Author Topic: The accurateness about getClosestPointTo between two Curves.  (Read 13540 times)
highflyingbird
  • Later equals never.
Re: The accurateness about getClosestPointTo between two Curves.
« Reply #15 on: July 31, 2010, 07:24:27 PM »
...Iíve also investigated the Curve3d.GetClosestPointTo(Curve3d, Tolerance), from the .NET side, and found the method to be a bit temperamental.  Does your updated code allow more consistent results?
Sorry,I just modified some bugs,havn't done more work  to improve it.
To be honest,I think ,if your want to get a more accurate result,you should use the iterative algorithm,maybe it's much better,and the function of getclosepointto
has several bugs.
so I put it way,wait some good ideas another day.
This attachment is the last one.
see the picture below:
« Last Edit: August 11, 2010, 08:38:42 AM by highflybird »
I am a bilingualist,Chinese and Chinglish.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #16 on: August 03, 2010, 02:57:02 AM »
Have you tried this with Bricscad? just curious..
highflyingbird
« Reply #17 on: August 03, 2010, 06:24:09 AM »
Actually, I did try this with Bricscad before you mentioned it.
but it didn't work.because Bricscad lacks  some functions .e.g:
Conversion.obj : error LNK2019: unresolved external symbol "public: class AcGeNurbCurve3d & __thiscall AcGeNurbCurve3d::makeClosed(void)" (?makeClosed@AcGeNurbCurve3d@@QAEAAV1@XZ) referenced in function "class AcGeNurbCurve3d * __cdecl AcDbCurveToAcGeCurve(class AcDbSpline const *)" (?AcDbCurveToAcGeCurve@@YAPAVAcGeNurbCurve3d@@PBVAcDbSpline@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: __thiscall AcGeNurbCurve3d::AcGeNurbCurve3d(class AcArray > const &,class AcGeVector3d const &,class AcGeVector3d const &,int,int,class AcGeTol const &)" (??0AcGeNurbCurve3d@@QAE@ABV?$AcArray@VAcGePoint3d@@V?$AcArrayMemCopyReallocator@VAcGePoint3d@@@@@@ABVAcGeVector3d@@1HHABVAcGeTol@@@Z) referenced in function "class AcGeNurbCurve3d * __cdecl AcDbCurveToAcGeCurve(class AcDbSpline const *)" (?AcDbCurveToAcGeCurve@@YAPAVAcGeNurbCurve3d@@PBVAcDbSpline@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: class AcGeKnotVector const & __thiscall AcGeSplineEnt3d::knots(void)const " (?knots@AcGeSplineEnt3d@@QBEABVAcGeKnotVector@@XZ) referenced in function "class AcDbSpline * __cdecl AcGeCurveToAcDbCurve(class AcGeNurbCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbSpline@@PBVAcGeNurbCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeSplineEnt3d::numKnots(void)const " (?numKnots@AcGeSplineEnt3d@@QBEHXZ) referenced in function "class AcDbSpline * __cdecl AcGeCurveToAcDbCurve(class AcGeNurbCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbSpline@@PBVAcGeNurbCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeSplineEnt3d::order(void)const " (?order@AcGeSplineEnt3d@@QBEHXZ) referenced in function "class AcDbSpline * __cdecl AcGeCurveToAcDbCurve(class AcGeNurbCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbSpline@@PBVAcGeNurbCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeNurbCurve3d::getFitData(class AcArray > &,class AcGeTol &,int &,class AcGeVector3d &,class AcGeVector3d &)const " (?getFitData@AcGeNurbCurve3d@@QBEHAAV?$AcArray@VAcGePoint3d@@V?$AcArrayMemCopyReallocator@VAcGePoint3d@@@@@@AAVAcGeTol@@AAHAAVAcGeVector3d@@3@Z) referenced in function "class AcDbSpline * __cdecl AcGeCurveToAcDbCurve(class AcGeNurbCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbSpline@@PBVAcGeNurbCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeSplineEnt3d::hasFitData(void)const " (?hasFitData@AcGeSplineEnt3d@@QBEHXZ) referenced in function "class AcDbSpline * __cdecl AcGeCurveToAcDbCurve(class AcGeNurbCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbSpline@@PBVAcGeNurbCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: __thiscall AcGeCompositeCurve3d::AcGeCompositeCurve3d(class AcArray > const &)" (??0AcGeCompositeCurve3d@@QAE@ABV?$AcArray@PAXV?$AcArrayMemCopyReallocator@PAX@@@@@Z) referenced in function "class AcGeCompositeCurve3d * __cdecl AcDbCurveToAcGeCurve(class AcDbPolyline const *)" (?AcDbCurveToAcGeCurve@@YAPAVAcGeCompositeCurve3d@@PBVAcDbPolyline@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: void __thiscall AcGeCompositeCurve3d::getCurveList(class AcArray > &)const " (?getCurveList@AcGeCompositeCurve3d@@QBEXAAV?$AcArray@PAXV?$AcArrayMemCopyReallocator@PAX@@@@@Z) referenced in function "class AcDbPolyline * __cdecl AcGeCurveToAcDbCurve(class AcGeCompositeCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbPolyline@@PBVAcGeCompositeCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeCurve3d::isLinear(class AcGeLine3d &,class AcGeTol const &)const " (?isLinear@AcGeCurve3d@@QBEHAAVAcGeLine3d@@ABVAcGeTol@@@Z) referenced in function "class AcDbPolyline * __cdecl AcGeCurveToAcDbCurve(class AcGeCompositeCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbPolyline@@PBVAcGeCompositeCurve3d@@@Z)
Conversion.obj : error LNK2019: unresolved external symbol "public: int __thiscall AcGeCurve3d::isPlanar(class AcGePlane &,class AcGeTol const &)const " (?isPlanar@AcGeCurve3d@@QBEHAAVAcGePlane@@ABVAcGeTol@@@Z) referenced in function "class AcDbPolyline * __cdecl AcGeCurveToAcDbCurve(class AcGeCompositeCurve3d const *)" (?AcGeCurveToAcDbCurve@@YAPAVAcDbPolyline@@PBVAcGeCompositeCurve3d@@@Z)
Debug/MyCurve.arx : fatal error LNK1120: 12 unresolved externals
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #18 on: August 03, 2010, 11:05:43 AM »
Well darn, I guess those functions are still needing to be implemented. I met the guy who wrote the geometry library for Bricscad at the developers meeting. This guy is so smart... I kinda like Forest Gump talking to Steven Hawkin..
frtfff
« Reply #19 on: August 06, 2010, 08:47:13 PM »
highflyingbird
« Reply #20 on: September 17, 2010, 09:39:58 AM »
I created a routine to get the right position  of  closest points between two curves.
use command "test" and "ccc" to compare  the method of iteration to the function of GetCLosestPointto:
001758
« Reply #21 on: November 29, 2011, 06:11:31 AM »
Help,
I really need that line that joins the two closest points.
I note in the post that the line is rarely need but only the readout.
I need that line - help.
frtfff
« Reply #22 on: November 30, 2011, 10:39:55 PM »
这个,是不是因为这个仅仅是三维立体图表现在二维平面的一个原因,还是,你一直都在用二维的检验?
It's 3D or 2D?
