DistanceDouble; input-onlyThe distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve's radius).
Command: (vlax-invoke obj 'offset 0.25)(#<VLA-OBJECT IAcadLWPolyline 0bb73304>)
Command: (vlax-invoke obj 'offset -0.5)(#<VLA-OBJECT IAcadLWPolyline 0bb73c64>)
