Author Topic: Removing a Support Path  (Read 3047 times)
ML
« on: December 08, 2004, 05:26:06 PM »
I created a VBA Module for adding and appending our Support Paths.
I wanted to be able to delete support paths as well as certain ones are not needed.
Does anyone know of a way to delete a support path?
I see no method for remove
Thank you
« Reply #1 on: December 08, 2004, 05:51:46 PM »
Obtain the support path string, modify it how you want it, replace the old with the new....
Anonymous
« Reply #2 on: January 22, 2005, 09:07:58 PM »
In the case of just replacing one for the other, the replace command would work really well but I was literally trying to get rid of 4 old paths on 5 different machines, not to be replaced.
Luckily Keith had created a function that worked along with the replace command and got it done for me.
