Author Topic: -={ Challenge }=- Nested Summing  (Read 9075 times)
« on: July 17, 2010, 06:09:26 AM »
Just for fun  :lol:
The Challenge:
Sum a list of numerical elements, nested to any level  8-)
Example:
(SumList '( 1 2 3 ))
==> 6
(SumList '( 1 2 ( 3 4 ( 1 ))))
==> 11
Have fun!
Lee
« Last Edit: July 17, 2010, 06:55:29 AM by Lee Mac »
It's Alive!
  • Retired
  • AKA Daniel
Re: -={ Challenge }=- Nested Summing
« Reply #1 on: July 17, 2010, 07:02:12 AM »
static int ads_nsum(void)
    struct resbuf *pArgs=acedGetArgs();
    double ans = 0;
    for(resbuf *pRbTmp=pArgs;pRbTmp!=NULL;pRbTmp=pRbTmp->rbnext)
      switch(pRbTmp->restype)
      case RTSHORT:   { ans+=pRbTmp->resval.rint; } break;
      case RTLONG:    { ans+=pRbTmp->resval.rlong; } break;
      case RTREAL:    { ans+=pRbTmp->resval.rreal; } break;
      case RTPOINT:   { ans+=pRbTmp->resval.rpoint[0];
                        ans+=pRbTmp->resval.rpoint[1];} break;
      case RT3DPOINT: { ans+=pRbTmp->resval.rpoint[0];
                        ans+=pRbTmp->resval.rpoint[2];} break;
    acedRetReal(ans);
    return (RSRSLT) ;
« Last Edit: July 17, 2010, 09:12:59 AM by eAmbiguousOutput »
David Bethel
« Reply #2 on: July 17, 2010, 07:02:42 AM »
Lee,
I always liked this one from the Compuserve days:
;;;++++++++++++ Explode Any List Steve Johnson +++++++++++++++++++++
(defun exlist (LST / expl new)
  (defun expl (SUBLST)
    (foreach one SUBLST
      (if (atom one)
          (setq new (cons one new))
          (if (listp (cdr one))
              (expl one)
              (setq new (cons (cdr one) (cons (car one) new)))))))
  (expl (list LST))
  (reverse new))
 (defun SumList (l)
    (apply '+ (exlist l)))
(SumList '(1 2 ( 3 4 ( 1 ))))
-David
R12 Dos - A2K
« Reply #3 on: July 17, 2010, 07:08:08 AM »
Dan - I'm blown out of the water by that  :lol: I can't even begin to dissect it to try to understand it...
David - that reminds me of Michaels 'Squish' function - nice approach.
Here is my submission:
(defun LM:SumList ( l )
  (if l
    (+ (if (eq 'list (type (car l)))
         (LM:SumList (car l))
         (car l)
       (LM:SumList (cdr l))
    0
David Bethel
« Reply #4 on: July 17, 2010, 07:22:27 AM »
Lee,
Try a list like this:
(setq l1 '( 1 2 (3 . 4)(5 6 7) 8))
That could have came from same stuff.  There were quite a few of us on the Compuserve forum that are still hanging around.  It was Autodesk's 'official' forum.  ALT- & COMP- stuff was around, just loaded with flamers and junk...
-David
« Last Edit: July 17, 2010, 07:27:30 AM by David Bethel »
R12 Dos - A2K
gile
  • Marseille, France
« Reply #5 on: July 17, 2010, 07:23:57 AM »
the same as Lee:
(defun sumlist (l / e)
  (if (setq e (car l))
    (+ (if (atom e)
         e
         (sumlist e)
       (sumlist (cdr l))
    0
or using cond
    ((null (setq e (car l))) 0)
    ((atom (car l)) (+ e (sumlist (cdr l))))
    (T (+ (sumlist e) (sumlist (cdr l))))
gile
  • Marseille, France
« Reply #6 on: July 17, 2010, 07:36:20 AM »
This one should work with the list posted by David
    ((and l (atom l)) l)
« Reply #7 on: July 17, 2010, 07:37:22 AM »
Lee,
-David
Ah yes - I hadn't accounted for any dotted pairs...  :|
gile
  • Marseille, France
« Reply #8 on: July 17, 2010, 07:42:45 AM »
Or, using if statement:
    (+ (if (atom e)
         e
         (sumlist e)
       (if (listp (cdr l))
         (sumlist (cdr l))
         (cdr l)
    0
« Reply #9 on: July 17, 2010, 07:43:33 AM »
Along the same lines as Gile I'm afraid  :|
  (if l
    (if (atom l) l
      (if (atom (car l))
        (+ (car l) (LM:SumList (cdr l)))
        (+ (LM:SumList (car l)) (LM:SumList (cdr l)))
    0
(defun LM:SumList2 ( l / x )
  (if l
    (if (atom l) l
        (if (atom (setq x (car l))) x (LM:SumList2 x))
        (LM:SumList2 (cdr l))
    0
« Last Edit: July 17, 2010, 08:16:38 AM by Lee Mac »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: July 17, 2010, 07:47:40 AM »
good here   :laugh:
« Reply #11 on: July 17, 2010, 07:56:40 AM »
good here   :laugh:
Yours will probably wipe the floor with us speedwise too  8-)
gile
  • Marseille, France
« Reply #12 on: July 17, 2010, 08:22:57 AM »
I tried a C# solution, but it's not very elegant  :|
namespace ChallengeSumList
    public class SumListClass
        [LispFunction("gc-SumList")]
        public double SumList(ResultBuffer resbuf)
            TypedValue[] args = resbuf.AsArray();
            double result = 0;
            foreach (TypedValue tv in args)
                switch (tv.TypeCode)
                    case (short)LispDataType.Int16:
                        result += (short)tv.Value;
                        break;
                    case (short)LispDataType.Int32:
                        result += (int)tv.Value;
                        break;
                    case (short)LispDataType.Double:
                        result += (double)tv.Value;
                        break;
                    case (short)LispDataType.Point2d:
                        result += ((Point2d)tv.Value).X + ((Point2d)tv.Value).Y;
                        break;
                    case (short)LispDataType.Point3d:
                        result += ((Point3d)tv.Value).X + ((Point3d)tv.Value).Y + ((Point3d)tv.Value).Z;
                        break;
                    default:
                        break;
            return result;
« Reply #13 on: July 17, 2010, 08:31:26 AM »
One more for the mix  8-)
(defun LM:SumList3 ( l )
    ( (not l)  0)
    ( (atom l) l)
    ( (vl-list-length l) (apply '+ (mapcar 'LM:SumList3 l)))
    ( (+ (LM:SumList3 (car l)) (LM:SumList3 (cdr l))))
gile
  • Marseille, France
« Reply #14 on: July 17, 2010, 09:13:21 AM »
Another way:
(defun sumlist (l)
  (eval
    (read
      (strcat "(+ "
      (vl-string-translate "(.)" "   " (vl-princ-to-string l))
« Last Edit: July 17, 2010, 01:29:36 PM by gile »
