Author Topic: import KMZ  (Read 36029 times)
Re: import KMZ
« Reply #15 on: June 23, 2010, 10:15:05 PM »
All,
I have a locator that is tracking pipelines using Google Earth. I am using Civil3D 2010 and it is my understanding that I can import Google Earth objects directly into Civil 3D. Can anyone explain how I would import line work. The help file explains how to import the images and the elavation data, but not any linework.
Thank you in advance!
OK, after much more care reading C3D and autocad HELP files.....
Google Earth Import and Export Command Reference
The following table lists the AutoCAD Civil 3D commands related to import and export operations with Google Earth and briefly describes their functionality.
Command
 Description
GETime Attaches the timespan information to civil object entities
ImportGEData
 Imports Google Earth image and terrain data into a created TIN surface
ImportGEImage
 Imports a Google Earth Image into a drawing
ImportGEMesh Imports elevation data of the current Google Earth view into AutoCAD Civil 3D as a mesh
ImportGESurface
 Imports Google Earth terrain data into a created TIN surface
PublishKML
 Publishes Civil design data to Google Earth in the KML (uncompressed) format
PublishKMZ Publishes Civil design data to Google Earth in the KMZ (compressed) format
So the short anser is NO you can NOT import these route tracings directly from Google Earth into C3D or Autocad; without using a(n) intermediate step of translating the data.
Willie
  • Going nowhere slowly
Re: import KMZ
« Reply #16 on: June 24, 2010, 01:09:50 AM »
Do you have path selected?
Re: import KMZ
« Reply #17 on: June 24, 2010, 06:33:05 AM »
My experiments were/are focused solely on wether a user can import the Google Earth Paths straight from the KML/KMZ files using ONLY C3D or Autocad functionality.
I am most certain that the kml2everything tools will not only work, they are mandatory as it does NOT work using only C3D/Autocad functions; that being the users original question.
The final answer being one will need use a third party application for this task. Global Mapper, or the KML tool box, or other.
neyton
Re: import KMZ
« Reply #18 on: August 27, 2010, 03:44:23 PM »
import kml to autocad:
http://tbn2.blogspot.com/2008/04/expge.html
use command READKML
Visit my website: http://tbn2.blogspot.com
Re: import KMZ
« Reply #19 on: August 27, 2010, 04:01:47 PM »
use command READKML
Say Neyton, you have that in english?
from my command line in C3D:
Command: readkml
Unknown command "READKML".  Press F1 for help.
Perhaps post a copy of whatever application you wanted to draw our attention to here with your post.
You know just to make it easy on us English only folks.   ;-)
Dilip Damle
Re: import KMZ
« Reply #20 on: October 19, 2010, 07:19:42 AM »
Hello to every one
I am new here
I have found and am using a FDO for linking to KML
It is here
http://www.sl-king.com/FdoKML/FdoKML.html
You can convert a kmz to kml by using googleearth
Rgds
Dilip Damle
New Delhi (India)
drizzt
Re: import KMZ
« Reply #21 on: October 25, 2010, 02:34:03 PM »
Welcome Dilip!
Willie
Re: import KMZ
« Reply #22 on: October 26, 2010, 03:41:02 PM »
http://beta.fmeserver.com/userweb/sharper/Portal/EasyTranslator/index.html
I have been struggling today to convert a kml file to a shapefile, but with all the attributes included. I found the above website that do the trick. It convert kml to shapefiles with the attributes included.
neyton
Re: import KMZ
« Reply #23 on: May 21, 2013, 11:35:10 AM »
IMPORTGMMAP, import maps from google maps to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=IMPORTGMMAP&ajuda=True
IMPORTGMPTS, import elevation points from Google Maps to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=IMPORTGMPTS&ajuda=True
EXPGE, export KML from AutoCAD:
http://tbn2net.appspot.com/showprog?progid=EXPGE2&ajuda=True
READKML, import KML to AutoCAD:
http://tbn2net.appspot.com/showprog?progid=READKML2&ajuda=True
pages is to help translate other languages ​​with google translate
DaveD
Re: import KMZ
« Reply #24 on: May 21, 2013, 07:04:13 PM »
You can also use QGIS (Quantum GIS), a free open sourcce app, to do this - create layer from KML/KMZ and export to SHP
