Author Topic: -={ Challenge }=- Multi-Delimiter String Parsing  (Read 7417 times)
« on: July 25, 2010, 10:36:35 AM »
The Challenge:
To separate elements of a string by a list of delimiters.
Example:
(MultiParse "This;is.a,Test;String" '(";" "." ","))
==>  ("This" "is" "a" "Test" "String")
(MultiParse "This&%is,5%" '("," "&%"))
==>  ("This" "is" "5%")
(MultiParse "&This,is,a&Test," '("&" ","))
==> ("This" "is" "a" "Test")
Enjoy!
Lee
« Last Edit: July 25, 2010, 11:45:04 AM by Lee Mac »
Re: -={ Challenge }=- Multi-Delimiter String Parsing
« Reply #1 on: July 25, 2010, 11:26:53 AM »
Here is a quickie. 8-)
(defun sparserm (str delim / ptr lst)
  (while (setq ptr (vl-remove 'nil (mapcar (function (lambda(x) (vl-string-search x str))) delim)))
    (setq ptr (apply 'min ptr))
    (setq lst (cons (substr str 1 ptr) lst))
    (setq str (substr str (+ ptr 2)))
  (reverse(cons str lst))
« Reply #2 on: July 25, 2010, 11:39:01 AM »
Nice one Alan  8-)
How about for delims of length > 1  :evil:
(sparserm "This&%is,5%" '("," "&%"))
« Reply #3 on: July 25, 2010, 11:42:46 AM »
My first entry:
(defun LM:StringParserM ( str del / foo l )
  (defun foo ( str del )
    (if (setq pos (vl-string-search del str))
      (vl-remove ""
        (cons (substr str 1 pos)
          (foo
            (substr str (+ pos 1 (strlen del))) del
      (list str)
  (setq l (foo str (car del)))
  (foreach x (cdr del)
    (setq l
      (apply (function append)
        (mapcar (function (lambda ( y ) (foo y x))) l)
  l
« Last Edit: July 25, 2010, 11:47:24 AM by Lee Mac »
« Reply #4 on: July 25, 2010, 12:06:33 PM »
Was that in the specifications?  :evil:
hermanm
« Reply #5 on: July 25, 2010, 01:14:01 PM »
Nice one, Lee.:)
Command: (LM:StringParserM "This;is.a,Test;\String" '(";" "." "," "\\"))
Command: (LM:StringParserM "This\nis a test\n     " '(" " "\n"))
("This" "is" "a" "test")
« Reply #6 on: July 25, 2010, 02:45:33 PM »
I hadn't included an example, but it was my intention  :wink:
« Reply #7 on: July 25, 2010, 02:47:03 PM »
Nice one, Lee.:)
Thanks Herman  :-)
LE3
« Reply #8 on: July 25, 2010, 04:11:34 PM »
;;(mparser '(";" "." "," "\\") "This;is.a,Test;\String")
;;("This" "is" "a" "Test" "String")
;;(mparser '(";" "." ",") "This;is.a,Test;String")
(defun mparser (pat str / pattern i j n lst)
  (setq p (car pat))
  (setq pattern (vl-remove p pat))
  (setq i 0)
  (repeat (length pattern)
    (setq str (vl-string-subst p (nth i pattern) str))
    (setq i (1+ i))
    ((/= (type str) (type p) 'STR))
    ((= str p) '(""))
    (T
     (setq i 0
  n (strlen p)
     (while (setq j (vl-string-search p str i))
       (setq lst (cons (substr str (1+ i) (- j i)) lst)
    i (+ j n)
     (mapcar '(lambda (x) (vl-string-trim " " x))
    (reverse (cons (substr str (1+ i)) lst))
« Reply #9 on: July 25, 2010, 05:17:24 PM »
Another,
(defun LM:StringParserM2 ( str del / pos x )
  ;; © Lee Mac 2010
  (if (setq pos
        (car
          (setq x
            (car
              (vl-sort
                (vl-remove nil
                  (mapcar
                    (function
                      (lambda ( d / p )
                        (if (setq p (vl-string-search d str))
                          (cons p (strlen d))
                    del
                (function
                  (lambda ( a b ) (< (car a) (car b)))
    (vl-remove ""
        (LM:StringParserM2
          (substr str (+ pos 1 (cdr x))) del
    (list str)
« Reply #10 on: July 25, 2010, 05:42:54 PM »
Perhaps a slightly more elegant version of my first one  :-)
      (vl-remove ""
          (foo
      (list str)
  (if (cdr del)
      (mapcar (function (lambda ( x ) (LM:StringParserM x (cdr del))))
        (foo str (car del))
    (foo str (car del))
LE3
« Reply #11 on: July 25, 2010, 07:46:51 PM »
edited.-
;;parsermult uses a token character separator to replace
;;all the characters separators in the patterns list
;;will check if the token is not on the patterns or in the string
;;returns= a list of new strings or nil
;;usage:
;;(parsermult "this;is;;a,test\"\"" '(";" "," "\"") "|")
;;("this" "is" "a" "test")
(defun parsermult  (string patterns token / pattern pos lst)
  (if (and (not (vl-position token patterns))
   (not (vl-string-search token string)))
      (while (setq pattern (car patterns))
(while (and pattern (vl-string-search pattern string))
  (setq string (vl-string-subst token pattern string)))
(setq patterns (cdr patterns)))
      (while (setq pos (vl-string-search token string))
(setq lst    (cons (substr string 1 pos) lst)
      string (substr string (+ pos 2))))
      (vl-remove "" (reverse lst)))))
« Last Edit: July 26, 2010, 12:08:51 AM by LE3 »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: July 26, 2010, 03:13:07 AM »
mine  :-D
(defun MultiParse (string delims / dlist item llout tmpl)
  (setq tmpl '() llout '()  dlist (vl-string->list delims))
  (foreach item (vl-string->list (vl-string-right-trim delims string))
    (if (not (vl-position item dlist))
      (setq tmpl (cons item tmpl))
        (setq llout (append llout (list(vl-list->string(reverse tmpl)))) tmpl '())
(MultiParse "This;is.a,Test;String" ";.,")
« Reply #13 on: July 26, 2010, 03:45:23 AM »
Daniel, I have one with similar functionality :
However I think the expectation was that the delimiters be a list of strings, each of which shall be removed from the parent string if existing.
... this should allow the the removal of character patterns like " ex" and "'s " from the parent.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: July 26, 2010, 03:57:59 AM »
ah ok, maybe something like
(defun MultiParse (string delims / item llout s tdlim tmpl tstr)
  (setq tstr "" tdlim "")
  (repeat (length delims)
    (setq tstr (strcat " " tstr)))
  (foreach s  delims
    (setq tdlim (strcat s tdlim)))
  (setq tmpl '() llout '())
  (foreach item (vl-string->list (vl-string-right-trim " "(vl-string-translate tdlim tstr string)))
    (if (/= item 32)
(MultiParse "This;is.a,Test;String " '(";" "." ","))
« Last Edit: July 26, 2010, 04:01:11 AM by eAmbiguousOutput »
