Author Topic: Conversion  (Read 16332 times)
rugaroo
  • The Other CAD Guy
Conversion
« on: November 25, 2003, 06:34:56 PM »
I just placed two files under../lillypond/rugaroo/, and if someone would please convert them from 2004 to 2000 I would greatly aprreciate it.
Thx - Rug
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
Conversion
« Reply #1 on: November 25, 2003, 09:55:40 PM »
rug,
check your folder in the lilly pond.
Hope they saved ok.
rugaroo
  • The Other CAD Guy
Conversion
« Reply #2 on: November 26, 2003, 02:10:07 AM »
Thx a lot CAB...but what are these??? I have never seen these before...
Also, I will be posting some more dwg's if you don't mind...I will move the old ones off here shortly...
Rug
Conversion
« Reply #3 on: November 26, 2003, 06:56:18 AM »
rugaroo, that would be proxy objects for the LDD custom objects that you don't have the object enablers for. If you go to the Autodork web site and look for LDD object enablers, you should be able to download them and install them so you can see the objects. You won't be able to modify them, but you will be able to see and plot them.
Conversion
« Reply #4 on: November 26, 2003, 08:16:41 AM »
K
i didn't know you could do that.
I have drawings that were created with ADT and though I had to live with the
trash on the screen. They were sent to me for reference info for a similar
model of house created by the previous designer for a new customer of mine.
Thanks for the tip.
I have 2004 but still use 2000 until I have time to convert all my menu and
buttons to a portable form so they can go with me.  More homework. :(
Conversion
« Reply #5 on: November 26, 2003, 08:24:19 AM »
Rug -
if you create the contours with plines you will get better results when converting back.
daron
Conversion
« Reply #6 on: November 26, 2003, 09:07:56 AM »
Quote from: CAB
Have a looksy here
Conversion
« Reply #7 on: November 26, 2003, 10:11:05 AM »
Yes thanks, I have it  already, but this working for a living is interfearing .
I did read the previous version though. :)
I'll get around to it.
rugaroo
  • The Other CAD Guy
Conversion
« Reply #8 on: November 26, 2003, 04:25:32 PM »
See that is the wierd thing....All of the plots that I have for this are clean, and I have made sure that the guy I got the topo from is using just the basics before he sends them to me, but after CAB saved them down, wow. Could it have been the ADT??? Aslo I just noticed this error with everything I try to do in that dwg now:
Closing Autodesk Map project...
Opening an AutoCAD 2000 format file.
Substituting [simplex.shx] for [AvantGarde Md BT].
Substituting [simplex.shx] for [MONOPLEX.shx].
Substituting [simplex.shx] for [MONOPLEX].
Substituting [simplex.shx] for [HELV.SHX].
Resolve Xref "RECORD OF SURVEY 091603": C:\Land Projects 2004\Antelope Rotated
030203\dwg\RECORD OF SURVEY 091603.dwg
File I:\Projects\Antelope Rotated 030203\dwg\RECORD OF SURVEY 091603.dwg was
saved after a drawing editor crash.
It must be recovered before being attached.
Regenerating model.
Command:
ARX_ERROR: eNotThatKindOfClass
Initializing...
ARX_ERROR: eNotThatKindOfClassPress ENTER to continue:
Command:
AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
DDChText 3.01 (c) cad nauseam, 1996-2000. Unregistered shareware.
AutoCAD menu utilities loaded.
Loading retired macros...
Command:
Sorry for the length.
Rug
daron
Conversion
« Reply #9 on: November 26, 2003, 04:28:58 PM »
It could be any desktop. They all use ARX files that standard cad can't run.
Conversion
« Reply #10 on: November 26, 2003, 04:32:13 PM »
Did you get the object enablers form Autodork?
rugaroo
  • The Other CAD Guy
Conversion
« Reply #11 on: November 26, 2003, 05:25:15 PM »
Yeah I got all of the enablers, but that is what keeps coming up with only that gp dwg that he saved. I am getting more errors with the new enablers.
Conversion
« Reply #12 on: November 26, 2003, 05:31:30 PM »
Put the dwg back up there Rug and let me try it.
rugaroo
  • The Other CAD Guy
Conversion
« Reply #13 on: November 26, 2003, 05:33:20 PM »
Ok Mark...give me a few minutes...gotta finish a new parcel map for NY...
rugaroo
  • The Other CAD Guy
Conversion
« Reply #14 on: November 29, 2003, 01:18:03 PM »
Ok...sorry it took me so long, but I reposted the files that were in lilly.pond. There are two zip files that I placed in there. Let me know what happens.
Rug
