Just wait !!
What happens when you try your example?
Then, what happens when you try these ?
(setq pt1 (getpoint "\n Select Point"))
(command "text" pt1 "" "" "42" "")
(setq pt2 (getpoint "\n Select Point"))
(command "text" pt2 "" "" 42 "")
(setq pt3 (getpoint "\n Select Point"))
(command "text" pt3 "" "" "42" )
(setq pt4 (getpoint "\n Select Point"))
(command "text" pt4 "" "" 42 )
