Author Topic: What is diffirence between BLOCK and INSERT?  (Read 2831 times)
HasanCAD
« on: July 19, 2010, 03:37:04 AM »
What is difference between a block definition (BLOCK) and block references (INSERT)?
(defun HM:add_Coordblock ()
  (if (not (tblsearch "block" "EC-CoordPoint"))
      (entmake (list (cons 0 "BLOCK")
(cons 100 "AcDbEntity")
(cons 67 0)
(cons 8 "0")
(cons 100 "AcDbBlockReference")
(cons 2 "EC-CoordPoint")
(cons 10 (nth (+ 5 n) XlsLst) (nth (+ 6 n) XlsLst) (nth (+ 7 n) XlsLst)) ;base point
(cons 70 0)
      (entmake (list (cons 0 "POINT")
         (cons 67 0)
         (cons 8 "0")
         (cons 100 "AcDbPoint")
         (cons 10 0.0 0.0 0.0)
         (cons 50 0.0)
      (entmake (list (0 "ATTDEF")
         (cons 67 0)
         (cons 8 "0")
         (cons 100 "AcDbText")
         (cons 10 -1433.142857142857 -110.0 0.0)
         (cons 40 220.0)
         (cons 1 (nth (+ 4 n) XlsLst)) ;Vlaue
         (cons 50 0.0)
         (cons 41 0.8)
         (cons 51 0.0)
         (cons 7 "EC-22-100")
         (cons 71 0)
         (cons 72 1)
         (cons 11 0.0 0.0 0.0)
         (cons 100 "AcDbAttributeDefinition")
         (cons 3 "EC-CoordPoint_PROMPT")
         (cons 2 "EC-COORDPOINT_TAG")
         (cons 70 0)
         (cons 73 0)
         (cons 74 2)
         (cons 280 0)
      (entmake (list (cons 0 "ENDBLK")
(cons 100 "AcDbBlockEnd")
(cons 8 "0")
Re: What is diffirence between BLOCK and INSERT?
« Reply #1 on: July 19, 2010, 03:46:54 AM »
Haven't tried your code, but a couple of questions ..
What do you think the code does ?
What is the value of n ?
What is the value of XlsLst ?
HasanCAD
« Reply #2 on: July 19, 2010, 04:37:21 AM »
I am tring to import a data from xls file using Gile tool Excel read and write
The full idea is
- Import points coordenate from excel file
- Then process these points in AutoCAD (move and rotate) to match the master plan
- Then export the new data to an excel sheet again.
What I am thinking is creating a block with insertion point and an attribute with point number to be able to export to the excel sheet with the points sequance
Attached a snapshot for the excel sheet
(defun c:CoordBlock ()
    (setq time (getvar "millisecs")
  n -1
  XlsLst (gc-xlread "C:/EC-Menu/Help/EC-Coordinates.xls" "Coord")
  (while
    (HM:add_Coordblock)
    (setq n (1+ n))
(cons 67 0)
(cons 8 "0")
(cons 70 0)
         (cons 67 0)
         (cons 8 "0")
         (cons 50 0.0)
         (cons 67 0)
         (cons 8 "0")
         (cons 40 220.0)
         (cons 50 0.0)
         (cons 41 0.8)
         (cons 51 0.0)
         (cons 71 0)
         (cons 72 1)
         (cons 70 0)
         (cons 73 0)
         (cons 74 2)
         (cons 280 0)
(cons 8 "0")
  (princ (strcat "\n<< Time took: " (rtos (/ (- (getvar "millisecs") time) 1000.) 2 4) " secs. >>"))
Tharwat
  • Hypersensitive
« Reply #3 on: July 19, 2010, 06:38:16 AM »
Well, BLOCK is made of gathered entities to be used later on as one object in a drawing of Autocad.  :ugly:
So the INSERT is the mechanical process to get your BLOCK come true in reality.. is that clear  :pissed:
 :-D  :-D  :-D
Tharwat
« Reply #4 on: July 19, 2010, 06:42:35 AM »
has not been resolved.
To deal with block definition and inserts using entmake :
FIRST :
If the BLOCK definition is not in the Block Table
then create the BLOCK
  • 1. Entmake the BLOCK entity.
  • 2. Entmake one ATTDEF entity for each attribute.
  • 3. Entmake a ENDBLK entity.
Then SECOND :
  To create the INSERT
  • 1. Entmake the INSERT entity.
  • 2. Entmake one ATTRIB entity for each attribute.
  • 3. Entmake a SEQEND entity.
When you can do that you can start to consider automating the process
« Reply #5 on: July 19, 2010, 02:16:19 PM »
Perhaps read this thread also.
« Reply #6 on: July 20, 2010, 05:31:11 AM »
Hello.
Is there anybody in there?
Just nod if you can hear me.
Is there anyone home?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: July 20, 2010, 05:39:39 AM »
Hello.
Hi!  :-)
HasanCAD
« Reply #8 on: July 20, 2010, 07:41:01 AM »
Hello.
Hi Kerry
dgorsman
« Reply #9 on: July 20, 2010, 11:19:09 AM »
The difference between a BLOCK and an INSERT (more correctly, a block reference) is the difference between a blueprint and the actual building.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Hangman
« Reply #10 on: July 20, 2010, 03:00:57 PM »
So, ... your saying that ... a BLOCK is to a Building what an INSERT is to a blueprint ??<Sarc>   :-D
(grrrr, ... stupid sarc marks ain't work'n)   :realmad:
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
dgorsman
« Reply #11 on: July 20, 2010, 03:31:46 PM »
Other way 'round - the BLOCK is the blueprint, which provides the instructions to build the actual object; in this case, a block reference.  Many buildings can be built off of the same blueprint, but they can (and usually do) vary slightly depending on who put them on site.
try {GreatPower;}
      {MasterBasics;}
