This will save the layers the points are on??
IF you open it as a file...and turn off the Description Key stuff...they will look just like the cad objects they are in Land....only after that IF you convert them...the label portion skacks you backwards and forces use of single layer for ALL label components within that style....
(I think the SINCPAK amends to this function)
SINC?
so if you just want them pretty layers and colors...for cad....leave them in autocad...DONT CONVERT to point objects, and don't apply DESCKEYS
if you need their 'data' for a surface...I would use the old project point MDB file....and only insert them into the surface definition
clear as crude oil, right?
if you need them
