Author Topic: Document has a command in progress...  (Read 5262 times)
Andrey Bushman
« on: August 02, 2010, 03:23:25 PM »
I write code,which must union 2 table styles. It work. But after work of code, if I run "_qsave" command - I get message: "Document has a command in progress...".
Screen:
But if I run other commands - I not get it message.
I can't find problem...
[CommandMethod("Q2", CommandFlags.Session)]
public void UnionTableStyles()
    string firstTableStyleName = "ts1";
    string secondTableStyleName = "ts2";
    lock (dwg.LockDocument())
        using (Transaction t = dwg.TransactionManager.StartTransaction())
            DBDictionary dict = (DBDictionary)t.GetObject(db.TableStyleDictionaryId, OpenMode.ForWrite);
            TableStyle ts1 = (TableStyle) t.GetObject((ObjectId)dict[firstTableStyleName], OpenMode.ForRead);
            TableStyle ts2 = (TableStyle)t.GetObject((ObjectId)dict[secondTableStyleName], OpenMode.ForRead);
            List<ObjectId> primitives = new List<ObjectId>();
            if (db.Tablestyle == ts1.ObjectId) db.Tablestyle = ts2.ObjectId;
            for (long i = db.BlockTableId.Handle.Value; i < db.Handseed.Value; i++)
                ObjectId id = ObjectId.Null;
                try
                    id = db.GetObjectId(false, new Handle(i), 0);
                catch (System.Exception)
                { continue; }
                if (!id.IsErased)
                    DBObject x = t.GetObject(id, OpenMode.ForRead);
                    if (x is Table && ((Table)x).TableStyle == ts1.ObjectId)
                        primitives.Add(id);
            foreach (ObjectId id in primitives)
                DBObject x = t.GetObject(id, OpenMode.ForWrite);
                Table table = (Table)x;
                table.TableStyle = ts2.ObjectId;
                x.DowngradeOpen();
            ObjectIdCollection c = new ObjectIdCollection(new ObjectId[] { ts1.ObjectId });
            db.Purge(c);
            if (c.Count != 0) dict.Remove(ts1.ObjectId);
            t.Commit();
Glenn R
Re: Document has a command in progress...
« Reply #1 on: August 02, 2010, 03:31:34 PM »
What is the purpose of this line:
Andrey Bushman
« Reply #2 on: August 02, 2010, 03:48:52 PM »
lock document while work my method (other users can't modify drawing).
without lock I get error (eLockViolation) in string:
Glenn R
« Reply #3 on: August 02, 2010, 04:01:45 PM »
I know what it is, I just wanted to see what you thought it was used for.
The correct usage is this:
using (DocumentLock yourVariableNameGoesHere = someVariableThatIsADocument.LockDocument())
  // some interesting code goes here
By using a 'using' statement, the DocumentLock is correctly disposed, which releases your document (which you code doesn't do), even in the event of failure.
Also, you should never be using the C# 'lock' keyword in AutoCAD, as it's for locking down code for multi-thread access, which AutoCAD is not capable of doing, using any of it's in-built functions.
Next question:
With the below attribute, why are you using CommangFlags.Session?
Andrey Bushman
« Reply #4 on: August 02, 2010, 04:26:46 PM »
Thank you! Now all ok!
Next question:
Because it code may be use for batch processing (several drawing).
It was very simplified code (the original - differs).
Thank you for help!
« Last Edit: August 02, 2010, 04:31:32 PM by Hwd »
Glenn R
« Reply #5 on: August 02, 2010, 04:35:46 PM »
If that's the case, then you will need CommandFlags.Session. If you don't need to run from the Application context, then you don't use LockDocument and your command should be decorated with the CommanFlags.Modal attribute parameter.
Also, in future, if you want help from the members on this board, it is worth posting code that people can run. The code you posted wouldn't as there were things missing.
Andrey Bushman
« Reply #6 on: August 02, 2010, 04:43:10 PM »
Excuse me. It more full code:
using System;
using System.Linq;
using System.Text;
using System.Xml.Linq;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Interop.Common;
//Acad
using acad = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.LayerManager;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Interop;
namespace Bushman.Autodesk.AutoCAD.Styles
    public class Class1
        Document dwg;
        Editor ed;
        Database db;
        void Initialize()
            dwg = acad.DocumentManager.MdiActiveDocument;
            ed = dwg.Editor;
            db = dwg.Database;
        public Class1()
            Initialize();
            using (dwg.LockDocument())
                        try
                        { continue; }
                        if (!id.IsErased)
                                primitives.Add(id);
                        x.DowngradeOpen();
                    db.Purge(c);
                    t.Commit();
Thank you.
Glenn R
« Reply #7 on: August 02, 2010, 04:46:01 PM »
You're welcome.
David Hall
  • Automatic Duh Generator
« Reply #8 on: August 02, 2010, 05:51:06 PM »
Not to ask a dumb question, but if your in the drawing to run the code, why lock the dwg?  Isn't it already locked because your in it?
Glenn R
« Reply #9 on: August 03, 2010, 05:43:32 AM »
That depends. Consider a modeless dialog - a palette is an excellent example. Because it's modeless, you will be running from the Application context, not in a drawing perse, so you will have to explicitly lock the document before you begin your mojo.
Contrast this to a command that has CommandFlags.Modal. This is running in the context of the drawing and a lock is implicitly applied by autocad, therefore, no need to lock it yourself.
I think of it as outside (application context) and inside (document context). If you're on the inside, you've got less to do - if you're on the outside looking in, you got more to do.
Andrey Bushman
« Reply #10 on: August 03, 2010, 06:10:31 AM »
Thank you!
David Hall
« Reply #11 on: August 03, 2010, 09:05:34 AM »
That makes perfect sense, thanks Glenn
