Author Topic: ADODB.Connection windows7 (64)  (Read 7926 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: June 29, 2010, 10:04:10 AM »
if you line access to the database *. mdb from windows (64), please share.
My research:
   (setq ac (vlax-create-object "ADODB.Connection")
 ar (vlax-create-object "ADODB.Recordset")
    (vlax-invoke-method
     ac
     "Open"
     "Database=D:\\technolog.mdb; Server=localhost; User ID=Admin; Password=;Provider=sqloled"
     "Admin"
     0
    ) ;_  vlax-invoke-method
  ==>> error provider
    (vlax-invoke-method
     ac
     "Open"
     "Driver={Microsoft Access Driver (*.mdb)};DBQ=D:\\technolog.mdb;"
     "Admin"
     0
  ==>> error provider
    (vlax-invoke-method
     ac
     "Open"
     "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=D:\\technolog.mdb;User Id=admin;Password=;"
     "Admin"
     0
  ==>> error provider
    (vlax-invoke-method
     ac
     "Open"
     "Provider=SQLNCLI10;Data Source=D:\\technolog.mdb;Persist Security Info=False;"
     "Admin"
     0
  ==>> error provider
    (vlax-invoke-method
     ac
     "Open"
     "Provider=SQLOLEDB;Data Source=D:\\technolog.mdb;"
     "Admin"
     0
  ==>> SQL Server does not exist or permission denied.
help my.
kpblc
Re: ADODB.Connection windows7 (64)
« Reply #1 on: June 29, 2010, 12:32:03 PM »
Sorry for my English.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: June 29, 2010, 07:14:00 PM »
I think access uses JET which does not work on 64bit  :|
You have three choices, move the .MDB to a .MDF/ SQL Express or other SQL server , transfer your data to SQLite or quit using databases
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: July 09, 2010, 05:48:12 AM »
after installing ms office 2010 x64 can use the line call:
(strcat "Provider=Microsoft.ACE.OLEDB.12.0;Data Source="
           (findfile "technolog.mdb")
           ";Persist Security Info=False;"
another way - the driver installation from ms office 2010 x64
AccessDatabaseEngine_X64.exe
28.1 MB
« Reply #4 on: July 09, 2010, 05:51:44 AM »
28.1 MB
yes Evgeniy ,
but unfortunately you can't install the 64 bit driver if 32 bit office is installed ....
and most people will install the 32 bit so that their OLD add-ons will still work :- most aren't yet converted to 64bit :(
« Reply #5 on: July 09, 2010, 09:27:44 PM »
In fact, from  http://technet.microsoft.com/en-us/library/ee681792.aspx
The recommendations for which edition of Office 2010 to install are as follows:
If users in your organization depend on existing extensions to Office, such as ActiveX controls, third-party add-ins, in-house solutions built on previous versions of Office, or 32-bit versions of programs that interface directly with Office, we recommend that you install 32-bit Office 2010 (the default installation) on computers that are running both 32-bit and 64-bit supported Windows operating systems.
If some users in your organization are Excel expert users who work with Excel spreadsheets that are larger than 2 gigabytes (GB), they can install the 64-bit edition of Office 2010. In addition, if you have in-house solution developers, we recommend that those developers have access to the 64-bit edition of Office 2010 so that they can test and update your in-house solutions on the 64-bit edition of Office 2010.
and
http://office.microsoft.com/en-au/word-help/choose-the-32-bit-or-64-bit-version-of-microsoft-office-HA010369476.aspx
« Last Edit: July 09, 2010, 09:35:36 PM by Kerry Brown »
