Author Topic: Share your ERROR subroutine to get best one  (Read 10534 times)
MeasureUp
Re: Share your ERROR subroutine to get best one
« Reply #45 on: July 12, 2010, 07:30:50 PM »
Thanks to all.
Sam
« Reply #46 on: July 16, 2010, 07:57:30 AM »
;;;m_redraw----objectives highlighted
;;;m_delss-----in the Program Run-time generated temporary objects
;;;m_hbdraw-----in the program Setup This value to determine whether mistakes redraw Graph
;;;m_setFirst------run in the interimSelectSet
(defun hb_error   (a /)
    (not
      (member a
         '("Function is cancelled"
      "Function cancelled"
      "quit / exit abort"
     (princ a)
  (if m_redraw
      ((member (type m_redraw) (list 'ename))
       (redraw m_reDraw 4)
       (setq m_reDraw nil)
      ((= (type m_redraw) 'list)
       (MAPCAR '(LAMBDA (itm) (redraw itm 4))
          m_redraw
       (setq m_reDraw nil)
  (if m_hbdraw
    (redraw)
  (if m_delss
      (vl-cmdf "_.erase" m_delss "")
      (setq m_delss nil)
  (if m_setFirst
    (sssetfirst nil nil)
  (HB_SETVAR m_lst) ;_m_lst saved for the initialization System Variable value
  (setq *error* olderr)
  (vla-EndUndoMark VLAXDOC)
;|«Visual LISP© Format Options»
(200 2 40 2 nil "end of " 60 9 0 0 nil T T nil T)
;*** DO NOT add text below the comment! ***|;
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
David Bethel
« Reply #47 on: July 17, 2010, 07:17:48 AM »
My $0.02
(setq olderr *error*
      *error* (lambda (msg)
                (while (> (getvar "CMDACTIVE") 0)
                       (command))
                (and (/= msg "quit / exit abort")
                     (princ (strcat "\nError: *** " msg " *** ")))
                (and (= (logand (getvar "UNDOCTL") 8) 8)
                     (command "_.UNDO" "_END" "_.U"))
                (nw_rmd)))  ;;; My Mode Reset
-David
R12 Dos - A2K
