Author Topic: GET COORDINATES FROM SAFEARRY  (Read 1674 times)
psuchewinner
« on: July 16, 2010, 10:00:12 AM »
Ive searched for this and I cant find what Im looking for.  How can I get the coordinates from this:
(setq TextInsertionPoint (vla-get-insertionpoint TextObject))?
I know it is simple but I really dont understand variants and safearrays.
Gliderider
Re: GET COORDINATES FROM SAFEARRY
« Reply #1 on: July 16, 2010, 10:13:16 AM »
(setq TextInsertionPoint (vlax-get TextObject 'InsertionPoint ))
that really didn't answer your question did it? Try this
(setq coords (vlax-safearray->list (vlax-variant-value TextInsertionPoint)))
« Last Edit: July 16, 2010, 10:20:44 AM by lpseifert »
gile
  • Marseille, France
« Reply #2 on: July 16, 2010, 10:20:15 AM »
Look at the safearray->list function.
Another way is to use vlax-get instead of a vla-* function which returns a variant:
(vlax-get TextObject 'Insertionpoint) returns a standard LISP list.
You can also use this sub which convert any variant or safearray into LISP data type
;; gc:VariantToLispData
;; Converts a variant or a safearray into LISP data (list)
;; Argument: var variant or safearray
(defun gc:VariantToLispData (var)
    ((= (type var) 'variant)
     (gc:VariantToLispData (vlax-variant-value var)))
    ((= (type var) 'safearray)
     (mapcar 'gc:VariantToLispData (vlax-safearray->list var))
    (T var)
Look at this thread
psuchewinner
« Reply #3 on: July 16, 2010, 11:33:44 AM »
Awesome, thanks guys.
Does the VLAX work woth all properties?
I will read up on this stuff when I am not quite so busy.
« Reply #4 on: July 16, 2010, 09:11:40 PM »
Here's the one I use for generic conversion ...
(defun lisp-value (v)
  ;; the Holy Grail of vla->lisp conversion? ;-)
  ;; Copyright 2002 Vladimir Nesterovsky.
  ;; Free for use by any commercial entity with
  ;; less then $100 million annual revenue.
  (cond ((= (type v) 'variant) (lisp-value (variant-value v)))
        ((= (type v) 'safearray) (mapcar 'lisp-value (safearray-value v)))
        (t v)
