Author Topic: How do I Convert a AcGeCompositeCurve3d to a AcDbPolyline?  (Read 2751 times)
highflyingbird
  • Later equals never.
« on: July 21, 2010, 10:51:18 AM »
This is my code.
AcDbPolyline * AcGeCurveToAcDbCurve(const AcGeCompositeCurve3d * pGe)
AcGePoint3d startPnt,endPnt;
if(pGe->hasEndPoint(endPnt) == Adesk ::kFalse || pGe->hasStartPoint(startPnt) == Adesk::kFalse)
return NULL;
AcGePlane plane;
             pGe->isPlanar(plane);
AcGePoint2d pt;
AcDbPolyline *pPoly = new AcDbPolyline();
AcGeVoidPointerArray curveList;
pGe->getCurveList(curveList);
AcGeCurve3d *pCurve = NULL;
AcGeLine3d *pLine = NULL;
             AcGeCircArc3d *arc = NULL;
int i;
for(i = 0;i < curveList.length();i++)
pCurve  =  (AcGeCurve3d *) (curveList[i]);
pCurve->hasStartPoint(startPnt);
pt = startPnt.convert2d(plane);
if (pCurve->isKindOf(AcGe::kLineSeg3d))
pPoly->addVertexAt(i,pt);
else if (pCurve->isKindOf(AcGe::kCircArc3d))
arc = (AcGeCircArc3d *)(pCurve);
double b = tan(0.25*(arc->endAng() - arc->startAng()))*(arc->normal().z);
pPoly->addVertexAt(i,pt,b);
pPoly->addVertexAt(i,endPnt.convert2d(plane),0,0,0);
return pPoly;
but when  the normal of AcGeCompositeCurve3d isn't (0 0 1),it works incorrectly. what's the matter?
I am a bilingualist,Chinese and Chinglish.
highflyingbird
Re: How do I Convert a AcGeCompositeCurve3d to a AcDbPolyline?
« Reply #1 on: July 21, 2010, 10:56:05 AM »
This is the code that can convert a AcDbPolyline to AcGeCompositeCurve3d. it does work.
// POLYLINE
AcGeCompositeCurve3d * AcDbCurveToAcGeCurve(const AcDbPolyline * pPoly)
AcGeLineSeg3d *pLine = NULL;
AcGeCircArc3d *pArc = NULL;
AcGeVoidPointerArray GeCurves;
for( int i = 0; i < pPoly->numVerts(); i++ )
if( pPoly->segType(i) == AcDbPolyline::kLine )
pLine = new AcGeLineSeg3d;
pPoly->getLineSegAt(i, *pLine);
GeCurves.append(pLine);
else if( pPoly->segType(i) == AcDbPolyline::kArc )
pArc = new AcGeCircArc3d;
pPoly->getArcSegAt(i, *pArc);
GeCurves.append(pArc);
return  new AcGeCompositeCurve3d(GeCurves);
highflyingbird
« Reply #2 on: July 22, 2010, 10:27:36 AM »
OK,I found a way to solve this problem.  :-D
It looks a little clumsy. Does anyone have a easier way?
if( pGe->hasEndPoint(endPnt) == Adesk ::kFalse ||
return NULL;
//get the plane of Curve3d
AcGePlane plane;
AcGeLine3d line;
AcGePoint3d p1,p2,p3;
    if(pGe->isPlanar(plane))
if(pGe->isLinear(line))    //Oh,it's a little tricky!
line.getPerpPlane(startPnt,plane);
plane.get(p1,p2,p3);
plane.set(p2,p3-p2);
else
return NULL;
//Creat a polyline
int i;
double b;
AcGePoint2d pt;
pArc = (AcGeCircArc3d *)(pCurve);
b = tan(0.25*(pArc->endAng() - pArc->startAng()));
if (pArc->normal().z < 0.0)
pPoly->addVertexAt(i,pt,-b);
else
else
if(!pGe->isClosed())
pt = endPnt.convert2d(plane);
else
pPoly->setClosed(Adesk::kTrue);
    //the most important step;
AcGeMatrix3d xform;
AcGeVector3d XAxis = p1-p2;
AcGeVector3d YAxis = p3-p2;
AcGeVector3d ZAxis = XAxis.crossProduct(YAxis);
xform.setCoordSystem(p2,XAxis,YAxis,ZAxis);
pPoly->transformBy(xform);
return pPoly;
