Author Topic: RENAMING FILES  (Read 4338 times)
krampaul82
RENAMING FILES
« on: June 30, 2010, 05:03:50 PM »
<see attached modules>
This program will take and create a new project directory structure with a user assigned project name, number etc.
once a new project has been created it somtimes needs to have a project number re-assigned is there a way to rename these files the same way they were created?  I hope I am making sense here...
is there a way to have the program continue after this msgbox without hitting OK? (like a little 2 second delay and the program will continue)
MsgBox "Excel Files W/Prefix are in place. On to the Data Extraction Files..."
Matt__W
  • I like my water diluted.
Re: RENAMING FILES
« Reply #1 on: July 01, 2010, 08:13:33 AM »
Try this...
Sub TimedMsgBox()
    Dim cTime As Long
    Dim WSH As Object
    Set WSH = CreateObject("WScript.Shell")
    cTime = 2 ' 2 secs
    Select Case WSH.Popup("Open an Excel file?!", cTime, "Question", vbYesNo)
        Case vbOK
            MsgBox "You clicked OK"
        Case vbCancel
            MsgBox "You clicked Cancel"
        Case -1
            MsgBox "Timed out"
        Case Else
    End Select
End Sub
Autodesk Expert Elite
krampaul82
Re: RENAMING FILES
« Reply #2 on: July 01, 2010, 10:15:56 AM »
Matt,
Well, now I learned a new way to display a message box, thank you for that code but I want to display a message for a brief time and then continue on to the next line of code without the user having to hit "OK" Is this possible? :|
Matt__W
Re: RENAMING FILES
« Reply #3 on: July 01, 2010, 10:17:43 AM »
That's what that code does; it displays a msgbox for 2 seconds then continues.  The lines that read:
        Case -1
            MsgBox "Timed out"
is where you would put your code to continue.
krampaul82
Re: RENAMING FILES
« Reply #4 on: July 01, 2010, 11:33:42 AM »
Matt
The message box just sits there infinitely, it does not continue...
Select Case WSH.Popup("Open an Excel file?!", cTime, "Question", vbYesNo) should this be vbok?
 Case vbOK
        Case vbCancel
        Case -1
            MsgBox "Timed out"
        Case Else
    End Select
Matt__W
Re: RENAMING FILES
« Reply #5 on: July 01, 2010, 11:46:53 AM »
It looks like you didn't copy the entire chunk of code.  What you just posted is missing
    Dim cTime As Long
    Dim WSH As Object
    cTime = 2 ' 2 secs
krampaul82
Re: RENAMING FILES
« Reply #6 on: July 01, 2010, 12:44:05 PM »
I put your entire code in a module and call the sub from where I placed the msgbox code still no dice.... :oops:
Matt__W
Re: RENAMING FILES
« Reply #7 on: July 01, 2010, 01:26:41 PM »
Can you post all or part of the code?  Are you doing it in Excel or AutoCAD?
krampaul82
Re: RENAMING FILES
« Reply #8 on: July 01, 2010, 03:09:36 PM »
Matt
Look at posted module #1 (kind of long) but the sub "gtc_move_Excell" call's from module3 (posted) where i now display the msgbox is where I now would call your sub "TimedMsgBox" instead. this works and by that i mean it displays a msgbox but it does not timeout.  I guess i could skip the msgbox alltogether and quietly finish the program but i like to let the user know where the program is at....
Matt__W
Re: RENAMING FILES
« Reply #9 on: July 02, 2010, 01:42:28 PM »
Take a look at this sample I threw together.  Run the MAIN sub.  It will prompt you to open an Excel file.  Don't do anything.  After 2 seconds, it will automatically continue by loading a userform (frmMain) and which will display a progress bar.
Instead of loading the form, you would put in your code to do whatever it is you want.
krampaul82
Re: RENAMING FILES
« Reply #10 on: July 06, 2010, 12:10:13 PM »
You only supplied the progerss bar.... ;-)
