Author Topic: Cell styles in TableStyle...  (Read 21731 times)
Andrey Bushman
Re: Cell styles in TableStyle...
« Reply #30 on: July 26, 2010, 03:04:03 AM »
May be it not work for AutoCAD 2009?
In Windows XP x86 SP3 I see reference, and can add it in my Project:
But...
The problem remained... (((
« Reply #31 on: July 26, 2010, 03:27:37 AM »
What happens if you use these references ??
the ObjectARX 2009 Reference:
Andrey Bushman
« Reply #32 on: July 26, 2010, 03:38:05 AM »
At first I did too. You can see result on my Reply #24 on: July 25, 2010, 03:41:47 pm for Windows 7 x64 (I showed the screen).
For Windows XP x86 other screen:
« Last Edit: July 26, 2010, 03:45:20 AM by Hwd »
« Reply #33 on: July 26, 2010, 03:50:31 AM »
Perhaps you could remove ALL the AutoCad based references and re-reference them :)
« Reply #34 on: July 26, 2010, 03:55:01 AM »
Have the rules changed again ??
Which version and Operating System are you actually trying to build on ???
Andrey Bushman
« Reply #35 on: July 26, 2010, 04:07:20 AM »
If I delete AutoCAD reference, then I get result which I show on my Reply #17 on: July 25, 2010, 12:57:30 pm.
I have Windows 7 x64 Ultimate and AutoCAD 2009 x64 SP3 Enu on my home.
I have Windows XP x86 SP3 Professional and AutoCAD 2009 x86 SP3 Enu on my office (work).
Some my users use Windows 7 x64, and some - Windows XP x86 SP3 Professional. Most my users (99%) use AutoCAD 2009.
I tried to do it.
« Reply #36 on: July 26, 2010, 04:10:20 AM »
re-read what I said.
Remove the ALL AutoCAD based references.
Reference them again.
« Reply #37 on: July 26, 2010, 04:12:34 AM »
great. How about resolving ONE issue at a time.
Choose one build and get it correct.
Then resolve the other build.
« Reply #38 on: July 26, 2010, 04:14:51 AM »
I tried to do it.
Perhaps you should try again
... and tell us which build you are working on.
Andrey Bushman
« Reply #39 on: July 26, 2010, 04:28:17 AM »
and
Most important variant - Windows XP x86 SP3 and AutoCAD 2009 x86.
I write video (YouTobe):
http://www.youtube.com/watch?v=TMNdpoNopxg
fixo write me, what on him AutoCAD 2009 all it good work. I was tangled... (((
I have asked him to send me a full project code - then I  compare all references.
« Last Edit: July 26, 2010, 04:51:59 AM by Hwd »
« Reply #40 on: July 26, 2010, 04:53:21 AM »
The video was a bit unclear for me.
I just looked at  the contents of  Autodesk.AutoCAD.Interop.Common for 2009
There is a public interface  IAcadTableStyle : IAcadObject
and a public interface IAcadTableStyle2 : IAcadTableStyle
ONLY the IAcadTableStyle2 has
void DeleteCellStyle(string bstrCellStyle);
void CreateCellStyle(string bstrCellStyle);
I can't test this, but perhaps try
// interop.Common.IAcadTableStyle ts = ob as interop.Common.IAcadTableStyle;
interop.Common.IAcadTableStyle2 ts = ob as interop.Common.IAcadTableStyle2;
Andrey Bushman
The problem is solved
« Reply #41 on: July 26, 2010, 05:05:54 AM »
Yes!!!!! ))))))
I use code from Reply #16 on: July 25, 2010, 12:15:56 pm within IAcadTableStyle. Now I change on IAcadTableStyle2 and all ok!!!!
All Thanks for help!
« Last Edit: July 26, 2010, 05:20:33 AM by Hwd »
fixo
« Reply #42 on: July 26, 2010, 05:42:13 AM »
With this one can add a cellstyle, delete a cellstyle, set the textstyle for a cellstyle.
It requires you to add some textstyles and a tablestyle
1) Apparantly it is impossible (whatever you do don't actually try it)
2) It probably is no use to the OP , as it is in no way what he wanted.
3) Who wants to use interop anyway.
       [CommandMethod("tts")]
        public static void TableStyleTest()
            Editor ed = doc.Editor;
            Database db = doc.Database;
            string tableStyleName = "YourTableStyle";
                TableStyle tableStyle;
                DBDictionary dic = tr.GetObject(db.TableStyleDictionaryId, OpenMode.ForRead) as DBDictionary;
                foreach (DictionaryEntry eDict in dic)
                    tableStyle = tr.GetObject
                        ((ObjectId)eDict.Value, OpenMode.ForRead) as TableStyle;
                    if (tableStyle.Name == tableStyleName)
                        tableStyle.UpgradeOpen();
                        ArrayList ca = tableStyle.CellStyles;
                        interop.AcadApplication Ap = (interop.AcadApplication)acadApp.AcadApplication;
                        object ob = Ap.ActiveDocument.ObjectIdToObject( tableStyle.ObjectId.OldId);
                        TextStyleTable textstyletable=tr.GetObject
                            (db.TextStyleTableId,OpenMode.ForRead) as TextStyleTable;
                        object ob2 = Ap.ActiveDocument.ObjectIdToObject(textstyletable.ObjectId.OldId);
                        interop.Common.IAcadTextStyles tss = ob2 as interop.Common.IAcadTextStyles;
                        if(ca.Contains("U1")) ts.DeleteCellStyle("U1");
                        ts.CreateCellStyle("U1");
                        ts.SetCellClass("U1", 1);
                        if (ca.Contains("U2")) ts.DeleteCellStyle("U2");
                        ts.CreateCellStyle("U2");
                        ts.SetCellClass("U2", 2);
                        if (ca.Contains("U3")) ts.DeleteCellStyle("U3");
                        ts.CreateCellStyle("U3");
                        ts.SetCellClass("U3", 3);
                        ed.WriteMessage(tss.Item("User1").ObjectID.ToString());
                        if(textstyletable.Has("User1"))
                            ts.SetTextStyleId("U1", tss.Item("User1").ObjectID);
                        if (textstyletable.Has("User2"))
                            ts.SetTextStyleId("U2", tss.Item("User2").ObjectID);
                        if (textstyletable.Has("User3"))
                            ts.SetTextStyleId("U3", tss.Item("User3").ObjectID);
                tr.Commit();
        } // end TableStyleTest
Thanks, Bryco, ya da man!
I've adopted your code to my A2009
It's working like a charm
Regards,
Oleg
~'J'~
pkohut
« Reply #43 on: July 26, 2010, 06:05:42 AM »
Problem solved, now I'll I can ask my OT question.
What software was used to annotate Kerry's and Hwd's pictures.  Can never be enough cool tools.
« Last Edit: July 26, 2010, 06:08:52 AM by pkohut »
Andrey Bushman
« Reply #44 on: July 26, 2010, 06:08:42 AM »
Problem solved, now I'll ask my OT question.
this
