Author Topic: Dimensions using plat coordinates  (Read 14274 times)
wjbzone
Re: Dimensions using plat coordinates
« Reply #15 on: May 06, 2014, 10:14:35 AM »
Could use something like that to check some legal descriptions.
Yes. You will have to enter the deed in the correct columns in the spreadsheet.
The attached spreadsheet has some instructions and comments, but not sure how user friendly it is.
alanjt
  • Standby for witty remark...
« Reply #16 on: May 06, 2014, 12:21:31 PM »
That's pretty in depth. I've always just plotted the legal in autocad and gone from there.
Dropbox
wjbzone
« Reply #17 on: May 06, 2014, 01:52:40 PM »
I like entering data into the spreadsheet because it is so easy to check and correct if needed. (It also has columns for poles and links hidden unless needed)
The spreadsheet's output script file can label points, lines, add descriptions and draw a circle at each point (each on specified layer). Read the script file into Autocad using the "scr" command.
alanjt
« Reply #18 on: May 06, 2014, 01:59:15 PM »
Whoa. Will have to try this out.
Thank you for sharing.
Dropbox
