Those are what vertical objects look like to the base Autocad managed code. In order to cast the object to its full type, you also need to reference the managed libraries of the appropriate vertical product. And note that not all objects are available in the managed libraries of vertical products - for example, the managed API to Civil 3D is still very incomplete. There are a lot of things that can only be accessed via the COM interops. That involves getting the AcadObject from your ImpDBObject and casting it as required, and requires you to reference the interops for the appropriate vertical product.
