Author Topic: Share your ERROR subroutine to get best one  (Read 10537 times)
alanjt
  • Standby for witty remark...
Re: Share your ERROR subroutine to get best one
« Reply #15 on: July 07, 2010, 09:27:19 AM »
You should be flattered :)
Don't get me wrong, I am flattered when I see my code being used by others - but I just get peeved when code is blatently copy/pasted with no credit as to the source is all.
It's a generic error handler. Do you give credit to whom you got the usage of wcmatch in the error handler from?
Dropbox
« Reply #16 on: July 07, 2010, 09:34:32 AM »
Honestly, ask yourself: why?
Let it go man. I'll give you a story. This one time (at band camp) I had a very sneaking suspicion that one guy i knew took my code and assembled a ``for sale program''. I was so weird about the whole situation that I started to work on a VLX and FAS decompiler so i could check. Do you have any idea how long it takes to map out a file structure like that with a hex editor (It takes a long time).  After about a week i started to make some progress and then i realized what i was doing and how much time I was wasting.  ...who cares (chin up)?
Besides, how complicated is this stuff anyways? Not very! Chances are that i could have wrote that very same thing 6 years ago and you then are the copy cat (so there :P ).
« Reply #17 on: July 07, 2010, 09:37:45 AM »
True, perhaps I'm getting worked up over nothing - I know that its only a small amount of code, and simple to write, but what got me was that there was no attempt at understanding the code that was used, clearly demonstrated by the Undomark being left in there. But you are right - I've said my piece, I'll leave it now.
alanjt
« Reply #18 on: July 07, 2010, 09:40:53 AM »
Don't lie, you just want to see your name in lights as much as possible.  :lmao:
Dropbox
« Reply #19 on: July 07, 2010, 09:47:22 AM »
<snip> what got me was that there was no attempt at understanding the code that was used... <snip>
*Phhhttt!* Yeah tell me about it. I post genius all day and i dont even get as much as "hey thats a cool idea".
alanjt
« Reply #20 on: July 07, 2010, 09:49:03 AM »
I think everyone feels that way, at least at some point.
Dropbox
pkohut
« Reply #21 on: July 07, 2010, 10:15:27 AM »
:-D :-D :-D
U-2, eh!
But as far as what Lee is talking about, let it go. Not everyone *wants* to understand the code they use,
some just want to put together a "patchwork quilt of pieces" to get something that works for them. On the
other hand continue to educate those that want to learn and participate. BTW, how long you been programming
anyways? Cause you've got some "elite" skills.  :kewl:
« Reply #22 on: July 07, 2010, 10:30:25 AM »
Thanks Paul - that is high praise indeed considering the source  :-)  I started about a year and a half or so ago, but only in the relatively simple world of LISP - I'd love to do what you guys can do in C++/Arx.
alanjt
« Reply #23 on: July 07, 2010, 11:02:11 AM »
When I grow up, I hope to have 'elite' skills like some here.
Dropbox
pkohut
« Reply #24 on: July 07, 2010, 11:12:47 AM »
Things you lispers' can do is mazing!
LE3
« Reply #25 on: July 07, 2010, 11:18:20 AM »
Me too.
alanjt
« Reply #26 on: July 07, 2010, 11:19:20 AM »
Me too.
Psh, you'll never grow up.  :laugh:
Dropbox
« Reply #27 on: July 07, 2010, 11:48:30 AM »
"[you]" = whomever
[you] want "attempt to understand" the code?
Why did [you] choose to use OR the way you did?
(or (wcmatch (strcase errmsg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\nError: " errmsg " **")))
Why did you terminate it after the first PRINC statement (technically speaking: there would be no difference if you terminated after the second princ)?
    (princ))
Why did [you] choose OR over something simpler to understand like COND?
      ((wcmatch (strcase errmsg) "*BREAK,*CANCEL*,*EXIT*")
       (princ (strcat "\n** Error: " errmsg " **")))
The way [you] use OR in the previous is confusing. In fact it would be less confusing and more straightforward if [you] choose to use IF or COND.
Why did'nt [you] at least stop all commands?
(repeat 2 (command))
Why did [you] choose the name "*error*" and not something like "MYERRHNDLR"
« Reply #28 on: July 07, 2010, 12:01:18 PM »
My answer:
To save from an 'if, not' - OR looks and feels tidier "Either the msg is matched with ... , OR we print it".
Yes there would, if the OR was terminated after the second 'princ', the second 'princ' would not be evaluated as the previous expression returns True. And secondly, the OR would be the last function call so we would have a return of T.
Again, just aesthetics I suppose...
I tend not to use command statements in my code.
I localise the *error* symbol in my code hence performing the same result as restoring the default handler.
How did I do?
« Reply #29 on: July 07, 2010, 12:35:56 PM »
why? There is nothing wrong with COMMAND if you are prepared for it. Besides, two commands like that means <ESCAPE> <ESCAPE>
> ...the second 'princ' would not be evaluated as the previous expression returns True...
See what i mean about confusing? `aesthetics' be damed. [you] or someone needs to maintain this. Make it easier on yourself; ditch the fancy obscure tricks and focus on the elegance.
Why even check the string if your not going to print it if it passes the check BTW? I'm actually kinda confused.
