Author Topic: # Purging a Block #  (Read 2361 times)
Andrea
# Purging a Block #
« on: December 08, 2004, 05:51:53 PM »
Another one....
I have a drawing named "D1"
In this drawing i have made a simple block containing a line
and name the block "test" but this block is not inserted in "D1"
So I have saved the "D1" without purging the drawing to keep the block "test"
Now, if I start a new drawing and than insert the "*D1" (exploded)
the block listed in the current drawing is "D1" and "test".
So if I purge the current drawing the "test" is disapear but not the "D1"
Why ?
Keep smile...
# Purging a Block #
« Reply #1 on: December 08, 2004, 07:16:56 PM »
huh?  :D
# Purging a Block #
« Reply #2 on: December 08, 2004, 07:42:30 PM »
because you evidently did something incorrect ... according to your description, it 'should' work properly so I would suggest looking at the methods you use....
Do a search on your HD for D1 and see if there is more than 1 of them... this is frequently the cause of strange occurences.
Andrea
# Purging a Block #
« Reply #3 on: December 09, 2004, 02:11:28 PM »
no, sorry.
I've started from scratch with the acad.dwt file.
I need to redefine the block before and purge after..
dont'know why.. :cry:
So any other woy to insert a drawing without using the INSERT command ?
Keep smile...
