Author Topic: piracy  (Read 6848 times)
jsr
piracy
« on: July 16, 2010, 06:55:40 AM »
Hi everybody
If someone writes auto/visual lisp code for commercial use. What are the possible measures to prevent its piracy. When using .NET we can have installation packages/activation codes etc But for lisp code what are the possibilities. Even if we create a .fas file it makes the code unreadable but still it can be easily copied/used etc.
Please guide.
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #1 on: July 16, 2010, 07:05:38 AM »
Actually Lisp easier to protect than .NET : )  compile to .vlx, or .fas,
Get the OS activation code or motherboard serial and go from there
jsr
Re: piracy (for eAmbiguousOutput)
« Reply #2 on: July 16, 2010, 07:10:59 AM »
Thanks eAmbiguousOutput
Would you please explain bit more. I want to give the .fas/vlx applications to others who are authorized to use but do not want them to further distribute them to others.
Thanks again.
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #3 on: July 16, 2010, 07:12:24 AM »
heres a link to where you can get some of the hardware needed to build a key
http://www.theswamp.org/index.php?topic=29556.msg350816#msg350816
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: July 16, 2010, 07:20:37 AM »
Thanks again.
Step 1. create a lisp routine in your VLX that can collect a few serials from the hardware.
Step 2, create a lisp routine in your VLX  that can code and decode the serials.
Step 3, create a lisp routine that can generate a request key and  accept an activation key.
step 4, store the activation key.
step 5, at various points in your lisp routine I.e at launch, check that activation key exists and is valid.
something like that  :laugh:
pkohut
Re: piracy
« Reply #5 on: July 16, 2010, 07:22:26 AM »
Is the application already written? If not I wouldn't worry about piracy, it's more important to write the application.
Sorry to be harsh again, but keying your software to the OS or some piece of hardware is, hold it - here's that word again --, stupid. Unless people absolutely need your software, which they probably don't, then that is a first class ticket to no sales.
Re: piracy
« Reply #6 on: July 16, 2010, 07:24:50 AM »
One thing that has puzzled me actually is that surely you need the program to modify itself in some way, else what is to stop the user running the program on another system and the program just going through the procedure as if it was the first time launch?
jsr
Re: piracy (for pkohut)
« Reply #7 on: July 16, 2010, 07:39:56 AM »
Dont be stupid If you do not have any reasonable answer do not bark like street dogs. Non sence
« Reply #8 on: July 16, 2010, 07:42:42 AM »
whoa junior ... you may just need to explain that !!
who are you talking to and why are you being so aggressive ..
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #9 on: July 16, 2010, 07:47:58 AM »
Paul's got one of those opinions  :lol:
I have one program on the market that has keying, While this had absolutely no affect on sales, it is a real PIA to deal with.
pkohut
Re: piracy
« Reply #10 on: July 16, 2010, 07:50:08 AM »
There's lots of ways to handle it. Self modifying code could be one. But if you want to key on the hardware then some sort of hardware hash needs to be sent company so they can send you a key based on it and your name or something.
pkohut
Re: piracy
« Reply #11 on: July 16, 2010, 07:50:42 AM »
I did give a warning.  :-D  :-D
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #12 on: July 16, 2010, 07:53:21 AM »
Aladdin had support for Autolisp, if your looking for a commercial solution http://www.aladdin.com/support/hasp/hasp4/legacyapi.aspx
jsr
Re: piracy
« Reply #13 on: July 16, 2010, 07:55:52 AM »
Sorry Its for Mr. pkohut who should not reply if he does not have a reasonable answer.
I think no question is non snece If the purpose is to learn something. One cannot learn if he/she does not ask questions whether reasonable or not. I had a question in my mind so I posted it to forum Now one does not need to worry if I have any application that is valuable for other or not.
Thanks.
pkohut
« Reply #14 on: July 16, 2010, 07:58:06 AM »
Sorry I didn't provide you with the answer you wanted to hear. After rereading what I wrote, I must agree with myself 100%. Again, my apologies.
Re: piracy
« Reply #15 on: July 16, 2010, 07:59:14 AM »
I see - thanks Paul  :-)
Hangman
Re: piracy
« Reply #16 on: July 16, 2010, 07:37:42 PM »
I wrote an app for an office once.  I thought it worked well under my limited knowledge, the office receiving it thought it was perfect, but I'm sure the guru's here would laugh at the code - I sure do after looking back at it.
But, my point I want to throw out here is this;
I didn't know how to protect it very well and was sure it would be copied and spread across the world in one way or another, so I put a one year limit on it.  I told the office receiving it that there was a one year limit and if they needed it again, just to call for it.
During that time, the code was updated here and there and sent to them with the original date still intact.  The office called once and I simply updated the code for the next year, created a VLX and sent it to them.  There is nothing in the code referencing me.  When the time is up, it simply comes back with a statement:  "Program needs to be updated".  So if anyone else has it, they either need to go back to the office they got it from to get an update, or call me if they know it's from me.
But I wasn't trying to get sales, so there was no need for advertising.
Well, anyway, my too sence wirth.  :)
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
Re: piracy
« Reply #17 on: July 16, 2010, 08:07:06 PM »
I've done that before - when attempting to sell a few programs I've offered a "7-day trial" before in a compiled VLX, but I've never gone into the realms of adding any sort of 'key' (my software isn't really expensive enough for that I shouldn't think).
Re: piracy
« Reply #18 on: July 16, 2010, 09:39:39 PM »
Thanks.
A professional developer giving his professional advice/opinion.
BTW, Don't be so cranky, this forum already has a token a55h0l3--and that would be me-. You play nice now or I will be forced to critique your question asking abilities. And before you come off your chair or froth at the mouth, That was a joke; calm down or I will be forced to reach through the internet and slap you.
Ah but it does matter if the program is `valuable or not' and eAmbiguousOutpt gave you another reason--more like a formula if you will--besides the `sales' he said that he has one app out there that is causing him problems. The PITA is relative to the popularity of the app.
Build a key/hidden file/widget into the installer?
Now that was funny.
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #19 on: July 16, 2010, 10:23:49 PM »
Doh! I did the yearly update thing too!  Now that was stupid  (on my part) : ) I had a ton of expiring builds while I was moving from the US to HK.. I remember sitting in the airport making builds.
IMO there is nothing wrong with keying your applications, In fact it can be a great learning experience that leads to other paths, I.e. encryption etc. Reading the white paper on how Microsoft attaches to hardware serials and gives each a weight, (you can replace two or three hardware items without killing the key), was very interesting. I spent two years writing a converter  from Acad to a third party software called Pattern Systems. PS sells for $35,000 for three seats, I sold the converter for $800. Sales were going fantastic until PS started to go belly up.. Whatever, I made a bit of cash. I believe the keying helped me make more, as I dealt with companies that were growing, they had to call me when they needed more seats.
« Last Edit: July 17, 2010, 05:50:42 AM by eAmbiguousOutput »
It's Alive!
  • Retired
  • AKA Daniel
Re: piracy
« Reply #20 on: July 16, 2010, 11:16:11 PM »
Now that was funny.
got my boots on  :lol:
hermanm
Re: piracy
« Reply #21 on: July 17, 2010, 10:33:12 PM »
It makes sense to me to key an AutoCAD add-on (LISP, .NET, ARX) to an AutoCAD license rather than the hardware.
This seems easy enough to do with a stand-alone ACAD license, but network licenses appear to be another story.
Comments?
Re: piracy
« Reply #22 on: July 18, 2010, 07:40:29 AM »
Do you mean using something like the _PKSER Sys Var?
hermanm
Re: piracy
« Reply #23 on: July 18, 2010, 10:38:52 AM »
Yes, or ..
(can't at this moment lay hands on proper information in HKEY_LOCAL_MACHINE->SOFTWARE)
danallen
Re: piracy
« Reply #24 on: July 19, 2010, 01:14:00 PM »
Here are the routines I setup for an office when I was cad manager. Back when I thought it was really important to protect the offices investment in custom routines (read my own ego about them). After I left the new cad manager called me about how to remove all of that.
The concept was that an encrypted serial # was stored in the registry after a password was entered into each station's config box. Used doslib to get MAC address. Had options for master unexpiring password with network install, or year long passwords for install on roaming machines. Each of my separate .lsp files had this in the header. Entire project compiled into one VLX.
;;; Authorization check
(if (or (not BCV_Authorization)
        (not (= "abracadabra" (BCV_Authorization "CAVEman")))
  (progn (alert "\nBCV Routines not authorized!\nQuitting.")(exit))
Code ran on v2004, I'm sure it is missing some global subroutines from other files. No promises that it works, but might be useful for learning or cribbing code (as I did). Hope my old comments are self explanatory enough.
(code post split into 2 parts)
Dan
Main routines:
;;; ABC_Cypher.lsp
;;; Requires doslib.arx to be loaded
;;; Establishes authorization of ABC routines
;;; At first time setup of ABC routines, this file calls a dialog
;;; with password for authorization "CAVEman"
;;; Assuming success, the routines are authorized with with encrypted
;;; registry entry unique to each machine (can't be copied)
;;; If password is incorrect, the file aborts loading of all further ABC routines
(if ABCdebug (princ "\nStarting ABC_Cypher.lsp"))
;;; test for required dos_lib
(if (not (and dos_version
              (setq dosv (dos_version))
              (>= 6 (atoi dosv))
         ) ;_and
    ) ;_not
    (progn (alert "\nRequires DOSLIB utilities!\nQuitting ABC Routines")(exit))
;;; Function : Returns only a part of a list, works like SUBSTR
;;; Argument : [ Lst ]  - List to check
;;;            [ Start] - starting position, starts from 1
;;;            [  len ] - Number of elements to extract
;;;                       If len is negative, returns until the end of the list
;;; Return   : The extracted list
;;; Updated  : December18, 1998
;;; Copyright: (C) 2000, Four Dimension Technologies, Singapore
;;; Contact  : rakesh.rao@4d-technologies.com for help/support/info
(defun ABC_SubList (Lst Start len / _len n m _Lst)
  (if (minusp len)
    (setq len 999999999)
  ) ;_ if
  (setq _len (length Lst)
        n    (min (- Start 1) _len)                                             ; Starting Index
        m    (min (+ n len) _len)                                               ; Ending Index
        _Lst '()
  ) ;_ setq
  (while (< n m)
    (setq _Lst (cons (nth n Lst) _Lst)
          n    (1+ n)
    ) ;_ setq
  ) ;_ while
  (reverse _Lst)
) ;_ defun
;;; function to return a repeated string of x length characters
;;; if x is less than string length, returns shorter version
(defun ABC_RepeatStringLen (str x / i newstr)
  (setq i 1
        newstr ""
  ) ;_ setq
  (while (< (strlen newstr) x)
    (setq newstr (strcat newstr (substr str i 1))
          i      (1+ i)
    ) ;_ setq
    (if (> i (strlen str))
      (setq i 1)
    ) ;_ if
  ) ;_ while
  newstr
) ;_ defun
;;; simple shift up of one decimal number by another on a base of 255 (hexidecimal)
;;; used for simple encoding of one number by another
(defun ABC_IntShiftBaseUp (a b base / c)
  (setq c (+ a b))
  (if (> c base)
    (setq c (- c base))
    c
;;; simple shift down of one decimal number by another on a base of 255 (hexidecimal)
;;; used for simple decoding of one number by another
(defun ABC_IntShiftBaseDown (a b base / c)
  (setq c (- a b))
  (if (< c 0)
    (setq c (+ c base))
    c
;;; encrypt a string with MAC Address
;;; used to make authorization unique to machine
(defun ABC_EncryptStr_Local (str / StrListDec MACAddress MACListDec NewListDec NewStr)
  (if (dos_macaddress)
      (setq StrListDec (vl-string->list str) ;convert string to list of ascii codes
            MACAddress (dos_strremove (dos_macaddress) ":") ;remove colons from MAC Address
            MACAddress (ABC_RepeatStringLen MACAddress (strlen str)) ;repeat MACAddress length of string to be encrypted
            MACListDec (vl-string->list MACAddress) ;convert MACAddress to list of ascii codes
            ;; cypher string with macaddress
            NewListDec (mapcar '(lambda (x y) (ABC_IntShiftBaseUp x y 255)) StrListDec MACListDec)
            NewStr     (vl-list->string NewListDec) ;convert cyphered codes back to ascii
;;; Decrypt a string with MAC Address
(defun ABC_DecryptStr_Local (str / StrListDec MACAddress MACListDec NewListDec NewStr)
            NewListDec (mapcar '(lambda (x y) (ABC_IntShiftBaseDown x y 255)) StrListDec MACListDec)
;;; ALTERNATIVE
;;; encrypt a string with computer name
(defun ABC_EncryptStr_Local (str / StrListDec computer_name MACListDec NewListDec NewStr)
  (if (dos_computer)
            computer_name (dos_computer)
            computer_name (ABC_RepeatStringLen computer_name (strlen str)) ;repeat computer_name length of string to be encrypted
            MACListDec (vl-string->list computer_name) ;convert computer_name to list of ascii codes
            ;; cypher string with computer name
;;; ALTERNATIVE
;;; Decrypt a string with computer name
  (if (dos_computer)
            MACListDec (vl-string->list computer_name) ;convert MACAddress to list of ascii codes
            ;; cypher string with computer_name
;;; Encrypt a string with a base 255 ABC Cypher (defined below)
(defun ABC_EncryptStr255 (str / StrListDec CypherCode NewListDec NewStr)
  (if *ABC-Cypher255*
            CypherCode    (ABC_SubList (*ABC-Cypher255* "CAVEman") 1 (strlen str)) ;get cypher in length of string to be encoded
            ;; cypher string
            NewListDec (mapcar '(lambda (x y) (ABC_IntShiftBaseUp x y 255)) StrListDec CypherCode)
;;; Decrypt a string with a base 255 ABC Cypher
(defun ABC_DecryptStr255 (str / StrListDec CypherCode NewListDec NewStr)
  (if *ABC-Cypher255*
            ;; cypher string
            NewListDec (mapcar '(lambda (x y) (ABC_IntShiftBaseDown x y 255)) StrListDec CypherCode)
;;; 1000 character long cypher - base 255
;;; Cypher definition needs to be protected from listing
;;; Use (*ABC-Cypher255* "CAVEman") to return list
;;; Be sure to declare as local
(defun *ABC-Cypher255* (password)
  (if (= password "CAVEman")
       (list 229  178  59   199  34   102  136  2    206  210  137  100  25   210  210  93   129  221  32   89   136
             7    228  152  226  34   231  47   204  212  130  180  208  2    116  178  161  97   187  141  78   128
             105  209  130  50   1    166  10   165  50   98   88   253  146  227  64   209  38   198  151  100  77
             19   7    228  2    108  178  150  217  107  244  70   206  50   241  195  60   213  35   215  23   171
             172  125  194  38   155  185  144  65   222  237  86   43   26   246  19   53   31   244  38   164  54
             17   251  134  247  33   187  16   233  111  232  179  154  146  99   102  118  162  217  92   253  166
             256  161  175  145  177  199  74   161  60   58   160  136  16   68   188  34   16   119  143  33   153
             109  210  127  186  159  105  14   136  74   233  1    9    13   137  197  185  85   48   254  12   36
             217  9    2    93   2    211  34   31   97   90   246  73   154  193  103  199  40   57   255  183  47
             168  133  4    125  90   227  136  98   161  227  84   159  171  158  56   33   120  50   23   195  61
             162  43   210  9    95   201  123  21   121  200  243  123  223  16   124  210  192  129  13   90   97
             178  200  58   137  181  10   143  216  103  50   166  24   114  240  68   242  139  69   74   5    23
             244  148  222  180  143  99   181  219  242  47   129  31   66   63   65   43   71   206  5    13   65
             43   173  242  3    148  197  234  129  61   142  184  133  68   156  105  213  254  4    166  109  96
             151  116  19   246  27   107  248  33   2    255  155  22   139  251  179  84   215  185  63   6    213
             55   148  20   142  163  134  75   194  109  113  101  75   129  89   86   69   187  214  174  110  44
             6    109  182  81   61   25   127  198  169  120  115  152  165  197  130  205  241  170  224  50   136
             235  162  15   73   13   196  219  50   210  66   123  93   235  9    51   122  172  106  213  2    30
             219  87   214  81   154  74   128  52   38   109  214  220  244  223  50   129  118  4    245  34   206
             203  147  5    56   85   215  17   160  164  164  57   85   102  220  232  85   115  177  185  49   18
             21   84   245  169  121  209  16   229  160  107  187  242  181  231  206  229  93   131  127  230  256
             195  2    50   3    244  133  155  29   193  123  136  153  173  175  30   157  211  32   165  76   178
             10   191  231  116  47   138  170  118  189  72   161  112  221  159  48   22   88   15   116  139  82
             179  76   117  133  231  51   21   10   229  170  53   19   249  101  74   150  97   244  149  105  112
             40   168  182  7    225  40   83   15   125  17   221  236  177  115  48   165  233  220  13   188  3
             105  134  94   130  189  22   256  11   194  233  249  80   143  56   64   42   57   80   214  25   3
             29   4    227  167  196  239  134  40   62   185  55   251  107  165  170  215  156  116  86   25   251
             121  233  254  227  148  184  148  134  153  63   200  233  69   150  71   171  87   231  175  138  228
             192  208  36   125  99   95   233  67   211  238  183  124  223  135  17   199  208  186  128  128  256
             129  240  113  20   195  167  102  3    222  183  190  175  5    104  140  70   207  155  106  26   203
             137  134  51   117  244  21   79   100  35   175  131  6    185  193  64   194  210  156  230  219  97
             61   172  240  73   114  9    93   36   96   90   116  58   22   255  202  148  49   170  131  171  64
             9    231  164  232  149  35   160  114  183  134  256  210  249  29   46   196  119  244  207  18   89
             227  231  158  118  64   212  72   239  65   172  71   233  109  233  15   38   253  218  88   181  116
             223  99   110  83   215  18   116  56   193  230  118  76   7    140  224  74   108  252  193  254  20
             205  146  151  150  215  157  160  163  183  52   244  37   82   124  142  94   225  253  134  244  185
             169  27   104  69   160  17   239  106  94   83   38   214  142  30   148  90   63   147  117  241  163
             11   207  117  45   2    51   178  36   242  60   225  127  242  48   37   47   120  197  38   154  19
             128  92   124  114  161  43   229  149  35   93   136  120  178  28   33   31   30   250  23   72   69
             44   34   172  223  130  33   24   49   58   228  69   20   82   21   187  86   82   3    156  216  76
             128  176  124  15   145  136  63   40   24   13   145  224  78   93   74   166  30   69   74   44   63
             44   49   162  39   218  33   81   163  217  21   8    67   227  178  141  78   27   16   164  133  123
             125  186  91   80   160  216  233  7    4    245  72   64   122  48   154  102  74   35   105  179  182
             208  156  247  177  78   193  237  96   203  208  137  59   239  57   8    103  85   91   35   39   11
             53   51   235  214  112  175  241  56   143  200  236  221  116  136  176  131  235  75   88   244  134
             225  216  46   109  64   127  79   103  16   85   88   211  238  218  102  191  191  12   123  233  240
             66   97   199  239  187  210  101  186  121  110  75   232  54   157  23   236  28   246  22   3    7
             65   133  145  242  172  184  85   108  76   226  59   154  131
            ) ;_ list
) ;_ setq
;;; desired encryption ascii 32 (space) through 126 = 94
;;; 500 character long cypher - base 36
;;; Use (*ABC-Cypher36* "CAVEman") to return list
(defun *ABC-Cypher36* (password)
       (list 29  24  31  1   7   34  14  6   6   0   15  35  23  19  30  3   22  26  2   17  8   24  26  20  18  26
             5   18  5   9   5   14  28  5   15  19  6   31  27  9   21  13  10  34  9   22  20  23  12  33  9   6
             1   2   0   14  4   8   34  28  7   29  29  11  17  6   8   20  24  6   23  19  23  26  33  8   31  17
             24  27  4   8   30  10  14  19  6   19  17  22  7   18  13  27  22  8   26  24  11  18  22  7   5   34
             1   34  26  34  27  19  13  9   25  22  33  35  14  30  22  34  24  12  33  3   22  13  19  18  8   26
             30  9   6   1   34  19  9   0   12  27  23  31  11  1   26  12  24  30  12  12  11  22  24  1   8   12
             11  21  1   15  19  24  3   7   31  15  13  7   24  9   12  27  18  11  30  32  21  31  16  35  35  6
             31  16  10  21  11  23  4   3   9   12  0   3   15  5   23  30  10  31  19  3   18  18  24  14  32  21
             23  29  21  35  13  6   16  13  3   3   16  28  1   10  33  17  31  26  7   13  25  19  6   16  31  10
             23  1   32  15  33  33  1   2   22  30  33  34  31  9   22  31  1   0   17  11  11  3   7   21  1   24
             22  14  5   28  22  26  26  30  6   12  3   21  25  28  3   3   14  27  17  33  6   16  19  4   4   35
             12  14  31  32  18  10  12  3   29  24  17  20  26  34  32  30  1   9   19  8   25  23  30  22  8   7
             34  21  20  9   1   31  17  20  24  2   13  31  3   34  17  33  2   6   30  27  28  14  2   22  6   34
             7   0   27  8   25  29  32  8   25  5   22  9   29  26  7   26  14  23  19  3   0   11  28  3   7   7
             33  2   2   10  5   26  16  1   31  1   2   21  33  21  29  33  21  5   0   35  32  29  19  7   20  11
             29  20  35  6   5   23  25  27  17  31  28  19  14  4   11  8   1   6   25  2   23  7   2   8   13  16
             1   11  27  25  18  4   34  12  25  13  3   34  32  1   15  32  13  19  3   2   21  23  34  9   29  9
             8   1   16  34  27  5   26  22  6   24  35  27  3   12  33  35  18  15  22  6   19  34  31  7   25  9
             17  33  27  18  21  1   20  1   19  16  21  3   34  7   35  6   0   6   15  7   17  14  35  31  10  7
             2   18  8   3   16  14
            ) ;_ list
) ;_ defun
danallen
Re: piracy
« Reply #25 on: July 19, 2010, 01:16:12 PM »
Second half of code.
;;; Make password dialog box on the fly in temp folder
(defun ABC_MakeTempDcl (/ file)
  (setq file (open (strcat (getenv "TEMP") "\\" "~getpass.dcl") "w"))
  (write-line "// GETPASS.DCL" file)
  (write-line "//" file)
  (write-line "passdlg : dialog {" file)
  (write-line "  label = \"Password to Authorize ABC Routines\";" file)
  (write-line "    : row {" file)
  (write-line "            : radio_column {" file)
  (write-line "                : radio_button {" file)
  (write-line "                    key = \"network\";" file)
  (write-line "                    label = \"Network Installation\";" file)
  (write-line "                }" file)
  (write-line "                  key = \"offsite\";" file)
  (write-line "                  label = \"Offsite Installation\";" file)
  (write-line "                           } //column" file)
  (write-line "          } //end :row" file)
  (write-line "  : edit_box {" file)
  (write-line "    label = \"Password:\";" file)
  (write-line "    edit_width = 20;" file)
  (write-line "    key = \"password\";" file)
  (write-line "    password_char = \"*\";" file)
  (write-line "    is_default = true;" file)
  (write-line "  ok_cancel;" file)
  (write-line "}" file)
  (close file)
;;; Dialog to bring up options for authorization
;;; with password, intended for first time set up of
;;; AutoCAD only, dialog should be skipped after that
(defun ABC_GETPASS (/ dcl_id pass auth return)
  (ABC_MakeTempDcl)
  (setq auth "network") ;set default
  (setq dcl_id (load_dialog (strcat (getenv "TEMP") "\\" "~getpass.dcl")))
  (if (new_dialog "passdlg" dcl_id)
    (progn (set_tile "network" "1")
           (action_tile "network" "(setq auth \"network\")")
           (action_tile "offsite" "(setq auth \"offsite\")")
           (action_tile "password" "(setq pass $value)")
           (mode_tile "password" 2)                                             ; set focus
           (start_dialog)
           (unload_dialog dcl_id)
    ) ;_ progn
    (princ "Error: Unable to load GETPASS.DCL. ")
  ) ;_ if
  ;;(if (setq file (findfile "~getpass.dcl"))(vl-file-delete file))
  ;; Authorize ABC routines with encrypted registry code
  (cond ((and (= "network" auth)(= "CAVEman" pass))
           (ABC_Authorize "CAVEman" "Full Network Permissions")
           (setq return T) ;return flag for success
        ;; for offsite, if password date range and current date match
        ;; authorize routines with encrypted code & password
        ((and (= "offsite" auth)(ABC_AuthCheckOffsite pass))
           (ABC_Authorize "CAVEman" (strcat "Temporary Offsite Permissions:" pass))
  ) ;_ cond
  return
) ;_ defun
;;; Check for ABC Routines authorized with encrypted registry entry
;;;  Decodes with local (MAC Address) code & also ABC cypher to ensure
;;;  that registry entry is unique to each machine (can't be copied)
;;; Returns string type of authorization or nil for failure
(defun ABC_AuthorizationCheck (/ auth dosv dauth return cpos ofpass)
  (and (setq dosv (dos_version))                                                ;verify doslib version
       (>= 6 (atoi dosv))
       ;; get encrypted authorizationcode
       (setq auth (dos_regget "HKEY_LOCAL_MACHINE\\Software\\ABC" "AuthCode")) ;get auth code from registry
       ;; decrypt code
       (setq dauth (ABC_DecryptStr_local (ABC_DecryptStr255 auth))) ;decrypt it
       (or (if (= dauth "Full Network Permissions") ;if it is network
             (setq return "Network") ;return network permission
           ) ;_ if
           (and (setq cpos (vl-string-position 58 dauth))                       ;or offsite - look for colon separating offsite password
                (setq ofpass (substr dauth (+ 2 cpos)))                         ;with password after colon
                (if (ABC_AuthCheckOffsite ofpass) ;verify with offsite list
                  (setq return "Offsite") ;return offsite permission
                ) ;_ if
           ) ;_ and
       ) ;_ or
  ) ;_ and
  return
) ;_ defun
;;; Verify offsite password with date list and current date
;;;  returns T for good
;;;  returns nil for invalid password
;;;  alerts for  for valid out of date password,and returns nil
(defun ABC_AuthCheckOffsite (pass / pwdlst pdatelst stdate enddate cdate newestini inidate return)
  ;;; association list of offsite passwords with range of valid dates
  (setq pwdlst ;ABC_OffsitePasswordList
         (list (list "aardwolves" (list 20030701 20031231))
               (list "test"       (list 20030926 20030927))
               (list "gelatinize" (list 20040101 20040631))
               (list "lutestring" (list 20040701 20041231))
               (list "rottweiler" (list 20050101 20050631))
               (list "picaresque" (list 20050701 20051231))
               (list "flugelhorn" (list 20060101 20060631))
               (list "beleaguers" (list 20060701 20061231))
               (list "zymologies" (list 20070101 20070631))
               (list "nonathlete" (list 20070701 20071231))
               (list "martensite" (list 20080101 20080631))
               (list "firstlings" (list 20080701 20081231))
         ) ;_ list
  ) ;_ setq
  (if (setq pdatelst (assoc pass pwdlst)) ;if password is in list
      (setq stdate   (caadr pdatelst) ;get start date
            enddate  (cadadr pdatelst) ;get end date
            cdate    (getvar "cdate") ;get current date
            ;; get newest ini file in the windows directory
            newestini (car (dos_dir (strcat (dos_windir) "*.ini") 4))
            ;; get date of file
            inidate (ABC_getfiledate (strcat (dos_windir) newestini))
      (if (and (< stdate cdate enddate) ;if current date is in range
               (< inidate (+ cdate 0.01)) ; and current date is older than newest ini file
                ; (adjusted an hour ahead to deal with daylight savings
          (setq return T) ; set return flag ok
          ;; (> 3 (- 20030927 (getvar "cdate")))
          (if (and (> 3 (- enddate cdate)) ;if expires in less than three days
                   (not (vl-bb-ref '*ABCExpireWarn*)) ;check session flag if user already warned
              ) ;_and
              (alert (strcat "Note: ABC Routines about to expire!" ;warn
                             "\n\nContact ABC Architects for new password."
                     ) ;_strcat
              ) ;_alert
              (vl-bb-set '*ABCExpireWarn* T) ;set session flag that user has been warned
            ) ;_progn
          ) ;_if
        ) ;_progn
          (alert "Password has expired - quitting") ; else warn expired
          (dos_regset "HKEY_LOCAL_MACHINE\\Software\\ABC" "AuthCode" "") ;clear code
      ) ;_if
    ) ;_progn
  ) ;_if
  return
) ;_defun
;;; Authorizes ABC routines
;;; with encrypted registry entry
(defun ABC_Authorize (password authd / auth)
  (if (= "CAVEman" password)
    (progn (setq auth  (ABC_EncryptStr255 (ABC_EncryptStr_local authd))
           ) ;_ setq
           (dos_regset "HKEY_LOCAL_MACHINE\\Software\\ABC" "AuthCode" auth)
    ) ;_ progn
  ) ;_ if
) ;_ defun
;;; Actions to run when ABC_Cypher.lsp is loaded
;;; Check if routines authorized
(if (not (ABC_AuthorizationCheck))
  ;; Not authorized, bring up dialog for password & authorization
  ;;  if dialog unsuccessful, then abort
  (if (not (ABC_GetPass))
    (progn (alert "\nIncorrect password!\nQuitting ABC Routines.")
           ;; probably paranoid, but on failure,
           ;;  clear all encryption routines from memory
           (setq ABC_SubList nil
                 ABC_SubList nil
                 ABC_RepeatStringLen nil
                 ABC_IntShiftBaseUp nil
                 ABC_IntShiftBaseDown nil
                 ABC_EncryptStr_Local nil
                 ABC_DecryptStr_Local nil
                 ABC_EncryptStr255 nil
                 ABC_DecryptStr255 nil
                 *ABC-Cypher255* nil
                 *ABC-Cypher36* nil
                 ABC_MakeTempDcl nil
                 ABC_GETPASS nil
                 ABC_AuthorizationCheck nil
                 ABC_AuthorizeNetwork nil
                 ABC_Authorizeoffsite nil
                 ABC_AuthCheckOffsite nil
                 ABC_OffsitePasswordList nil
           ) ;_ setq
           (exit)
    ) ;_ progn
  ) ;_ if
) ;_ if
;;; define shortform authorization for other routines to check
;;; just returns "abracadabra" for authorized, else nil
;;; other checks for type of authorization must use ABC_AuthorizationCheck
(defun ABC_Authorization (password)(if (= password "CAVEman") "abracadabra"))
(if ABCdebug (princ "\nFinished ABC_Cypher.lsp"))
;;; Development work and source info below
(defun test ()
  (setq t1 (ABC_EncryptStr255 "All good dogs go to heaven, 1908234, (*!@!@(*&"))
  (setq t1dec (vl-string->list t1))
  (setq t2 (ABC_DecryptStr255 t1))
  (setq t2dec (vl-string->list t2))
(defun c:t1 ()
  (setq t1 (getstring "\nText to encode: "))
  (setenv "ABC\\Test" (ABC_EncryptStr255 t1))
(defun c:t2 ()
  (princ (ABC_DecryptStr255 (getenv "ABC\\Test")))
(defun c:t3 ()
  (setenv "ABC\\Test" (ABC_EncryptStr255 (ABC_EncryptStr255_mac t1)))
(defun c:t4 ()
  (princ (ABC_DecryptStr255_mac (ABC_DecryptStr255 (getenv "ABC\\Test"))))
;;; convert date to list of ascii characters
(setq t1 (vl-string->list (menucmd "M=$(edtime, $(getvar, date),YYMODD)")))
;(48 51 48 57 48 57)
;;; convert numbers to hex?
;(mapcar '(lambda(x) (atoi (std-num->hex x))) (vl-string->list (menucmd "M=$(edtime, $(getvar, date),YYMODD)")))
;(30 33 30 39 30 38)
;;; get semi unique computer id - network address number
;(dos_macaddress)
;"00:01:02:C7:70:28"
;;; convert to list &
;;; convert hex to decimal
(setq t2 (mapcar '(lambda(x) (std-hex->num x)) (dos_strtokens (dos_macaddress) ":" T)))
;(0 16 181 250 88 249)
;; test encrypt date (t1) with MACAddress (t2)
(setq t3 (mapcar '(lambda (x y) (ABC_IntShiftBaseUp x y 255)) t1 t2))
;(48 67 229 52 136 51)
;; test decryption of date (reverse)
(setq t4 (mapcar '(lambda (x y) (ABC_IntShiftBaseDown x y 255)) t3 t2))
;;; From: rurban@sbox.tu-graz.ac.at (rurban@sbox.tu-graz.ac.at)
;;; Subject: Re: Need Encryption Algorythm in AutoLisp
;;; Newsgroups: autodesk.autocad.customization
;;; Date: 1998/08/23
;;; the trick is using a VERY long cypher which is not transported together with
;;; the encrypted string.
;;; how to splice a char of 255 states into a char of 36 states?
;;; this could be possible with some heavy compression techniques (huffmann or lzw
;;; for example) but if it works for every string is not guaranteed and cannot be
;;; generally guaranteed.
;;; 3) if we assume that the string to be encrypted is of the same order as
;;; the resulting string (36 valid chars) it is very easy and unbreakable by
;;; generating a long sequence of random characters and encryptr your string
;;; with the random cypher-string as generator. xor is enough. and use a simple
;;; alphabet to map the result onto the valid charset.
;;; Strings to be encrypted must be alpha-numberic, no spaces or symbols
;; generate the cypher, this should be quite long and not
;; transported together with with the code!
(defun init-cypher (len / s i)
  (setq *cypher* nil)
  (setq *encypher-pos* 0)
  (setq *decypher-pos* 0)
  (setq *cypher-len* len)
  (repeat len
    (setq *cypher* (cons (ABC_random 36) *cypher*)))
;;; map the decrypted char [0-9],[A-Z] to int 65-101,
;;; force uppercase,
;;; result is guaranteed to be in [65-101]
(defun enmap-char (c / i)
  (setq i (ascii c))
  (if (<= 97 i 122) (setq i (- i 32))) ; force upcase
  (if (<= 48 i 57)  (setq i (+ i 43))) ; 0-9 above Z
  (+ 65 (rem (abs (- i 65)) 36)) ; force interval 65-101
;;; map the encrypted int 65-101 to [0-9],[A-Z]
;;; result is a one-char string in [0-9][A-Z]
(defun demap-char (i)
  (chr (cond ((<= 65 i 90) i)
      ((> i 90) (- i 43)))
(defun encrypt-string (s / i l crypt)
  (setq l     (strlen s)
        i     1
        crypt ""
  ) ;_ setq
  (while (<= i l)
    (setq crypt          (strcat crypt
                                 (demap-char
                                   (encypher-fun
                                     (enmap-char (substr s i 1))
                                     (nth *encypher-pos* *cypher*)
                                   ) ;_ encypher-fun
                                 ) ;_ demap-char
                         ) ;_ strcat
          i              (1+ i)
          *encypher-pos* (rem (1+ *encypher-pos*) *cypher-len*)
    ) ;_ setq
  ) ;_ while
  crypt
) ;_ defun
(defun decrypt-string (s / i l crypt)
  (setq l     (strlen s)
        i     1
        crypt ""
  ) ;_ setq
  (while (<= i l)
                                 (demap-char
                                   (decypher-fun
                                     (nth *decypher-pos* *cypher*)
                                   ) ;_ decypher-fun
                                 ) ;_ demap-char
                         ) ;_ strcat
          i              (1+ i)
          *decypher-pos* (rem (1+ *decypher-pos*) *cypher-len*)
    ) ;_ setq
  ) ;_ while
  crypt
) ;_ defun
;; use simple shifting by the cypher:
; x: 65-101, y: 0-35 => 65-101
; (ENCYPHER-FUN 78 33) => 75
(defun encypher-fun (x y)
  (+ 65 (rem (+ (- x 65) y) 36)))
; (DECYPHER-FUN 75 33) => 78 ??
(defun decypher-fun (x y)
  (while (< (- x y) 65)
    (setq x (+ x 36)))
  (- x y))
(defun cyphertest ()
  (init-cypher 1000)
  (setq s1 "einkleinenachtmusik123")
  (setq s2 "undnocheine987")
  (print s1)(princ " => ")
  (princ (setq es1 (encrypt-string s1)))
  (print s2)(princ " => ")
  (princ (setq es2 (encrypt-string s2)))
  (print (decrypt-string es1))
  (print (decrypt-string es2))
  (prin1)
"einkleinenachtmusik123"  => N95PPUZGQUOBK9BQ1JTQOI
"undnocheine987"  => 1VZTEZHNXPNZC6
"EINKLEINENACHTMUSIK123"
"UNDNOCHEINE987"
hermanm
Re: piracy
« Reply #26 on: July 19, 2010, 10:28:32 PM »
FWIW,
vl-registry-read
vl-registry-write
appear to work just fine.
Docs say:
You cannot use vl-registry-write for HKEY_USERS or KEY_LOCAL_MACHINE
But this is evidently not so. I have written to HKEY_LOCAL_MACHINE\\Software\\My Stuff, & read back the value.
So, I see no need to load doslib to perform this one task.
ElpanovEvgeniy
  • Moscow (Russia)
Re: piracy
« Reply #27 on: July 20, 2010, 12:34:33 AM »
 have a few years, successfully using the keys Senselock EL-STD
