Author Topic: Writing tests for .Net AutoCAD plagins via Visual Studio 2010 Test menu tools  (Read 3210 times)
Andrey Bushman
Somebody has experience of writing tests for .Net AutoCAD plagins via Visual Studio 2010 Test menu tools?
If "yes" - then I will be very grateful for samples of it code.
« Last Edit: August 03, 2010, 09:21:56 AM by Andrey »
David Hall
  • Automatic Duh Generator
Andrey, I sent you a PM
Andrey Bushman
Yes, I got it, thank's.
It's Alive!
  • Retired
  • AKA Daniel
thanks for sharing  :|
Andrey Bushman
but... what about it topic? :-)
David Hall
The PM had nothing to do with the solution.
It's Alive!
  • Retired
  • AKA Daniel
Ah, and here I thought you guys were talking about top secret unit testing techniques via PM  :laugh:
Andrey Bushman
Somebody use it, or for AutoCAD it's impossible?
It's Alive!
  • Retired
  • AKA Daniel
I have not used it, from what I understand, it's for doing unit testing. You can use it to instantiate classes, run tests then tear down. I would assume its for larger projects and is probably not applicable for plug-ins that only contain a few command methods returning void. For the itty-bitty apps you can use the tools  found in System.Diagnostics; I.e. [Conditional("DEBUG")],  Debug and Trace
« Last Edit: August 04, 2010, 01:33:14 AM by __declspec »
