Good point. Are you having problems with the lineweights on the PDF itself or on the hard copies produced FROM the PDF?
Ahhh, ... Yes !!
OK, question, ... what do you mean
... having problems with the lineweights on the PDF itself or on the hard copies produced FROM the PDF?
I can print a drawing from AutoCAD to the printer and get the results we want. The lineweights are as we want them displayed on a 24x36 sheet of paper. When I print from AutoCAD to the 'DWG to PDF', to a file, then open that file using Adobe's reader 9, the lineweights are at least half of what the dwg print is. So I think, from the hard copies produced from the PDF.?.
Does this answer the question ??
Just throwing this out there. Is your printing settings in your Reader set correctly?
What version of Cad are you using? We had problems with hatch printing correctly from a PDF for the O8 DWG to PDF version.
2010 DWG to PDF version has been working pretty slick.
Sorry, we are using 2010 Map3D. I had read a post where the Adobe Reader 9 would be a problem, but that is not as readily fixable as one might think. If we get rid of Reader 9 and go back to 8, do we also advise our clients to the same ?? If that be the case, why not just email them the old version of DWF viewer and let them install and use that ?? Answer: because it's inconvenient and they know PDF's not DWF's.
I agree with the arguments and I've fought that battle for years now. I still have the old DWF viewer that was only ... 1.6 meg in size if I remember right. Easy to email out and instruct on how to use it. And it still opens the DWF's created with 2010.
Anyway, back to the topic: How do you adjust the "printing settings" in the reader, and why ?? From what I've researched so far,
the problem lies in the conversion from DWG to PDF. Scratch that, so you are suggesting that when we view the drawings with the reader and print them out, that is where the problem may be ?. But even in the reader, the lineweights are not correct, no need to print them out to see that. Would the reader not be displaying correctly ??
One thing you need to make sure of is that all objects have their lineweights set to BYLAYER (for them to print your intended lineweights).
In your CTB file, select all of the colours and then from the Lineweight pulldown, select Use Object Lineweight.
This has been done. Any objects drawn, the lineweights are set to ByLayer. In the Layer Manager, the layers are set to the lineweights we desire. In the CTB file, the colors are set to 'use object lineweight'.
Question: could a single entity drawn, be set to some specific lineweight, and that setting throw off the entire plot ??
Thank you guys for your help.
