
« Reply #20 on: August 05, 2010, 04:38:54 PM »
Nice solution Alan - kind of the reverse of VovKa's suggestion  8-)
« Reply #21 on: August 05, 2010, 05:21:10 PM »
Is there a wcmatch wildcard for AND, like there is "," for OR ?
« Reply #22 on: August 05, 2010, 06:45:32 PM »
What would be an example where AND would be used?
« Reply #23 on: August 06, 2010, 02:14:35 PM »
In place of MP's earlier suggestion, where he is using vl-every to make sure each pattern holds True.
LE3
« Reply #24 on: August 08, 2010, 04:13:20 PM »
(defun strPrefixIntNumSuffix (string prefix)
  (and (wcmatch string (strcat prefix "*[0-9]*"))
       (not (wcmatch string (strcat prefix "*[a-z]*")))
       (not (wcmatch string (strcat prefix "*[A-Z]*")))
       (not (wcmatch string (strcat prefix "*@*")))
       (not (wcmatch string (strcat prefix "*.*")))))
(strPrefixIntNumSuffix "test_#!@$%^&*()_-+={}[]|\;'\":,<.>?/`~" "test");;nil
(strPrefixIntNumSuffix "test9999" "test");;T
(strPrefixIntNumSuffix "test9999000000000000000e" "test");;nil
(strPrefixIntNumSuffix "test999900000.000000000" "test");;nil
(strPrefixIntNumSuffix "testpppp9999____oooo00000.000000000" "test");;nil
(strPrefixIntNumSuffix "test999900009-00000000000)))" "test");;nil
(strPrefixIntNumSuffix "99999test99990000900000000000)))" "test") ;;nil
(strPrefixIntNumSuffix "9999999990000900000000000" "test") ;;nil
edit:added more tests
or this short version:
(defun strNum  (string prefix)
       (vl-every (function (lambda (pattern) (not (wcmatch string (strcat prefix pattern)))))
(list "*[a-z]*" "*[A-Z]*" "*@*" "*.*"))))
« Last Edit: August 08, 2010, 10:57:17 PM by LE »
jbuzbee
« Reply #25 on: August 13, 2010, 09:25:43 AM »
When I read the title of this thread: "Wcmatch mental block" I thought: I've never heard of a Mental Block.  Is this some new kind of dynamic block for 2011? (I'm still on 2009)  What would a mental block be able to do over a regular block or a dynamic block?  AI?
that would be scary.
that's how messed up my brain is right now.   :lol:
TGIF
James Buzbee
Windows 8
« Reply #26 on: August 13, 2010, 09:28:20 AM »
It's not new, just undocumented.  8-)
jbuzbee
« Reply #27 on: August 13, 2010, 09:40:55 AM »
 :-D :-D :-D
Have a great weekend everone!
James Buzbee
Windows 8
« Reply #28 on: August 13, 2010, 03:57:12 PM »
« Reply #29 on: August 14, 2010, 09:04:58 AM »
lol  :lol:
