Author Topic: How to: Creating 3d fly through in Civil 3D  (Read 12838 times)
alanjt
  • Standby for witty remark...
« on: August 04, 2010, 08:40:09 AM »
Does anyone have any information on creating a 3d fly through of a roadway in civil 3d? It was asked of me today and I've never done anything like that.
Dropbox
LE3
Re: How to: Creating 3d fly through in Civil 3D
« Reply #1 on: August 04, 2010, 10:26:30 AM »
Alan,
This is my second day using C3D 2011 - just did a quick one using the command: NEWSHOT that can be viewed from SHOWMOTION iconbar (_navsmotion)
guess that can be use for that... but wait for the ones that know.
alanjt
« Reply #2 on: August 04, 2010, 10:30:23 AM »
Cool.
I found the Motion Path Animations under the VIEW pulldown. I'm playing with that now.
Dropbox
« Reply #3 on: August 04, 2010, 10:41:02 AM »
Cool.
You will find that having the camera attached to one path, and following another will produce the best animations...also I hope you have plenty of time for those scenes to render  ;-)
alanjt
« Reply #4 on: August 04, 2010, 10:49:20 AM »
Cool.
That makes a huge difference. I'm not sure if I can do this, but he said to play with it for a bit.
Dropbox
Willie
  • Going nowhere slowly
« Reply #5 on: August 04, 2010, 10:51:28 AM »
try "drive" command
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
« Reply #6 on: August 04, 2010, 01:19:28 PM »
Cool.
The cool part about having the camera  'look' at another path...is that through some clever segmentation...one can cause the camera to...open with target in distance...then pan/tilt towards object of interest...and hold focus there for several frames and then slowly pan to other areas of interest.....
one can also use the VIEW command to organize other STILL frames that can later be used in video editing app to fade/dissolve cut to shot..and then you insert your special views
« Reply #7 on: August 04, 2010, 01:21:46 PM »
A trick to start the camera path...lift the feature line, from the alignment...edit it's elevation to get it up to eye level, and then explode it into a polyline....then attach the camera to that path...be sure to turn on 'corner deceleration' to steady the camera through the polyline vertices ;-)
alanjt
« Reply #8 on: August 04, 2010, 04:28:35 PM »
Ok, I've got the fly through looking good. Is is possible to overlay an image or something to match the surface? I'm trying with the Map options, but it's saying I have to have polygons. Thoughts?
Dropbox
« Reply #9 on: August 04, 2010, 04:53:58 PM »
DrapeImage perhaps?
The help that describes the process can be found under this Heading: Draping Images On Surfaces
« Reply #10 on: August 04, 2010, 05:17:32 PM »
TipTo perform this operation, ensure that the surface display style has triangles visibility enabled. See Editing a Surface Style. Also, ensure that Realistic is a default type of materials set in the Material Editor in the Materials window
alanjt
« Reply #11 on: August 05, 2010, 09:14:23 AM »
Awesome, thanks guys.
Dropbox
butzers09silverado
« Reply #12 on: July 22, 2011, 08:09:55 AM »
I've done this quite a few times if you need help... i see this is an old post but I'm an old Skool FormZ, studioViz, and now C3D.
looks like you got what you needed but let me know.
RONJON322
« Reply #13 on: February 18, 2014, 02:17:17 PM »
I figured out how to do a fly by in autocad but I can't get my background to come out when I record.  All I get is a black background.  Any idea what I'm doing wrong?
Please help!!
Ronnie
« Reply #14 on: March 05, 2014, 07:30:35 AM »
map an image to a plane and place that within the camera view, and view style must be set to realistic
  or one could use
Navisworks
OR
Infrastructure Modeller (Infraworks)
