Author Topic: Replacing a char with another in a Text  (Read 1517 times)
Tharwat
  • Hypersensitive
« on: June 30, 2010, 05:34:14 AM »
Hi
I want to replace a specific chars from the first text and replace it with another within the text selection .
I have reach to the end but the result is nil ..... I think the use of - subst - is not correct.
any help would be appreciated ..
Code:
(defun c:txt (/ 1txt 2txt curTxt entTxt all pt)
(setq 1txt (getstring"\nEnter the old Char.:"); example   123
      2txt (getstring"\nEnter the replaced Char.:"); example the
      curTxt(car(entsel"\nSelect Text:")); Ref123ok
      entTxt(cdr (assoc 2 (entget curTxt)))
(setq all (subst (2txt) (1txt) entTxt)
      hgt (cdr (assoc 40 (entget curTxt))))
(setq pt (getpoint"\nNew text Location: "))
  (command "_.text" pt  hgt "" all "")
; result must be = Reftheok
Regards
Tharwat
Re: Replacing a char with another in a Text
« Reply #1 on: June 30, 2010, 06:45:28 AM »
perhaps something like
(setq 1txt   "123"
      2txt   "the"
      curTxt "Ref123ok"
(setq result (VL-STRING-SUBST 2txt 1txt curTxt))
